Date/Time: Thu, 02 May 2024 20:12:44 +0000
Volume By Price Study 'Outline'
View Count: 794
[2019-08-08 03:02:11] |
User12167 - Posts: 16 |
Hi, Would it be possible to have this study updated with an option to draw BOTH the "Hologram" and "Filled Volume Bars"? This creates a very nice outline effect which has a big visual difference. I currently have to run two almost identical studies to achieve this: one with each draw method. As you can imagine this is not efficient. Thank you |
[2019-08-12 13:36:46] |
Bump
[2019-08-15 21:24:17] |
Please advise, thanks
[2019-08-20 17:03:51] |
[2019-08-21 06:46:09] |
Refer to: Notice: Suggestions (Currently not accepting) Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
