Date/Time: Fri, 03 May 2024 19:39:06 +0000
Current Jigsaw user looking to convert to SC
View Count: 2717
[2019-08-19 04:41:06] |
feelingtheblues - Posts: 4 |
I read some documentation but couldn't find what I was looking for? I currently use the Jigsaw DOM platform. My broker is deep discount trading with Ironbeam as my FCM, and I have an active account. My main question is, can I sign up for Sierra and bridge it to Jigsaw, while still using only 1 data feed? My data feed is CQG. I'd use Sierra Charts for data only and use Jigsaw as my execution platform. Is this possible with only 1 data source, would I need to have 2 separate data feeds? My long-term plan is potentially converting from Jigsaw, solely to Sierra. For my Jigsaw service, I pay yearly, with an expiration at the end of this year, so I have 4 or 5 months left. My other question, completely separate from above. For the Sierra DOM, can I plot levels on a chart, then that chart would automatically load the levels onto the DOM, without me having to do a second step? To follow-up with that, if the static levels automatically load onto the DOM, can a dynamic level be autoloaded as well, mainly an exponential moving average. If I use a 5 minute chart with an EMA, can that EMA be shown on the DOM as well? Preferably highlighted or at least in some sort of alert column? If you have any questions, just let me know. I appreciate any feedback. |
[2019-08-19 07:05:28] |
would I need to have 2 separate data feeds? This really would be much better. We recommend using this data feed:Denali Exchange Data Feed If you want to use CQG you would have to ask your broker to see if you can have two connections to CQG at the same time. In our experience no, but maybe you can pay for a second connection. If you are using our data feed, you would still have to connect to CQG once a month from Sierra Chart to authorize the CME data: Real-Time Exchange Data Feeds Available From Sierra Chart: Understanding and Accessing Data From the CME, CBOT, NYMEX, COMEX Exchanges . For the Sierra DOM, can I plot levels on a chart, then that chart would automatically load the levels onto the DOM, without me having to do a second step? To follow-up with that, if the static levels automatically load onto the DOM, can a dynamic level be autoloaded as well, mainly an exponential moving average. If I use a 5 minute chart with an EMA, can that EMA be shown on the DOM as well? Preferably highlighted or at least in some sort of alert column?
Yes. Refer to:Copying Chart Drawings from Other Charts Automatically Study/Price Overlay Study Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2019-08-19 07:07:00
