Date/Time: Sun, 28 Apr 2024 10:27:33 +0000
Need Rithmic settings page
View Count: 1240
[2013-12-06 09:23:22] |
Provide us the connection details and we can add them. This is the easiest way. It is doubtful we would add a user interface with all of these settings fields. Also, the bridge program that we use to connect to Rithmic is open source. It can be found at the bottom of the page here: http://www.sierrachart.com/index.php?l=doc/doc_GeneralDataTradeServiceProtocol.php#OpenSourceBridge However, currently the zip file there is a little old. It does not have all of the latest changes. So you would not be able to use it with your changes. It is easiest if you just give us the settings. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2013-12-06 09:23:53
[2013-12-06 15:32:34] |
Sierra Chart - Max - Posts: 5597 |
When uploading the files, you have an option to make them private or you can send the files to support (at) sierrachart.com
Sierra Chart Support Date Time Of Last Edit: 2013-12-06 15:33:24
