Date/Time: Sat, 04 May 2024 09:52:30 +0000
NSE INDIA DATAFEED & TRADING OPTIONS & FUTURES IN IB ACCOUNT
View Count: 1584
[2019-08-19 04:43:48] |
rvdesh - Posts: 28 |
Dear Sir, I have taken a 15 days trial. Will be keen for Service Package 5. I trade NIFTY Index options of NSE India through IB Account. I wanted to know if there are any other data-feed sources (other than IB itself) that are supported by Sierra Chart? Globaldatafeeds, eSignal... Also, please send me link that explains procedure to map symbols between data provider and IB for auto-trading. Does Sierra chart auto-trading system has methods to place IB's Scale Trader Algo and AccumulateDistribute order? If not are there any in-built functions/methods in Sierra Chart. |
[2019-08-20 08:16:00] |
I wanted to know if there are any other data-feed sources (other than IB itself) that are supported by Sierra Chart? Globaldatafeeds, eSignal... Not at this time.Also, please send me link that explains procedure to map symbols between data provider and IB for auto-trading. There is no need for this.Does Sierra chart auto-trading system has methods to place IB's Scale Trader Algo and AccumulateDistribute order? No.If not are there any in-built functions/methods in Sierra Chart. Have a look at the ACSIL trading functions:Automated Trading From an Advanced Custom Study Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2021-03-16 13:11:13] |
User202416 - Posts: 37 |
I am using SC level 5 with Global data feed fir Nifty in India . I compared tick data many days with esignal and found that 1. In foot print all bids and offers are matching with e signal but for some high and low volume bid and offer in same foot print , it is showing bid in offer side and offer in bid side Due to this issue Number bar calculated values are displaying different data . Can Sierra suggest any other vendor for India data feed for me if it has alternative vendor including other countries |
[2021-03-16 14:01:16] |
Earlier I had an issue with Range Bars. Globaldatafeeds tech team fixed it in a very short time. Have you approached them? If yes, what is their response? I had requested if truedata can also be approached for datafeed. Atleast a standby option will be there. |
