Date/Time: Fri, 03 May 2024 10:36:25 +0000
Start/End Times
View Count: 1115
[2013-12-06 16:38:06] |
sbeltran - Posts: 8 |
EX: The NQ I have a start time of 09:30:00 with an end time of 09:29:59. Problem is that when Friday rolls around the chart stops printing at 09:30:00. The reason for the 24 hour spread is to get the premarket data also. I also have the 6E set with a start time of 03:00:00 end time of 02:59:59, same thing, on Friday charts stop printing at 13:00:00.. Please advise
[2013-12-06 18:38:44] |
The settings seem fine and should not prevent the chart from updating on Friday. That makes no sense at all. Refer to help topic 3 here when you have a problem with the chart not updating: Http://www.sierrachart.com/index.php?l=doc/helpdetails3.html Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
