Date/Time: Wed, 01 May 2024 16:44:59 +0000
Candle Body
View Count: 626
[2019-08-20 17:22:04] |
MazSalih - Posts: 4 |
Hi I have searched through the studies but unable to ssource what I'm after so was wondering if you can help. Is there a way that I can colour a bar when it's body is 50% less than it's range? |
[2019-08-21 06:46:56] |
Use the Color Bar Based on Alert Condition study and you would use a formula that looks like this: =ABS(O - C) < 0.5 * (H - L)
Refer to the following for the study: Color Bar Based on Alert Condition And refer to the following for alerts in general: Study/Chart Alerts And Scanning Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
