Date/Time: Sat, 01 Feb 2025 23:01:56 +0000
depth question with new version and data
View Count: 850
[2019-08-10 23:57:43] |
zippyzip - Posts: 293 |
can you please bring back the option to select how many levels we wish to use please , i run few programs that rely on data points of set levels not whole dom , and looking forward to the full dom for crude that cqg offers through denali , thanks
[2019-08-11 06:33:13] |
This is already the case: Chart Settings: Maximum Market Depth Levels (Chart >> Chart Settings >> Market Depth menu) Also refer to this setting: Real-Time Exchange Data Feeds Available From Sierra Chart: Controlling Number of Market Depth Levels (Controlling Number of Market Depth Levels) Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2019-08-11 06:33:52
[2019-08-11 19:25:23] |
yes im aware but was looking to use it based on the study with having full depth and taking data from sections , this makes it alot more difficult with out older setting , thanks
[2019-08-11 19:37:04] |
so for example i have full depth on chart and i want to see the liquidity providers working 50 ticks away , i was able to do this with old study settings , now i cant
[2019-08-11 22:32:26] |
It sounds like you are referring to Bid and Ask Depth Bars and you want to control the number of market depth levels used in the calculation for that study. This is supported now in the latest prerelease, 1972, with a new chart setting: Chart >> Chart Settings >> Advanced Settings 3 >> Number of Levels for Bid/Ask Depth Calculations. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2019-08-12 10:39:05] |
yes i understand but i want full depth on chart with ability to see levels of depth with study , not chart setting
[2019-08-12 16:40:10] |
There are two settings. This one controls the number of levels of depth displayed in various areas of the chart that support depth: Chart Settings: Maximum Market Depth Levels (Chart >> Chart Settings >> Market Depth menu) This one controls the number of levels used in the calculation with Bid and Ask Depth Bars: https://www.sierrachart.com/index.php?page=doc/ChartSettings.html#NumberOfLevelsForBidAskCalculations Make sure you are on the latest prerelease for proper support for the last one. Although the current version may have it implemented as well. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2019-08-12 16:40:45
