Date/Time: Thu, 02 May 2024 06:00:39 +0000
unattended installation
View Count: 1053
[2013-12-08 15:21:01] |
Bob77 - Posts: 17 |
Hi, is it possible to install/update Sierra Chart in an unattended way by running the .exe installer and passing parameters for the install directory, whether to create a shortcut, install notepad++ and .NET? How would one do this? Thanks |
[2013-12-08 19:29:16] |
It is possible to specify the installation folder. Not the other parameters.
