Date/Time: Mon, 06 May 2024 05:24:24 +0000
Data feeds for Crypto dont work.
View Count: 1021
[2019-08-16 16:58:20] |
mikeindigo - Posts: 3 |
My data/trade feed for cryptocurrencies is blank, I have updated 3 times and restar tSierra 4 times and still the data feed is blank, please help me asap as this is the only reason I signed up to Sierra for this data feed. Thanks. |
[2019-08-16 17:38:53] |
This has been answered here: Data feed Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2019-08-16 19:19:27] |
Bloomberg FIX | Connecting. | 2019-08-16 19:17:32.505 Warning: Caught an exception during the processing of a timer event. Source: c_SierraChartMainApp::m_StartupControlTimer | 2019-08-16 19:17:32.509 * Now I cant even login anymore??? |
[2019-08-16 19:43:24] |
We will fix that exception issue but you are using the wrong service. Do not use Bloomberg. Set Global Settings >> Data/Trade Service Settings >> Service to Cryptocurrencies Data-DTC. After that restart Sierra Chart. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2019-08-16 19:43:41
