Date/Time: Fri, 18 Sep 2026 02:09:31 +0000
Unable to connect when using server 5 as the primary server
View Count: 906
[2019-08-10 03:39:26]
User372626 - Posts: 59
Reading Internal Order ID file. | 2019-08-09 22:32:42.282
Reading Trade Orders file. | 2019-08-09 22:32:42.355
Reading Trade Positions file. | 2019-08-09 22:32:42.358
Reading Account Balance file. | 2019-08-09 22:32:42.361
UDPListener (1432). Port 22904 | Listening on UDP port 22904. | 2019-08-09 22:32:42.382
Software version: 1962 64-bit | 2019-08-09 22:32:42.382
Usage end date: 2020-07-07 | 2019-08-09 22:32:42.382
Enabled for: Advanced Features 2. | 2019-08-09 22:32:42.382
Enabled for: Sierra Chart Historical Data Service. | 2019-08-09 22:32:42.382
Enabled for: Sierra Chart Bundled Real-Time Exchange Data Feed. | 2019-08-09 22:32:42.382
Enabled for exchange2: CME | 2019-08-09 22:32:42.382
Allow Support for Sierra Chart Data Feeds is enabled. | 2019-08-09 22:32:42.382
Current selected Data/Trading service: SC Futures Order Routing/Data | 2019-08-09 22:32:42.382
Custom symbol settings values: disabled | 2019-08-09 22:32:42.382
Chart Update Interval: 500 | 2019-08-09 22:32:42.382
Intraday Data Storage Time Unit: 0 | 2019-08-09 22:32:42.382
Time Zone: -05:00:00 (CST-06CDT+01,M3.2.0/02:00,M11.1.0/02:00) | 2019-08-09 22:32:42.382
2019-08-10 11:32:42 Local computer time | 2019-08-09 22:32:42.382
2019-08-10 03:32:42 Local computer time in UTC | 2019-08-09 22:32:42.382
2019-08-09 22:32:42 Local computer time in SC Time Zone | 2019-08-09 22:32:42.382
2019-08-10 03:32:44 Server time in UTC | 2019-08-09 22:32:42.382
Local computer UTC time and Server UTC time difference: 2 seconds. | 2019-08-09 22:32:42.382
Program path: C:\SierraChart\ | 2019-08-09 22:32:42.382
Data Files path: C:\SierraChart\Data\ | 2019-08-09 22:32:42.382
OS Version Number: 10.0 | 2019-08-09 22:32:42.383
Locale Setting: C | 2019-08-09 22:32:42.383
DLLs: UserContributedStudies.dll, UserContributedStudies_64.dll | 2019-08-09 22:32:42.383
Created the DTC Protocol server. | 2019-08-09 22:32:42.383
DTC Protocol Server listening on port 11099. | 2019-08-09 22:32:42.384
Created the DTC Protocol historical data server. | 2019-08-09 22:32:42.384
HD Server Manager | Listening on port 11098 | 2019-08-09 22:32:42.385
Checking for new symbol settings. Requested symbol settings MD5 for service code sc_futures.dtc.trading. Request ID: 1. | 2019-08-09 22:32:42.385
HTTPS connection ID:1 to login.sierrachart.com:443 for request ID:1 (1) | Shutdown started. Waiting for graceful close. | 2019-08-09 22:32:42.393
Received 5 login tokens. | 2019-08-09 22:32:43.123
HTTPS connection ID:1 to login.sierrachart.com:443 for request ID:1 (1) | Socket gracefully closed by remote side. | 2019-08-09 22:32:43.209
HTTPS connection ID:1 to login.sierrachart.com:443 for request ID:1 (1) | Closed. | 2019-08-09 22:32:43.209
HTTPS connection ID:2 to www.sierrachart.com:443 for request ID:2 (2) | Shutdown started. Waiting for graceful close. | 2019-08-09 22:32:43.384
HTTPS connection ID:2 to www.sierrachart.com:443 for request ID:2 (2) | Socket gracefully closed by remote side. | 2019-08-09 22:32:43.599
HTTPS connection ID:2 to www.sierrachart.com:443 for request ID:2 (2) | Closed. | 2019-08-09 22:32:43.599
Symbol settings MD5 received. Request ID: 1. | 2019-08-09 22:32:43.909
Symbol settings are up-to-date for sc_futures.dtc.trading. | 2019-08-09 22:32:43.909
HTTPS connection ID:1 to www.sierrachart.com:443 for request ID:1 (1) | Creating socket. Using TLS 1.2. | 2019-08-09 22:32:44.383
HTTPS connection ID:1 to www.sierrachart.com:443 for request ID:1 (1) | Connecting to IP: 46.4.97.203. | 2019-08-09 22:32:44.383
HTTPS connection ID:1 to www.sierrachart.com:443 for request ID:1 (1) | Shutdown started. Waiting for graceful close. | 2019-08-09 22:32:47.505
HTTPS connection ID:1 to www.sierrachart.com:443 for request ID:1 (1) | Socket gracefully closed by remote side. | 2019-08-09 22:32:47.730
HTTPS connection ID:1 to www.sierrachart.com:443 for request ID:1 (1) | Closed. | 2019-08-09 22:32:47.731
SC Futures Order Routing/Data | Connecting to the server futurestrading2.sierracharts.com. Port 11098 | 2019-08-09 22:32:50.265
DTC Client socket (1) | Creating socket. Using TLS 1.2. | 2019-08-09 22:32:50.952
DTC Client socket (1) | Connecting to IP: 208.185.224.129. | 2019-08-09 22:32:50.953
SC Futures Order Routing/Data | Connected to server. | 2019-08-09 22:32:51.247
SC Futures Order Routing/Data | Starting socket receive thread. | 2019-08-09 22:32:51.247
SC Futures Order Routing/Data | Sending encoding request to server: Binary VLS | 2019-08-09 22:32:51.247
SC Futures Order Routing/Data | Setting DTC encoding to Binary VLS | 2019-08-09 22:32:52.122
SC Futures Order Routing/Data | Sending logon request message. | 2019-08-09 22:32:52.122
SC Futures Order Routing/Data | Received logon response. | 2019-08-09 22:32:52.401
SC Futures Order Routing/Data | Server Name: SC DTC Server. | 2019-08-09 22:32:52.401
SC Futures Order Routing/Data | Server protocol version: 8. Client protocol version: 8 | 2019-08-09 22:32:52.401
SC Futures Order Routing/Data | Successfully connected. Connected to SC DTC Protocol server. Service=trading_technologies.trading|SymbolSettings=trading_technologies_v2.trading. | 2019-08-09 22:32:52.401
SC Futures Order Routing/Data | Trading is supported. | 2019-08-09 22:32:52.401
SC Futures Order Routing/Data | Order cancel and replace is supported. | 2019-08-09 22:32:52.401
SC Futures Order Routing/Data | OCO Orders supported. | 2019-08-09 22:32:52.401
SC Futures Order Routing/Data | Bracket Orders supported. | 2019-08-09 22:32:52.401
SC Futures Order Routing/Data | Connected to data and trading server. | 2019-08-09 22:32:52.401
File >> Disconnect selected. | 2019-08-09 22:33:27.019
SC Futures Order Routing/Data | Disconnected. | 2019-08-09 22:33:27.019
DTC Client socket (1) | Shutdown started. Waiting for graceful close. | 2019-08-09 22:33:27.019
DTC Client socket (1) | Socket gracefully closed by remote side. | 2019-08-09 22:33:27.309
DTC Client socket (1) | Closed. | 2019-08-09 22:33:27.309
SC Futures Order Routing/Data | Connecting to the server futurestrading5.sierracharts.com. Port 443 | 2019-08-09 22:33:35.185
DTC Client socket (1) | Creating socket. Using TLS 1.2. | 2019-08-09 22:33:35.277
DTC Client socket (1) | Connecting to IP: 209.58.163.194. | 2019-08-09 22:33:35.277
SC Futures Order Routing/Data | Connected to server. | 2019-08-09 22:33:35.572
SC Futures Order Routing/Data | Starting socket receive thread. | 2019-08-09 22:33:35.572
SC Futures Order Routing/Data | Sending encoding request to server: Binary VLS | 2019-08-09 22:33:35.572
Service connection timed out. Will disconnect and retry. | 2019-08-09 22:34:35.185 *
Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2019-08-09 22:34:35.185
Select 'File >> Disconnect' to prevent further connection attempts. | 2019-08-09 22:34:35.185
DTC Client socket (1) | Write in progress. Shutdown being delayed. | 2019-08-09 22:34:35.228
SC Futures Order Routing/Data | Disconnected. | 2019-08-09 22:34:35.229
Will reconnect to the server in 1.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2019-08-09 22:34:35.229
SC Futures Order Routing/Data | Connecting to the server futurestrading5.sierracharts.com. Port 443 | 2019-08-09 22:34:36.238
DTC Client socket (2) | Creating socket. Using TLS 1.2. | 2019-08-09 22:34:36.241
DTC Client socket (2) | Connecting to IP: 209.58.163.194. | 2019-08-09 22:34:36.241
SC Futures Order Routing/Data | Connected to server. | 2019-08-09 22:34:37.550
SC Futures Order Routing/Data | Starting socket receive thread. | 2019-08-09 22:34:37.550
SC Futures Order Routing/Data | Sending encoding request to server: Binary VLS | 2019-08-09 22:34:37.550
[2019-08-10 22:50:17]
Can you contact your Internet Service Provider and ask them why there is a connectivity issue to the following IP and port:
IP: 209.58.163.194
Port 443
We thought the Singapore server would help users in China but clearly it is not. So we would have to find another location. But we also are concerned about if we find a location that works, what kind of connectivity problem there is going to be between that server and the TT server.
Date Time Of Last Edit: 2019-08-10 22:50:23
