Date/Time: Thu, 02 May 2024 23:12:10 +0000
Buy Ask - Sell Bid buttons on the chart
View Count: 1634
[2019-08-15 15:06:41] |
User643046 - Posts: 14 |
Hello, How can I get buy ask / sell bid buttons when I am trading directly from the chart? See attached screen-shot to see what buttons do I have. FYI, I do see buy ask / sell bid in the DOM. tx |
BuyAskSellBid.JPG / V - Attached On 2019-08-15 15:06:10 UTC - Size: 41.84 KB - 345 views |
[2019-08-15 21:23:31] |
Those specific options (Buy Ask / Sell Bid) are not available in the Trading Shortcut Menu. In general, you would add/remove from that list according to the information here: Global Settings Menu: Customize Chart Trade Menu (Global Settings menu) You can, however, create keyboard shortcuts for those specific commands. Refer to the following, and they are under the Trading Keyboard Shortcuts section: Global Settings Menu: Customize Keyboard Shortcuts (Global Settings menu) You can also add Control Bar buttons for them as well which might be exactly what you are looking for: Control Bar Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
