Date/Time: Thu, 02 May 2024 10:41:37 +0000
Tool to measure the exact number of pips(forex)
View Count: 1870
[2013-12-05 16:07:13] |
User59474 - Posts: 13 |
Hi, Is it a tool to measure the number of pips between two price? I found the Risk Ratio tool, but it isn't quit what i'm seeking for, so if you have a quick way to do that i'll be glad to know. Thanks |
[2013-12-05 16:19:43] |
ganz - Posts: 1048 |
User59474 Tools -> Chart Calculator |
[2013-12-06 03:12:55] |
Here is the documentation for the Chart Calculator tool: http://www.sierrachart.com/index.php?l=doc/doc_Tools.html#ChartCalculator Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
