Date/Time: Sat, 27 Apr 2024 14:24:22 +0000
[Programming Help] - Automatic trading using python
View Count: 2927
[2019-08-19 17:10:37] |
User740266 - Posts: 26 |
I do automatic trading using API (python) in Interactive broker using non-tick data before. However, my new strategies require me to import tick data (number bars data) to my trading program and send order request to IB, may I ask how could I do this? Is there any documentation I should refer to? Thanks.
[2019-08-21 09:08:01] |
Could someone help me on this?
[2019-08-21 18:36:57] |
This is outside the scope of our support but there is export functionality within Sierra Chart. You can find the commands for this on the Edit menu: Edit Menu Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2019-08-21 20:10:30] |
Sawtooth - Posts: 3978 |
You'll need to set the 'Intraday Data Storage Time Unit' to 1 tick: Tick by Tick Data Configuration Once you have changed the setting, you'll need to delete existing data and redownload the 1 tick data: Edit Menu Edit Menu: Edit >> Delete All Data And Download Also, concerning IB data, note item #3 here: Tick by Tick Data Configuration: Instructions |
[2019-08-22 04:44:44] |
Thank you. I understood how to export tick data from Sierra Chart. But does Sierra Chart allow for live stream export of data?
