Date/Time: Tue, 07 May 2024 06:17:20 +0000
tool set fine size with DRAWING_HORIZONTAL_RAY
View Count: 616
[2019-08-13 17:41:09] |
onnb - Posts: 661 |
We are drawing DRAWING_HORIZONTAL_RAY with ACSIL See sample code below. The text draws fine, I don't see the font size changing - is that expected? tool.Text = SCString().Format("%i %02i:%02i:%02i %s", vol, dt.GetHour(), dt.GetMinute(), dt.GetSecond(), sc.FormatGraphValue(tool.BeginValue, sc.BaseGraphValueFormat).GetChars()); tool.TextAlignment = DT_RIGHT | alignment; tool.FontSize = in_font_size.GetInt(); Date Time Of Last Edit: 2019-08-13 17:41:25
[2019-08-16 19:37:04] |
Yes, the font size for that drawing tool will use the Global Chart Drawing Font: Chart Drawing Tools: Global Chart Drawing Font (Global Settings >> Tool Settings >> General >> Drawing Font) Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2019-08-16 19:37:23
