Date/Time: Sat, 04 May 2024 03:27:25 +0000
Chart
View Count: 584
[2019-08-13 18:50:18] |
Jeffrey S - Posts: 42 |
How can I set up a daily chart on the ESminis that is not manipulated by the rollovers?
[2019-08-13 22:13:58] |
We are not really understanding the question. Do you mean a chart that is not back adjusted?
[2019-08-13 22:37:37] |
I apologize for the lack of clarity, but the answer is yes. A chart that is not back adjusted. Thanks.
[2019-08-14 03:37:35] |
Ok, so you just follow the instructions here: Continuous Futures Contract Charts And do not choose one of the back adjusted Continuous Contract options. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
