Date/Time: Fri, 03 May 2024 07:15:15 +0000
[User Discussion] - Move Trade Activity Records from one Sim acct to another
View Count: 589
[2019-08-15 06:28:33] |
User629461 - Posts: 158 |
Hi - I want to move simulated Trade Activity records from Sim1 to Sim2 acct. Is it possible to transfer within the application or export and re-import the records under Sim1? Thanks |
[2019-08-15 09:45:06] |
You could export the data, clear the trade activity from the log and then modify the Trade Account in the file and then reimport.
Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2019-08-15 09:45:22
[2019-08-15 11:27:00] |
If Sim1 already has trade data in it, will importing overwrite exiting data in Sim1 or append? I do not want to overwrite existing data, I want to merge the 2 data sets.
[2019-08-16 05:06:24] |
Just tested and it does append - not overwrite. Thanks |
