Date/Time: Fri, 03 May 2024 02:28:09 +0000
How to remove a pop up?
View Count: 618
[2019-08-14 12:36:22] |
User348929 - Posts: 16 |
Hi , On the Dom, I trade with attached orders. When i want to move my TP (take profit), i always have a pop up confirmation first. How can i get rid of it? Thanks for your help, Corinne |
[2019-08-14 16:55:09] |
You need to disable the order modification confirmations. Refer to: Basic Trading and the Trade Window: Main/C >> Menu >> Order Confirmations (chart specific) Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2019-08-14 16:56:22
