Date/Time: Fri, 03 May 2024 13:20:10 +0000
The Russell 2k Historical Chart
View Count: 973
[2019-08-18 01:04:06] |
User628 - Posts: 18 |
Hello. The Russell 2k use to use the symbol RJ# for historical charts. It seems to no longer be available. Does anyone know the current symbol? I've searched through all the possible symbols and can't find anything, So this was my last resort. Thanks again
[2019-08-18 17:45:29] |
User90125 - Posts: 715 |
Try QR# ... https://www.sierrachart.com/index.php?page=doc/SierraChart_RealTime_And_Historical_Symbols.php&SymbolsPage=Futures#GBLX
[2019-08-18 17:56:23] |
Thank you. But I've tried every possible symbol. QR#, QRZ19, QR_F. TF, RTY, And some other symbols that are the Russ 2k. So far haven't found the correct symbol
[2019-08-18 18:22:55] |
Dunno, dude. Try again, carefully. QR# populates a daily historical chart fully and completely here. https://www.sierrachart.com/Download.php?Folder=SupportBoard&download=30831 |
[2019-08-18 22:50:44] |
I don't know what the heck I did wrong yesterday, maybe just the symbol QR# at the top of the chart didn't work. So because of you I put QR# in the chart settings and it worked. Thank you
[2019-08-19 00:13:00] |
You need to use the symbol RTYU19 for the current contract. The Barchart symbol QR plus the month code and 2 digit year will work as well. But we have the symbol settings properly defined for RTY so that is what you will want to use. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2019-08-19 00:13:18
[2019-08-19 00:35:11] |
RTYU19 or RTYU9 don't work when trying to open a true historical chart for me. Probably something simple in the symbol settings that needs to be updated so that QR# opens automagically when using the current RTY contract for historical charts. Can you point me to the proper symbol settings please so I may update them myself? |
[2019-08-19 07:09:11] |
For Transact the correct symbol is RTYU9. If you are not getting a historical chart, then follow the instructions below: Follow the instructions here to clear the Message Log: Message Log: Clearing the Message Log Fully re-download the data in the chart by going to the chart and selecting "Edit >>Delete All Data and Download". After about a minute provide a copy of the Message Log following these instructions: https://www.sierrachart.com/index.php?page=PostingInformation.php#MessageLog Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2019-08-19 21:21:32] |
Software version: 1941 64-bit | 2019-08-19 17:10:11.849
Enabled for: Advanced Features. | 2019-08-19 17:10:11.849 Enabled for: Advanced Features 2. | 2019-08-19 17:10:11.849 Enabled for: Sierra Chart Historical Data Service. | 2019-08-19 17:10:11.849 Allow Support for Sierra Chart Data Feeds is enabled. | 2019-08-19 17:10:11.849 Current selected Data/Trading service: TransAct Trading | 2019-08-19 17:10:11.849 Custom symbol settings values: enabled | 2019-08-19 17:10:11.849 Chart Update Interval: 10 | 2019-08-19 17:10:11.849 Intraday Data Storage Time Unit: 0 | 2019-08-19 17:10:11.849 Service username command line set: en*** | 2019-08-19 17:10:11.849 Time Zone: -04:00:00 (EST-05EDT+01,M3.2.0/02:00,M11.1.0/02:00) | 2019-08-19 17:10:11.849 2019-08-19 17:10:11 Local computer time | 2019-08-19 17:10:11.849 2019-08-19 21:10:11 Local computer time in UTC | 2019-08-19 17:10:11.849 2019-08-19 17:10:11 Local computer time in SC Time Zone | 2019-08-19 17:10:11.849 2019-08-15 00:33:19 Server time in UTC | 2019-08-19 17:10:11.849 Local computer UTC time and Server UTC time difference: 0 seconds. | 2019-08-19 17:10:11.849 Program path: G:\SierraChart\SierraChartTransActMA\ | 2019-08-19 17:10:11.849 Data Files path: G:\SierraChart\SierraChartTransActMA\Data\ | 2019-08-19 17:10:11.849 OS Version Number: 10.0 | 2019-08-19 17:10:11.850 Locale Setting: C | 2019-08-19 17:10:11.850 DLLs: CumulativeDeltaVolumeBars_64.dll, CustomMACD_64.dll, DailyHighLow_64.dll, DailyPercentR_64.dll, DMIADXOsc_64.dll, DonchianChannels_64.dll, FlexMACD_64.dll, KAMA_BinaryWave_64.dll, ShiftedRedux_64.dll, sst_FreeBundle.dll, sst_FreeBundle_64.dll, StudySubgraphsReferences_64.dll, UltraMACD_64.dll, UserContributedStudies.dll, UserContributedStudies_64.dll, VCValueLevels.dll, X-O_Lines_64.dll, X-O_Line_64.dll | 2019-08-19 17:10:11.850 RTYU9 Daily #8 | Reloading chart. | 2019-08-19 17:10:34.912 + Chart Data Loading Thread Stopwatch: 0.003185 seconds. | 2019-08-19 17:10:34.919 RTYU9 Daily #8 | StartDateTimeForLoadingOrderFills: 2018-06-14 00:00:00 | 2019-08-19 17:10:34.950 HD Request # 934 | Downloading Historical Daily chart data for RTYU9. Starting date: 2019-08-16. Service: TransAct.Trading | 2019-08-19 17:10:35.067 HD Request # 934 | Requesting historical Daily data for QRU19 starting at 2019-08-15 | 2019-08-19 17:10:35.067 HTTPS connection ID:5 to historicaldata.sierrachart.com:443 for request ID:5 (2) | Creating socket. Using TLS 1.2. | 2019-08-19 17:10:35.142 HTTPS connection ID:5 to historicaldata.sierrachart.com:443 for request ID:5 (2) | Connecting to IP: 88.99.0.216. | 2019-08-19 17:10:35.142 HD Request # 934 | Receiving historical Daily data for RTYU9 starting at 2019-08-16 | 2019-08-19 17:10:36.606 HD Request # 934 | Writing historical Daily data to the file RTYU9.dly | 2019-08-19 17:10:36.606 HD Request # 934 | Received 3 records from 2019-08-16 00:00:00 to 2019-08-19 00:00:00 (4.0 days) and wrote 2 records for RTYU9 | 2019-08-19 17:10:36.607 HD Request # 934 | Completion time: 1s | 2019-08-19 17:10:36.613 HD Request # 934 | Daily data download complete for RTYU9. Unique request ID: 933 | 2019-08-19 17:10:36.613 Removed historical data download ID 933 | 2019-08-19 17:10:36.613 RTYU9 Daily #8 | Reloading chart. | 2019-08-19 17:10:36.641 + Chart Data Loading Thread Stopwatch: 0.0021747 seconds. | 2019-08-19 17:10:36.646 RTYU9 Daily #8 | StartDateTimeForLoadingOrderFills: 2018-06-14 00:00:00 | 2019-08-19 17:10:36.655 HTTPS connection ID:5 to historicaldata.sierrachart.com:443 for request ID:5 (2) | Shutdown started. Waiting for graceful close. | 2019-08-19 17:10:36.884 RTYU9 Daily #8 | StartDateTimeForLoadingOrderFills: 2018-06-14 00:00:00 | 2019-08-19 17:10:36.988 HTTPS connection ID:5 to historicaldata.sierrachart.com:443 for request ID:5 (2) | Socket gracefully closed by remote side. | 2019-08-19 17:10:36.994 HTTPS connection ID:5 to historicaldata.sierrachart.com:443 for request ID:5 (2) | Closed. | 2019-08-19 17:10:36.994 Also sent for analysis as well. Date Time Of Last Edit: 2019-08-19 21:25:00
