Date/Time: Fri, 18 Jul 2025 23:54:51 +0000
different algorithm for different time frame
View Count: 1403
[2013-12-05 18:46:37]
toews&kane - Posts: 209
As in title, is there an option to use a different algorithm for different time frame, say between the hours of 17:00-8:00 and then a different algorithm in the normal day time frame?
Cheers
[2013-12-05 20:50:19]
this is for spreadsheet trading
[2013-12-05 21:05:52]
Sawtooth - Posts: 4244
You would need to include the time frame conditions in your formulas. Here's one way:
Put these in the following cells:
H3:
=AND(J41-INT(J41)>=TIMEVALUE("08:00:00"),J41-INT(J41)<TIMEVALUE("17:00:00"))
H4:
your conditions specific to the RTH time frame.
H5:
=OR(J41-INT(J41)>=TIMEVALUE("17:00:00"),J41-INT(J41)<TIMEVALUE("08:00:00"))
H6:
your conditions specific to the Globex time frame.
(Use OR if the timeframe spans midnight, use AND if it does not.)
Then include absolute references to $H$3, $H$4 and $H$5, $H$6 using IF statements in your K3-N3 formulas:
=AND(YourConditionsNotSpecificToTimeframe,IF($H$3,$H$4,IF($H$5,$H$6,FALSE)))
Instead of separating things in column H, you could concatenate everything in your K3-N3 formulas.
Date Time Of Last Edit: 2013-12-06 13:21:33
