Date/Time: Mon, 06 May 2024 00:22:33 +0000
Denali Exchange and market depth
View Count: 1104
[2019-08-14 14:52:59] |
User918738 - Posts: 31 |
Hi, I am trying out the denali exchange for my data feed. I am only seeing 100 levels of market depth for CL. Can i see more depth using denali or do i need to switch back to SC data for 300 levels of market depth? Thanks. |
[2019-08-14 15:04:45] |
SC Support - Posts: 1797 |
Refer to: Chart Settings: Maximum Market Depth Levels (Chart >> Chart Settings >> Market Depth menu) Also refer to this setting: Real-Time Exchange Data Feeds Available From Sierra Chart: Controlling Number of Market Depth Levels (Controlling Number of Market Depth Levels) |
[2019-08-14 16:42:28] |
Refer to the documentation here in regards to this: Real-Time Exchange Data Feeds Available From Sierra Chart: Controlling Number of Market Depth Levels Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2021-03-05 16:54:22] |
User263664 - Posts: 23 |
I also have Denali data feed and only 100 levels of depth. I confirmed that chart settings and data trade settings all have max depth 0. I even check the individual symbol settings and they also have max depth 0. What could be causing this issue?
[2021-03-05 17:15:02] |
John - SC Support - Posts: 31379 |
Go to Global Settings >> Sierra Chart Server Settings. On that page is an entry for Max Depth Levels. Make sure that is set to 0.
[2021-03-05 17:23:39] |
Thank you! That did it.
