Date/Time: Sun, 28 Apr 2024 15:27:49 +0000
Can a Spread Order be based on a SG?
View Count: 536
[2019-08-19 17:11:26] |
Himalaya - Posts: 10 |
The Spread Order feature seems to only allow the order to be triggered by a static price. Is it possible to have the trigger price be activated by an SG? I.e less or equal/ greater or equal to an SG? If this feature is already existing could someone kindly direct me to it. Thank you. |
Spread Order based on SG.PNG / V - Attached On 2019-08-19 17:09:35 UTC - Size: 83.26 KB - 236 views |
[2019-08-19 19:37:52] |
This is not supported but the source code for the study is provided and you can modify it to your requirements. Refer to: How to Build an Advanced Custom Study from Source Code Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
