Date/Time: Thu, 02 May 2024 18:20:21 +0000
Bitmex connection issues
View Count: 505
[2019-08-23 17:21:12] |
U536222 - Posts: 40 |
sorry i meant the messages are top left
[2019-08-23 17:47:08] |
This message is marked as hidden. We do not normally respond to hidden messages. You should use separate API keys. But you need to ask BitMex about that. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2019-08-23 18:14:44] |
Yes, I thought I'd see what that 'hidden' command is. Since the support pages say one can send such if we didn't want it public. But thanks for replying; much appreciated I will generate a new API key and test it. Regards
