Date/Time: Thu, 02 May 2024 20:54:36 +0000
TPO fields of data in the Chart Values window
View Count: 652
[2019-07-30 06:24:11] |
nicktrader - Posts: 665 |
Is it possible to add: - TPO VA Range Width - Volume VA Range Width |
[2019-07-30 09:32:27] |
Yes we can add these. If you just mean the difference between the Value Area High and Low.
[2019-07-30 10:00:10] |
Yes I do :-)) Many txs |
[2019-08-03 03:55:36] |
Just asking. What do you think when will it be available?
[2019-08-19 05:51:54] |
Is there any chance?
TPO Chart Values.png / V - Attached On 2019-08-19 05:49:40 UTC - Size: 215.01 KB - 218 views |
[2019-08-19 06:23:17] |
These will be added to the next release.
