Date/Time: Fri, 03 May 2024 11:19:12 +0000
TT stop orders
View Count: 598
[2019-08-14 15:03:30] |
User231363 - Posts: 31 |
I entered a trade using the DOM with the stop orders for the configuration set to "stop:stop", but I noticed on the Orders-and-Positions summary that those stop orders were Stop-Limit orders with both the stop and limit prices set to the same price. Why am I getting Stop-Limit orders when I specified "Stop" orders? If TT always uses Stop-Limit orders, how do I specify a different limit price offset for my exit stop orders than a stop-limit entry order? |
[2019-08-14 16:44:31] |
This is explained here: Order Types: Stop Orders on the CME You can use Stop-Limit orders instead: Order Types: Stop-Limit The documentation explains how to control the Limit offset. How are you submitting the order? Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
