Date/Time: Sun, 05 May 2024 21:39:06 +0000
BOLLINGER BAND SQUEEZE
View Count: 1250
[2019-08-23 02:02:28] |
BLAKE R - Posts: 23 |
HELLO, WHAT SYNTAX WOULD I USE TO NOTE THAT THE BOLLINGER BAND SQUEEZE IS EITHER TRUE OF FALSE [ RED OR YELLOW DOTS ]? THANK YOU, BLAKE |
[2019-08-23 18:08:45] |
It would just be if the Bands Ratio subgraph is greater than 0 (true) or less than 0 (false). If you are putting this into an alert, it would look like this to test if it is True: ID1.SG1 > 0
Where ID1 is the ID number of the Bollinger Squeeze study, and SG1 is the first subgraph of the study, which is the Bands Ratio. For more information, refer to this section of the Alerts documentation and the section below it: Study/Chart Alerts And Scanning: Referencing Study Subgraphs Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
