Date/Time: Mon, 06 May 2024 16:45:29 +0000
Daily High and Low line on Chart DOM
View Count: 573
[2019-08-14 13:44:11] |
User98657 - Posts: 304 |
Can you tell me what controls the Daily High and Low bars on the Chart DOM? It doesn't seem to be the session start time. |
[2019-08-16 17:41:48] |
This is controlled by the exchange. It comes direct from the market data feed.
Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2019-08-16 17:41:55
