Date/Time: Fri, 26 Apr 2024 14:31:05 +0000
Add Plot to VBP
View Count: 895
[2019-08-22 14:36:45] |
User993067 - Posts: 137 |
Under VBP settings and inputs Display entire Ask Volume - Bid Volume in SG:95 Question can this be displayed on both the top and the bottom of profile? right now it only displayed on the top and deep sell offs when the range extends quickly i cant see the display without scrolling up which is a distraction...it would be very helpful if this were displayed on both ends of the profile...and perhaps add a color direction if the profile delta was negative and positive. thank you. |
[2019-08-23 10:53:49] |
Yes we can add that capability.
[2019-08-26 14:55:25] |
Thank you very much for considering this. Please advise when next update reflects changes.
[2019-09-11 13:45:36] |
Hello, Has there been progress on this feature request? Thanks |
[2019-09-12 13:34:53] |
Is there a workaround available? Can I float a subgraph value on the DOM or chart?...viewable in spreadsheet?
[2019-09-12 23:20:18] |
There have been changes that are in the most recent version (v1987). The documentation has not been updated yet for these changes, but if you scroll down towards the bottom of the Inputs for the Volume by Price study, you will see options for displaying the data, along with selecting which data to display and where to display it. There is not the option for both top and bottom, but you can display it on the bottom of the screen, so it will always be viewable. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2019-09-12 23:20:37
[2019-09-13 00:25:59] |
Thank you for addressing this modification: Once view at bottom window is enabled values disappear when I adjust scale by left click drag on scale or scrolling center wheel. I also feel the bottom of the windows is too far from my "line of sight" Is there a way to pin this to VWAP, POC?...send this values to a spreadsheet? or to float it in its own window (like a control bar but with values in it) where I can place it where I want and set window to always visible? thanks again in advance |
[2019-09-13 13:52:24] |
Also just an FYI...lost visual on deep sell off on bottom of graph setting and bottom of window setting...without scale adjustment..returns randomly..or when price returns to within last visible scale..not sure but erratic
[2019-09-16 11:08:57] |
We will take care of the issue described in post #7 and #8. Also refer to: Volume By Price Study: Viewing Volume Profile Text Information Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
