Date/Time: Tue, 07 May 2024 14:29:12 +0000
Daily PnL not indicating correctly
View Count: 1694
[2019-08-12 20:38:16] |
User703334 - Posts: 59 |
I'm having two issues with DAILY PnL: 1. The Trade Window DPL box will fluctuate even though I have no trade on or even long after I exited a trade. I.e., my last trade today was this morning after which DPL box in the Trade window indicated 9.25 points. After placing no further trades, a few hours later I noticed DPL indicated 16.5 points. 5 minutes later it read 9.25 Points (no trade taken to reduce DPL). Still reads 9.25 points. Why does it fluctuate when no trades are effecting in real time? 2. TRADE>TRADE ORDERS AND POSITIONS>BALANCE TAB (not Balance in Menu line, BALANCE TAB). When I open the BALANCE TAB it shows the following: TRADE ACCOUNT: 842981 CASH BALANCE: 2666.91 (which is correct) AVAILABLE FUNDS FOR NEW POSITIONS: 0.00 (incorrect) MARGIN: 0 (incorrect) ACCOUNT VALUE: 0 (incorrect) OPEN POSITIONS: 0 (correct) DAILY PROFIT/LOSS 0 (incorrect...I verified with AMP Futures trade desk my profit this morning was $82.50) How do I get the BALANCE TAB spreadsheet to show correct values? |
[2019-08-12 22:59:28] |
Refer to this page: Help With Daily Profit/Loss Value Why does it fluctuate when no trades are effecting in real time?
If there is not a Position currently for the Symbol and Trade Account the Trade Window is for, it should not change on current versions of Sierra Chart. However, it will still likely be wrong until you understand how the calculation is done and adjust the starting time for the fills, but it should stay at a fixed value. Is it prefixed with DPL or NPL?Read through the documentation we linked to above in regards to all of this. AVAILABLE FUNDS FOR NEW POSITIONS: 0.00 (incorrect) We will add support for this in the next release when using CQG FIX.Refer to the documentation here for the Balance tab fields: Trading Information Windows: Trade Account Monitor Field Descriptions Some of them are not supported with the service you are using. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2019-08-12 23:00:59
[2019-08-13 23:25:13] |
To answer your question it is prefixed with DPL, not NPL. I read through the link you attached, but I did not read how to fix the TRADE>TRADE ORDERS AND POSITIONS>BALANCE TAB issue. - see attached file for pic of how that BALANCE TAB read at the end of today's trading day. Is this correctable? |
Trade Orders and Positions 8-13.JPG / V - Attached On 2019-08-13 23:23:57 UTC - Size: 150.2 KB - 326 views Attachment Deleted. |
[2019-08-14 16:41:05] |
The account value cannot be changed. That comes from the CQG system. It looks as though you are you now using the CQG Web API Service? Use prerelease 1974 which will be releasing in about 20 minutes, and then use the CQG FIX Trading service instead. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2019-08-14 16:41:33
[2019-08-14 20:29:14] |
No, I'm actually using and have been using the CQG FIX service. Web API does not work for me at all because I trade the E-mini MICROS from the chart using the CHART SETTINGS>TRADE AND CURRENT QUOTE SYMBOL> USE AS TRADE SYMBOL
[2019-08-15 09:48:42] |
It is fine to use CQG FIX but regarding the problem you mention with the CQG Web API, refer to: CQG Trading Platform Service: Solving Contract ID Mapping Error when Submitting Order We want you to use prerelease 1974. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2019-08-15 09:49:09
[2019-08-18 19:18:45] |
Ok, I just downloaded pre-release 1974 (1976) and have read through the link you provided. Will keep you posted. Thank you
