Date/Time: Sun, 05 May 2024 12:02:05 +0000
Request - New type of Drawstyle (solved)
View Count: 962
[2019-08-11 09:24:12] |
Ackin - Posts: 1865 |
to Sierra Chart Engineering) I try it again after 2 months. Please consider to add: "Point Variable Size with Border" Primary color - fill Secondary color - border Thanks |
[2019-08-11 23:54:20] |
Chris_uk - Posts: 89 |
+1 Thanks |
[2019-08-12 00:26:00] |
We will get this added.
[2019-08-12 00:56:59] |
Acro - Posts: 436 |
It would be amazing if the attributes of this draw style could be used to further improve the dots drawn by the Large Volume Trade Indicator
[2019-08-20 12:00:29] |
Acro) Yes, often objects overlap and can only be solved on a larger scale axis. The border would make everything visible. |
[2019-08-20 18:51:08] |
+1 Regarding the suggestion Acro made.
[2019-08-24 22:20:54] |
We will get this added. Any news? |
[2019-08-29 06:09:26] |
User590016 - Posts: 50 |
@Sierra Charts Engineers: Any update about the release of Akins request? "Point Variable Size with Border" Primary color - fill Secondary color - border " Is it for very soon? |
[2019-10-16 23:57:39] |
it's very good - thank you ... |
[2019-10-17 07:33:48] |
This is good.
