Date/Time: Sun, 28 Apr 2024 05:09:50 +0000
The Panic button
View Count: 638
[2019-08-21 17:50:30] |
User680338 - Posts: 4 |
Hi all, I'll like to have the option to configure a "panic button". What I want is to lock trading, just for a while (15-20 mins). Is there any option or study for that? just pushing a button and not with Global Profit/Loss Management rules. thanks in advance. Regards. |
[2019-08-21 21:09:55] |
This is not supported.
[2019-08-22 01:36:20] |
User19165 - Posts: 346 |
Yes you can do this. I have my DOM set to keyboard shortcut that will lock trading. Look in Global Settings | Customize Keyboard Shortcuts | Trading | Trading Locked
