Date/Time: Sun, 28 Apr 2024 15:53:03 +0000
Limited availability of modern indicators
View Count: 815
[2019-08-17 08:00:22] |
User871277 - Posts: 34 |
Why are modern indicators not available within Sierra Chart? Many of the options are somewhat "antique". |
[2019-08-17 09:51:02] |
Sierra Chart already has everything you need. Refer to: Technical Studies Reference https://www.sierrachart.com/index.php?page=doc/Contents.php#Charting Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2019-08-17 16:21:28] |
Chris_uk - Posts: 89 |
What do you mean by 'Modern Indicators'? Are you looking for something specific? Sierra is by far the most feature rich platform I have ever used, many competitors charge substantially more and don't even come close in terms of stability, functionality and support. If there is something you are trying to achieve It is more than likely possible, people on the support board are generally very helpful. I did find it a little hard to get used to initially, but ultimately It has turned out to be an absolute joy to use, I would never consider switching at this point. I use it for orderflow analysis, volume profiling, market profile. The DOM is highly customisable and can be configured to replicate pretty much anything currently on the market. Some examples: http://www.sierrachart.com/image.php?Image=1566057776943.png http://www.sierrachart.com/image.php?Image=156605912226.png http://www.sierrachart.com/image.php?Image=1566057921626.png http://www.sierrachart.com/image.php?Image=156605802835.png http://www.sierrachart.com/image.php?Image=15660581031.png http://www.sierrachart.com/image.php?Image=1566058153917.png Cheers Date Time Of Last Edit: 2019-08-17 16:25:49
[2019-08-18 13:54:35] |
NotIll - Posts: 118 |
You need to look past the outdated like menu's and such of SC and digg deeper in those same menu's. There is much to be made, and in the process, to be understood which will help you become a better trader too.
