Date/Time: Tue, 07 May 2024 08:18:33 +0000
up/dn tick difference bars?
View Count: 738
[2019-08-13 05:21:50] |
User19165 - Posts: 346 |
We have 3 different types of cummulative delta bars. Could these be replicated into the their equivalent "difference bars" indicators? In thinner markets, I find up/dn tick to be a much more insightful measure than ask/bid volume.
[2019-08-13 07:31:29] |
Ackin - Posts: 1865 |
Hi, check this post with similar quest: nonCumulative |
[2019-08-14 06:38:11] |
Thanks for the reply Ackin. Please don't take offense, but I do not wish to install any dlls on my trading platform from parties that I do not know. I still think my initial post is reasonable and would add consistency to the built-in indicator suite. |
[2019-08-14 09:53:28] |
All right, I get it. Good luck ;) |
[2019-08-17 09:29:49] |
We will add a Up/Down Volume Difference Bars study.
