Date/Time: Sat, 04 May 2024 12:21:13 +0000
Sierra Chart Real-Time Exchange Data Feed Trial
View Count: 924
[2019-08-20 18:21:11] |
Giamsterdam - Posts: 33 |
On my DOM I don't see the [M} behind the symbol. On my other chart I do. the charts are linked and showing the same instrument.
[2019-08-21 05:54:56] |
If you see [M] for the same symbol in another chart within the same instance of Sierra Chart, then the data for that symbol will be coming from the Sierra Chart data feed.
[2019-08-21 14:16:20] |
perfect thank you!
[2019-08-29 07:50:06] |
The 1978 Timestamps on CQG seem to have improved the market replay a lot. I have to do some side by side comparisons with an older version though. Does the timestamping also works on CQG datafeed? Or only in combination with Sierra Datafeed |
