Date/Time: Sat, 04 May 2024 19:30:11 +0000
Ehlers smoothed adaptive momentum indicator request
View Count: 1608
[2019-08-14 05:42:14] |
User954185 - Posts: 7 |
Hi, Thank you very much for your hard work sierra chart engineering. Would like to request this indicator for Sierra Chart. If it is possible and not too difficult. Date Time Of Last Edit: 2019-08-14 05:42:33
[2019-08-14 16:22:08] |
We will look into this.
[2019-08-15 18:07:34] |
SC Support Tom - Posts: 450 |
Hello, I am looking at two scripts for this indicator (written in Pine Script for Tradingview). I should be able to come up with an ACSIL version by Monday. https://www.tradingview.com/script/PP4FmEA7-Ehlers-Smoothed-Adaptive-Momentum/ https://www.tradingview.com/script/vIE6adMm-Ehlers-Smoothed-Adaptive-Momentum-LazyBear/ |
[2019-08-16 00:49:03] |
I would prefer the first one because it has more settings that i can adjust and customize. I use that one personally. https://www.tradingview.com/script/PP4FmEA7-Ehlers-Smoothed-Adaptive-Momentum/ Thank you again! Date Time Of Last Edit: 2019-08-16 01:07:07
[2019-08-16 21:03:57] |
OK I am working on that one.
[2019-08-23 23:29:02] |
Hi Tom, Can I kindly check in with you on this? Thank you very much, Leon |
[2019-08-26 18:26:18] |
Hello, I apologize for the delay. I had some trouble finding what I needed in the Tradingview documentation to make an accurate translation. I am nearly finished. Please allow another day or two for me to complete testing and submit to Sierra Chart Engineering.
[2019-09-10 17:28:09] |
Hello again. I just want to let you know that we are still working on this. It has required a bit more research than was originally anticipated. I will let you know here when it is finished.
[2019-09-13 10:20:04] |
OH okay, Thank you. This indicator is in ehler's book cybernetic analysis for stock and futures. Do you want a copy? if it would help. It has code in EFS. I think you could find a copy online, but let me know.
[2019-09-13 19:12:05] |
Hi, I just downloaded a copy of the book. I already have Ehlers' book called Rocket Science for Traders, but this indicator is not in that one. Thanks for the tip.
[2022-06-07 05:06:28] |
This is done. It will be available in the next release.
