Date/Time: Sat, 27 Apr 2024 05:49:50 +0000
VWAP (pink line) on TPO doesn't update automatically
View Count: 684
[2019-08-19 11:32:25] |
ez2000 - Posts: 7 |
How come my Volume Weighted Average Price -Rolling (studies) applied on TPO charts doesnt update automatically? I have to right click Studies>Apply to get it updated. I already adjusted number of days to calculate and I still get same result. What to do here?
Private File Private File Private File |
[2019-08-19 11:34:18] |
Refer to: Time Price Opportunity (TPO) Profile Charts: Using Other Studies on a TPO Chart Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2019-08-19 14:42:17] |
ez2000 - Posts: 7 |
I don't think you understood the problem I posted. My TPO charts are working fine. The Volume Weighted Average Price -Rolling study that I added on top of it is the problem. It is not updating. Check the screenshot I sent HERE.
Screenshot - 8_19_2019 , 10_37_49 AM.png / V - Attached On 2019-08-19 14:41:54 UTC - Size: 38.77 KB - 212 views |
[2019-08-19 17:54:54] |
Once again refer to: Time Price Opportunity (TPO) Profile Charts: Using Other Studies on a TPO Chart (Using Other Studies on a TPO Chart) Tell us what you do not understand in that section. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
