Date/Time: Sat, 01 Feb 2025 17:01:17 +0000
Access to live data feed and connection to TD ameritrade
View Count: 1002
[2019-07-26 15:07:27]
Oxcap - Posts: 72
I just signed up and paid for SC with data feed. I'm having issues connecting to real time data. Can someone please help with getting set up to real time data and making sure im connected to my broker TD ameritrade and/or if I'm set up correctly.
Im currently signed up for package 5 with denali exchange data feed. I also activated CME w/ market depth for non professional. Supported brokerage is TD Ameritrade w/ funds in account.
Please advise.
Thanks,
HN
[2019-07-26 18:18:53]
John - SC Support - Posts: 37656
Everything looks good in terms of what you have signed up for on our end. Be sure you have followed through the Setup Instructions for using TD Ameritrade here:
https://www.sierrachart.com/index.php?page=doc/AmeriTrade.php#SetupInstructions
If you have already done that, or you have completed it, then check that you have the option for Global Settings >> Data/Trade Service Settings >> Allow Support for Sierra Chart Data Feeds enabled (checked). Refer to the documentation here for this:
https://www.sierrachart.com/index.php?page=doc/SierraChartRealTimeFuturesStockDataFeed.php#IntegrationWithTradingServices
If you still have problems after this, then open a chart with one symbol that you are having an issue with and then paste your message log to this thread following these instructions:
https://www.sierrachart.com/index.php?page=PostingInformation.php#MessageLog
Date Time Of Last Edit: 2019-07-26 18:25:52
[2019-07-26 18:28:34]
Oxcap - Posts: 72
Reading Internal Order ID file. | 2019-07-25 20:37:18.480
Reading Trade Orders file. | 2019-07-25 20:37:18.620
Reading Trade Positions file. | 2019-07-25 20:37:18.625
Reading Account Balance file. | 2019-07-25 20:37:18.629
UDPListener (1340). Port 22904 | Listening on UDP port 22904. | 2019-07-25 20:37:18.664
Software version: 1941 64-bit | 2019-07-25 20:37:18.664
Usage end date: 2019-10-25 | 2019-07-25 20:37:18.664
Enabled for: Advanced Features. | 2019-07-25 20:37:18.664
Enabled for: Advanced Features 2. | 2019-07-25 20:37:18.664
Enabled for: Sierra Chart Historical Data Service. | 2019-07-25 20:37:18.664
Enabled for: Sierra Chart Bundled Real-Time Exchange Data Feed. | 2019-07-25 20:37:18.664
Allow Support for Sierra Chart Data Feeds is enabled. | 2019-07-25 20:37:18.664
Current selected Data/Trading service: TD Ameritrade | 2019-07-25 20:37:18.664
Custom symbol settings values: enabled | 2019-07-25 20:37:18.664
Chart Update Interval: 500 | 2019-07-25 20:37:18.664
Intraday Data Storage Time Unit: 0 | 2019-07-25 20:37:18.664
Time Zone: -07:00:00 (PST-08PDT+01,M3.2.0/02:00,M11.1.0/02:00) | 2019-07-25 20:37:18.664
2019-07-25 20:37:18 Local computer time | 2019-07-25 20:37:18.664
2019-07-26 03:37:18 Local computer time in UTC | 2019-07-25 20:37:18.664
2019-07-25 20:37:18 Local computer time in SC Time Zone | 2019-07-25 20:37:18.664
2019-07-26 03:37:20 Server time in UTC | 2019-07-25 20:37:18.664
Local computer UTC time and Server UTC time difference: 2 seconds. | 2019-07-25 20:37:18.664
Program path: C:\SierraChart\ | 2019-07-25 20:37:18.664
Data Files path: C:\SierraChart\Data\ | 2019-07-25 20:37:18.664
OS Version Number: 10.0 | 2019-07-25 20:37:18.664
Locale Setting: C | 2019-07-25 20:37:18.664
DLLs: UserContributedStudies.dll, UserContributedStudies_64.dll | 2019-07-25 20:37:18.665
HTTPS connection ID:1 to www.sierrachart.com:443 for request ID:1 (4) | Creating socket. Using TLS 1.2. | 2019-07-25 20:37:18.666
Checking for new symbol settings. Requested symbol settings MD5 for service code tda. Request ID: 1. | 2019-07-25 20:37:18.666
HTTPS connection ID:1 to www.sierrachart.com:443 for request ID:1 (4) | Connecting to IP: 46.4.97.203. | 2019-07-25 20:37:18.666
HTTPS connection ID:1 to login.sierrachart.com:443 for request ID:1 (1) | Shutdown started. Waiting for graceful close. | 2019-07-25 20:37:18.688
HTTPS connection ID:1 to login.sierrachart.com:443 for request ID:1 (1) | Socket gracefully closed by remote side. | 2019-07-25 20:37:18.854
HTTPS connection ID:1 to login.sierrachart.com:443 for request ID:1 (1) | Closed. | 2019-07-25 20:37:18.854
Received 5 login tokens. | 2019-07-25 20:37:19.235
Symbol settings MD5 received. Request ID: 1. | 2019-07-25 20:37:19.356
Symbol settings are up-to-date for tda. | 2019-07-25 20:37:19.356
HTTPS connection ID:2 to www.sierrachart.com:443 for request ID:2 (2) | Shutdown started. Waiting for graceful close. | 2019-07-25 20:37:19.485
HTTPS connection ID:1 to www.sierrachart.com:443 for request ID:1 (4) | Shutdown started. Waiting for graceful close. | 2019-07-25 20:37:19.599
HTTPS connection ID:2 to www.sierrachart.com:443 for request ID:2 (2) | Socket gracefully closed by remote side. | 2019-07-25 20:37:19.647
HTTPS connection ID:2 to www.sierrachart.com:443 for request ID:2 (2) | Closed. | 2019-07-25 20:37:19.647
HTTPS connection ID:1 to www.sierrachart.com:443 for request ID:1 (4) | Socket gracefully closed by remote side. | 2019-07-25 20:37:19.754
HTTPS connection ID:1 to www.sierrachart.com:443 for request ID:1 (4) | Closed. | 2019-07-25 20:37:19.755
HTTPS connection ID:1 to www.sierrachart.com:443 for request ID:1 (1) | Creating socket. Using TLS 1.2. | 2019-07-25 20:37:20.663
HTTPS connection ID:1 to www.sierrachart.com:443 for request ID:1 (1) | Connecting to IP: 46.4.97.203. | 2019-07-25 20:37:20.663
HTTPS connection ID:1 to www.sierrachart.com:443 for request ID:1 (1) | Shutdown started. Waiting for graceful close. | 2019-07-25 20:37:21.661
HTTPS connection ID:1 to www.sierrachart.com:443 for request ID:1 (1) | Socket gracefully closed by remote side. | 2019-07-25 20:37:21.830
HTTPS connection ID:1 to www.sierrachart.com:443 for request ID:1 (1) | Closed. | 2019-07-25 20:37:21.830
TD Ameritrade | Connecting. | 2019-07-25 20:37:22.976
TD Ameritrade | Logging in. (Step 1 of 3) | 2019-07-25 20:37:22.976
HTTPS connection ID:1 to apis.tdameritrade.com:443 for request ID:1 (1) | Creating socket. Using TLS 1.2. | 2019-07-25 20:37:22.993
HTTPS connection ID:1 to apis.tdameritrade.com:443 for request ID:1 (1) | Connecting to IP: 198.200.171.201. | 2019-07-25 20:37:22.993
TD Ameritrade | Authorized for streamer data. Account: 86*** | 2019-07-25 20:37:23.483
TD Ameritrade | Getting streamer information. (Step 2 of 3) | 2019-07-25 20:37:23.483
HTTPS connection ID:2 to apis.tdameritrade.com:443 for request ID:2 (2) | Creating socket. Using TLS 1.2. | 2019-07-25 20:37:23.483
HTTPS connection ID:2 to apis.tdameritrade.com:443 for request ID:2 (2) | Connecting to IP: 198.200.171.201. | 2019-07-25 20:37:23.483
TD Ameritrade | Requesting message key for account activity streamer (Step 3 of 3) | 2019-07-25 20:37:23.706
HTTPS connection ID:3 to apis.tdameritrade.com:443 for request ID:3 (3) | Creating socket. Using TLS 1.2. | 2019-07-25 20:37:23.706
HTTPS connection ID:3 to apis.tdameritrade.com:443 for request ID:3 (3) | Connecting to IP: 198.200.171.201. | 2019-07-25 20:37:23.706
HTTPS connection ID:1 to apis.tdameritrade.com:443 for request ID:1 (1) | Shutdown started. Waiting for graceful close. | 2019-07-25 20:37:23.723
HTTPS connection ID:1 to apis.tdameritrade.com:443 for request ID:1 (1) | Socket gracefully closed by remote side. | 2019-07-25 20:37:23.772
HTTPS connection ID:1 to apis.tdameritrade.com:443 for request ID:1 (1) | Closed. | 2019-07-25 20:37:23.772
TD Ameritrade | Requesting account balance data. Connection will be complete once received. | 2019-07-25 20:37:23.935
HTTPS connection ID:4 to apis.tdameritrade.com:443 for request ID:4 (1) | Creating socket. Using TLS 1.2. | 2019-07-25 20:37:23.935
HTTPS connection ID:4 to apis.tdameritrade.com:443 for request ID:4 (1) | Connecting to IP: 198.200.171.201. | 2019-07-25 20:37:23.935
HTTPS connection ID:5 to apis.tdameritrade.com:443 for request ID:5 (4) | Creating socket. Using TLS 1.2. | 2019-07-25 20:37:23.935
HTTPS connection ID:5 to apis.tdameritrade.com:443 for request ID:5 (4) | Connecting to IP: 198.200.171.201. | 2019-07-25 20:37:23.936
HTTPS connection ID:2 to apis.tdameritrade.com:443 for request ID:2 (2) | Shutdown started. Waiting for graceful close. | 2019-07-25 20:37:23.943
HTTPS connection ID:2 to apis.tdameritrade.com:443 for request ID:2 (2) | Socket gracefully closed by remote side. | 2019-07-25 20:37:24.000
HTTPS connection ID:2 to apis.tdameritrade.com:443 for request ID:2 (2) | Closed. | 2019-07-25 20:37:24.000
HTTPS connection ID:3 to apis.tdameritrade.com:443 for request ID:3 (3) | Shutdown started. Waiting for graceful close. | 2019-07-25 20:37:24.177
HTTPS connection ID:3 to apis.tdameritrade.com:443 for request ID:3 (3) | Socket gracefully closed by remote side. | 2019-07-25 20:37:24.230
HTTPS connection ID:3 to apis.tdameritrade.com:443 for request ID:3 (3) | Closed. | 2019-07-25 20:37:24.230
TD Ameritrade | Connected to data and trading server. | 2019-07-25 20:37:24.243
HTTPS connection ID:5 to apis.tdameritrade.com:443 for request ID:5 (4) | Shutdown started. Waiting for graceful close. | 2019-07-25 20:37:24.459
HTTPS connection ID:4 to apis.tdameritrade.com:443 for request ID:4 (1) | Shutdown started. Waiting for graceful close. | 2019-07-25 20:37:24.491
HTTPS connection ID:5 to apis.tdameritrade.com:443 for request ID:5 (4) | Socket gracefully closed by remote side. | 2019-07-25 20:37:24.511
HTTPS connection ID:5 to apis.tdameritrade.com:443 for request ID:5 (4) | Closed. | 2019-07-25 20:37:24.511
HTTPS connection ID:4 to apis.tdameritrade.com:443 for request ID:4 (1) | Socket gracefully closed by remote side. | 2019-07-25 20:37:24.552
HTTPS connection ID:4 to apis.tdameritrade.com:443 for request ID:4 (1) | Closed. | 2019-07-25 20:37:24.552
TD Ameritrade | Streamer request #1 initiated. | 2019-07-25 20:37:25.242
HTTPS connection ID:1 to streamer-ext-bin.tdameritrade.com:443 for request ID:1 (1) | Creating socket. Using TLS 1.0. | 2019-07-25 20:37:25.259
HTTPS connection ID:1 to streamer-ext-bin.tdameritrade.com:443 for request ID:1 (1) | Connecting to IP: 198.200.171.138. | 2019-07-25 20:37:25.259
TD Ameritrade | Streamer response: STREAMER_SERVER_ID. Additional text: 10-3 | 2019-07-25 20:37:25.522
HTTPS connection ID:6 to apis.tdameritrade.com:443 for request ID:6 (2) | Creating socket. Using TLS 1.2. | 2019-07-25 20:37:29.240
HTTPS connection ID:6 to apis.tdameritrade.com:443 for request ID:6 (2) | Connecting to IP: 198.200.171.201. | 2019-07-25 20:37:29.240
HTTPS connection ID:7 to apis.tdameritrade.com:443 for request ID:7 (3) | Creating socket. Using TLS 1.2. | 2019-07-25 20:37:29.240
HTTPS connection ID:7 to apis.tdameritrade.com:443 for request ID:7 (3) | Connecting to IP: 198.200.171.201. | 2019-07-25 20:37:29.240
HTTPS connection ID:8 to apis.tdameritrade.com:443 for request ID:8 (4) | Creating socket. Using TLS 1.2. | 2019-07-25 20:37:29.240
HTTPS connection ID:8 to apis.tdameritrade.com:443 for request ID:8 (4) | Connecting to IP: 198.200.171.201. | 2019-07-25 20:37:29.240
HTTPS connection ID:9 to apis.tdameritrade.com:443 for request ID:9 (5) | Creating socket. Using TLS 1.2. | 2019-07-25 20:37:29.241
HTTPS connection ID:9 to apis.tdameritrade.com:443 for request ID:9 (5) | Connecting to IP: 198.200.171.201. | 2019-07-25 20:37:29.241
HTTPS connection ID:10 to apis.tdameritrade.com:443 for request ID:10 (6) | Creating socket. Using TLS 1.2. | 2019-07-25 20:37:29.241
HTTPS connection ID:10 to apis.tdameritrade.com:443 for request ID:10 (6) | Connecting to IP: 198.200.171.201. | 2019-07-25 20:37:29.241
HTTPS connection ID:7 to apis.tdameritrade.com:443 for request ID:7 (3) | Shutdown started. Waiting for graceful close. | 2019-07-25 20:37:29.740
HTTPS connection ID:11 to apis.tdameritrade.com:443 for request ID:11 (7) | Creating socket. Using TLS 1.2. | 2019-07-25 20:37:29.740
HTTPS connection ID:11 to apis.tdameritrade.com:443 for request ID:11 (7) | Connecting to IP: 198.200.171.201. | 2019-07-25 20:37:29.740
HTTPS connection ID:10 to apis.tdameritrade.com:443 for request ID:10 (6) | Shutdown started. Waiting for graceful close. | 2019-07-25 20:37:29.741
HTTPS connection ID:6 to apis.tdameritrade.com:443 for request ID:6 (2) | Shutdown started. Waiting for graceful close. | 2019-07-25 20:37:29.755
HTTPS connection ID:9 to apis.tdameritrade.com:443 for request ID:9 (5) | Shutdown started. Waiting for graceful close. | 2019-07-25 20:37:29.756
HTTPS connection ID:8 to apis.tdameritrade.com:443 for request ID:8 (4) | Shutdown started. Waiting for graceful close. | 2019-07-25 20:37:29.775
HTTPS connection ID:7 to apis.tdameritrade.com:443 for request ID:7 (3) | Socket gracefully closed by remote side. | 2019-07-25 20:37:29.793
HTTPS connection ID:7 to apis.tdameritrade.com:443 for request ID:7 (3) | Closed. | 2019-07-25 20:37:29.793
HTTPS connection ID:10 to apis.tdameritrade.com:443 for request ID:10 (6) | Socket gracefully closed by remote side. | 2019-07-25 20:37:29.793
HTTPS connection ID:10 to apis.tdameritrade.com:443 for request ID:10 (6) | Closed. | 2019-07-25 20:37:29.793
HTTPS connection ID:9 to apis.tdameritrade.com:443 for request ID:9 (5) | Socket gracefully closed by remote side. | 2019-07-25 20:37:29.814
HTTPS connection ID:9 to apis.tdameritrade.com:443 for request ID:9 (5) | Closed. | 2019-07-25 20:37:29.814
HTTPS connection ID:6 to apis.tdameritrade.com:443 for request ID:6 (2) | Socket gracefully closed by remote side. | 2019-07-25 20:37:29.814
HTTPS connection ID:6 to apis.tdameritrade.com:443 for request ID:6 (2) | Closed. | 2019-07-25 20:37:29.814
HTTPS connection ID:8 to apis.tdameritrade.com:443 for request ID:8 (4) | Socket gracefully closed by remote side. | 2019-07-25 20:37:29.834
HTTPS connection ID:8 to apis.tdameritrade.com:443 for request ID:8 (4) | Closed. | 2019-07-25 20:37:29.834
HTTPS connection ID:11 to apis.tdameritrade.com:443 for request ID:11 (7) | Shutdown started. Waiting for graceful close. | 2019-07-25 20:37:30.224
HTTPS connection ID:11 to apis.tdameritrade.com:443 for request ID:11 (7) | Socket gracefully closed by remote side. | 2019-07-25 20:37:30.282
HTTPS connection ID:11 to apis.tdameritrade.com:443 for request ID:11 (7) | Closed. | 2019-07-25 20:37:30.282
ESU19 1 Min #1 | Reloading chart. | 2019-07-25 20:37:52.958
TD Ameritrade | Starting real-time market data updates for: ESU19. ID: 1 | 2019-07-25 20:37:53.452
TD Ameritrade | Requesting security definition data for: ESU19. ID: 1 | 2019-07-25 20:37:53.452
Starting first historical Intraday data download. When complete another download will be done from the primary service. Symbol: ESU19 | 2019-07-25 20:37:53.452
Intraday data recording state for symbol ESU19 is set to download 'Pending'. | 2019-07-25 20:37:53.452
Delaying start of download for ESU19 | 2019-07-25 20:37:53.453
TD Ameritrade | Old streamer request finished. Request ID: 1. | 2019-07-25 20:37:54.445
HTTPS connection ID:1 to streamer-ext-bin.tdameritrade.com:443 for request ID:1 (1) | Shutdown started. Waiting for graceful close. | 2019-07-25 20:37:54.695
HTTPS connection ID:2 to streamer-ext-bin.tdameritrade.com:443 for request ID:2 (2) | Creating socket. Using TLS 1.0. | 2019-07-25 20:37:55.442
TD Ameritrade | Streamer request #2 initiated. | 2019-07-25 20:37:55.442
HTTPS connection ID:2 to streamer-ext-bin.tdameritrade.com:443 for request ID:2 (2) | Connecting to IP: 198.200.171.138. | 2019-07-25 20:37:55.442
TD Ameritrade | Streamer response: STREAMER_SERVER_ID. Additional text: 10-3 | 2019-07-25 20:37:55.660
+ Chart Data Loading Thread Stopwatch: 2.7422154656472233 seconds. | 2019-07-25 20:37:55.704
HTTPS connection ID:1 to streamer-ext-bin.tdameritrade.com:443 for request ID:1 (1) | Close event error. Windows error code 10053: An established connection was aborted by the software in your host machine. | 2019-07-25 20:37:55.709 *
HTTPS connection ID:1 to streamer-ext-bin.tdameritrade.com:443 for request ID:1 (1) | Socket gracefully closed by remote side. | 2019-07-25 20:37:55.709
HTTPS connection ID:1 to streamer-ext-bin.tdameritrade.com:443 for request ID:1 (1) | Closed. | 2019-07-25 20:37:55.709
HD Request # 2 | Downloading Intraday chart data for ESU19 to the file ESU19.scid. Service: cme | 2019-07-25 20:38:00.334
HD Request # 2 | Download start date-time: 2019-07-25 05:17:30.000 | 2019-07-25 20:38:00.334
HD Request # 2 | Using server: exchangehistdata2.sierracharts.com port 10149 | 2019-07-25 20:38:00.335
Socket (1) | Creating socket. | 2019-07-25 20:38:00.355
Socket (1) | Connecting to IP: 8.18.161.133. | 2019-07-25 20:38:00.355
HD Request # 2 | Setting DTC encoding to Binary VLS | 2019-07-25 20:38:00.502
HD Request # 2 | Sending historical data logon request message. | 2019-07-25 20:38:00.503
HD Request # 2 | Requesting Intraday data. Start date-time: 2019-07-25 05:17:30. Record interval: 0. Symbol: ESU19 | 2019-07-25 20:38:00.570
HD Request # 2 | Decompressing data. | 2019-07-25 20:38:00.631
HD Request # 2 | Receiving Intraday data for ESU19 starting at 2019-07-25 05:17:30 | 2019-07-25 20:38:00.781
HD Request # 2 | Timestamp of first Intraday data file record written: 2019-07-25 05:17:33 | 2019-07-25 20:38:00.781
Socket (1) | Shutdown started. Waiting for graceful close. | 2019-07-25 20:38:02.182
Historical data download thread signaled to stop. | 2019-07-25 20:38:02.182
HD Request # 2 | Received 535845 records from 2019-07-25 05:17:30.000 to 2019-07-25 20:27:23.000 (15.2 hours) and wrote 535815 records for ESU19 | 2019-07-25 20:38:02.183
HD Request # 2 | Completion time: 2s | 2019-07-25 20:38:02.186
HD Request # 2 | Intraday data download complete for ESU19. Unique request ID: 1 | 2019-07-25 20:38:02.186
Removed historical data download ID 1 | 2019-07-25 20:38:02.186
Real-time Intraday chart data file updates started for ESU19 | 2019-07-25 20:38:02.187
Intraday chart data file opened for ESU19 | 2019-07-25 20:38:02.187
TD Ameritrade | Using primary service for historical data for ESU19 | 2019-07-25 20:38:02.187
Intraday data recording state for symbol ESU19 is set to download 'Pending'. | 2019-07-25 20:38:02.187
HD Request # 3 | Downloading Intraday chart data for ESU19 to the file ESU19.scid. Service: tda | 2019-07-25 20:38:02.187
HD Request # 3 | Download start date-time: 2019-07-25 20:27:23.000 | 2019-07-25 20:38:02.188
HD Request # 3 | Requesting 0 days of historical Minute data. | 2019-07-25 20:38:02.188
HTTPS connection ID:12 to apis.tdameritrade.com:443 for request ID:12 (3) | Creating socket. Using TLS 1.2. | 2019-07-25 20:38:02.188
HTTPS connection ID:12 to apis.tdameritrade.com:443 for request ID:12 (3) | Connecting to IP: 198.200.171.201. | 2019-07-25 20:38:02.188
Socket (1) | Socket gracefully closed by remote side. | 2019-07-25 20:38:02.244
Socket (1) | Closed. | 2019-07-25 20:38:02.244
HD Request # 3 | Error downloading historical Intraday data for ESU19. Validation failed for 1 of 1 requests.Your request is not valid. | 2019-07-25 20:38:02.406
HD Request # 3 | Received 0 records from 00:00:00.000 to 00:00:00.000 (0.0 seconds) and wrote 0 records for ESU19 | 2019-07-25 20:38:02.406
HD Request # 3 | Completion time: 0s | 2019-07-25 20:38:02.406
HD Request # 3 | Intraday data download complete for ESU19. Unique request ID: 2 | 2019-07-25 20:38:02.406
Removed historical data download ID 2 | 2019-07-25 20:38:02.406
Real-time Intraday chart data file updates started for ESU19 | 2019-07-25 20:38:02.406
Intraday chart data file opened for ESU19 | 2019-07-25 20:38:02.406
HTTPS connection ID:12 to apis.tdameritrade.com:443 for request ID:12 (3) | Shutdown started. Waiting for graceful close. | 2019-07-25 20:38:02.648
HTTPS connection ID:12 to apis.tdameritrade.com:443 for request ID:12 (3) | Socket gracefully closed by remote side. | 2019-07-25 20:38:02.699
HTTPS connection ID:12 to apis.tdameritrade.com:443 for request ID:12 (3) | Closed. | 2019-07-25 20:38:02.699
HTTPS connection ID:13 to apis.tdameritrade.com:443 for request ID:13 (3) | Creating socket. Using TLS 1.2. | 2019-07-25 20:40:18.364
HTTPS connection ID:13 to apis.tdameritrade.com:443 for request ID:13 (3) | Connecting to IP: 198.200.171.201. | 2019-07-25 20:40:18.365
HTTPS connection ID:13 to apis.tdameritrade.com:443 for request ID:13 (3) | Shutdown started. Waiting for graceful close. | 2019-07-25 20:40:18.820
HTTPS connection ID:13 to apis.tdameritrade.com:443 for request ID:13 (3) | Socket gracefully closed by remote side. | 2019-07-25 20:40:18.885
HTTPS connection ID:13 to apis.tdameritrade.com:443 for request ID:13 (3) | Closed. | 2019-07-25 20:40:18.885
HTTPS connection ID:14 to apis.tdameritrade.com:443 for request ID:14 (3) | Creating socket. Using TLS 1.2. | 2019-07-25 20:43:18.367
HTTPS connection ID:14 to apis.tdameritrade.com:443 for request ID:14 (3) | Connecting to IP: 198.200.171.201. | 2019-07-25 20:43:18.367
HTTPS connection ID:14 to apis.tdameritrade.com:443 for request ID:14 (3) | Shutdown started. Waiting for graceful close. | 2019-07-25 20:43:18.849
HTTPS connection ID:14 to apis.tdameritrade.com:443 for request ID:14 (3) | Socket gracefully closed by remote side. | 2019-07-25 20:43:18.900
HTTPS connection ID:14 to apis.tdameritrade.com:443 for request ID:14 (3) | Closed. | 2019-07-25 20:43:18.900
HTTPS connection ID:15 to apis.tdameritrade.com:443 for request ID:15 (3) | Creating socket. Using TLS 1.2. | 2019-07-25 20:46:18.364
HTTPS connection ID:15 to apis.tdameritrade.com:443 for request ID:15 (3) | Connecting to IP: 198.200.171.201. | 2019-07-25 20:46:18.364
HTTPS connection ID:15 to apis.tdameritrade.com:443 for request ID:15 (3) | Shutdown started. Waiting for graceful close. | 2019-07-25 20:46:18.835
HTTPS connection ID:15 to apis.tdameritrade.com:443 for request ID:15 (3) | Socket gracefully closed by remote side. | 2019-07-25 20:46:18.886
HTTPS connection ID:15 to apis.tdameritrade.com:443 for request ID:15 (3) | Closed. | 2019-07-25 20:46:18.886
HTTPS connection ID:16 to apis.tdameritrade.com:443 for request ID:16 (3) | Creating socket. Using TLS 1.2. | 2019-07-25 20:49:18.368
HTTPS connection ID:16 to apis.tdameritrade.com:443 for request ID:16 (3) | Connecting to IP: 198.200.171.201. | 2019-07-25 20:49:18.368
HTTPS connection ID:16 to apis.tdameritrade.com:443 for request ID:16 (3) | Shutdown started. Waiting for graceful close. | 2019-07-25 20:49:18.834
HTTPS connection ID:16 to apis.tdameritrade.com:443 for request ID:16 (3) | Socket gracefully closed by remote side. | 2019-07-25 20:49:18.891
HTTPS connection ID:16 to apis.tdameritrade.com:443 for request ID:16 (3) | Closed. | 2019-07-25 20:49:18.891
HTTPS connection ID:17 to apis.tdameritrade.com:443 for request ID:17 (3) | Creating socket. Using TLS 1.2. | 2019-07-25 20:52:18.364
HTTPS connection ID:17 to apis.tdameritrade.com:443 for request ID:17 (3) | Connecting to IP: 198.200.171.201. | 2019-07-25 20:52:18.364
HTTPS connection ID:17 to apis.tdameritrade.com:443 for request ID:17 (3) | Shutdown started. Waiting for graceful close. | 2019-07-25 20:52:18.836
HTTPS connection ID:17 to apis.tdameritrade.com:443 for request ID:17 (3) | Socket gracefully closed by remote side. | 2019-07-25 20:52:18.888
HTTPS connection ID:17 to apis.tdameritrade.com:443 for request ID:17 (3) | Closed. | 2019-07-25 20:52:18.888
HTTPS connection ID:18 to apis.tdameritrade.com:443 for request ID:18 (3) | Creating socket. Using TLS 1.2. | 2019-07-25 20:55:18.390
HTTPS connection ID:18 to apis.tdameritrade.com:443 for request ID:18 (3) | Connecting to IP: 198.200.171.201. | 2019-07-25 20:55:18.390
HTTPS connection ID:18 to apis.tdameritrade.com:443 for request ID:18 (3) | Shutdown started. Waiting for graceful close. | 2019-07-25 20:55:18.851
HTTPS connection ID:18 to apis.tdameritrade.com:443 for request ID:18 (3) | Socket gracefully closed by remote side. | 2019-07-25 20:55:18.907
HTTPS connection ID:18 to apis.tdameritrade.com:443 for request ID:18 (3) | Closed. | 2019-07-25 20:55:18.907
HTTPS connection ID:19 to apis.tdameritrade.com:443 for request ID:19 (3) | Creating socket. Using TLS 1.2. | 2019-07-25 20:58:18.364
HTTPS connection ID:19 to apis.tdameritrade.com:443 for request ID:19 (3) | Connecting to IP: 198.200.171.201. | 2019-07-25 20:58:18.364
HTTPS connection ID:19 to apis.tdameritrade.com:443 for request ID:19 (3) | Shutdown started. Waiting for graceful close. | 2019-07-25 20:58:18.833
HTTPS connection ID:19 to apis.tdameritrade.com:443 for request ID:19 (3) | Socket gracefully closed by remote side. | 2019-07-25 20:58:18.883
HTTPS connection ID:19 to apis.tdameritrade.com:443 for request ID:19 (3) | Closed. | 2019-07-25 20:58:18.883
HTTPS connection ID:20 to apis.tdameritrade.com:443 for request ID:20 (3) | Creating socket. Using TLS 1.2. | 2019-07-25 21:01:18.365
HTTPS connection ID:20 to apis.tdameritrade.com:443 for request ID:20 (3) | Connecting to IP: 198.200.171.201. | 2019-07-25 21:01:18.365
HTTPS connection ID:20 to apis.tdameritrade.com:443 for request ID:20 (3) | Shutdown started. Waiting for graceful close. | 2019-07-25 21:01:18.834
HTTPS connection ID:20 to apis.tdameritrade.com:443 for request ID:20 (3) | Socket gracefully closed by remote side. | 2019-07-25 21:01:18.884
HTTPS connection ID:20 to apis.tdameritrade.com:443 for request ID:20 (3) | Closed. | 2019-07-25 21:01:18.884
HTTPS connection ID:21 to apis.tdameritrade.com:443 for request ID:21 (3) | Creating socket. Using TLS 1.2. | 2019-07-25 21:04:18.365
HTTPS connection ID:21 to apis.tdameritrade.com:443 for request ID:21 (3) | Connecting to IP: 198.200.171.201. | 2019-07-25 21:04:18.365
HTTPS connection ID:21 to apis.tdameritrade.com:443 for request ID:21 (3) | Shutdown started. Waiting for graceful close. | 2019-07-25 21:04:18.834
HTTPS connection ID:21 to apis.tdameritrade.com:443 for request ID:21 (3) | Socket gracefully closed by remote side. | 2019-07-25 21:04:18.890
HTTPS connection ID:21 to apis.tdameritrade.com:443 for request ID:21 (3) | Closed. | 2019-07-25 21:04:18.890
HTTPS connection ID:22 to apis.tdameritrade.com:443 for request ID:22 (3) | Creating socket. Using TLS 1.2. | 2019-07-25 21:07:18.368
HTTPS connection ID:22 to apis.tdameritrade.com:443 for request ID:22 (3) | Connecting to IP: 198.200.171.201. | 2019-07-25 21:07:18.368
HTTPS connection ID:22 to apis.tdameritrade.com:443 for request ID:22 (3) | Shutdown started. Waiting for graceful close. | 2019-07-25 21:07:18.836
HTTPS connection ID:22 to apis.tdameritrade.com:443 for request ID:22 (3) | Socket gracefully closed by remote side. | 2019-07-25 21:07:18.889
HTTPS connection ID:22 to apis.tdameritrade.com:443 for request ID:22 (3) | Closed. | 2019-07-25 21:07:18.889
HTTPS connection ID:23 to apis.tdameritrade.com:443 for request ID:23 (3) | Creating socket. Using TLS 1.2. | 2019-07-25 21:10:18.364
HTTPS connection ID:23 to apis.tdameritrade.com:443 for request ID:23 (3) | Connecting to IP: 198.200.171.201. | 2019-07-25 21:10:18.364
HTTPS connection ID:23 to apis.tdameritrade.com:443 for request ID:23 (3) | Shutdown started. Waiting for graceful close. | 2019-07-25 21:10:18.834
HTTPS connection ID:23 to apis.tdameritrade.com:443 for request ID:23 (3) | Socket gracefully closed by remote side. | 2019-07-25 21:10:18.900
HTTPS connection ID:23 to apis.tdameritrade.com:443 for request ID:23 (3) | Closed. | 2019-07-25 21:10:18.900
HTTPS connection ID:24 to apis.tdameritrade.com:443 for request ID:24 (3) | Creating socket. Using TLS 1.2. | 2019-07-25 21:13:18.380
HTTPS connection ID:24 to apis.tdameritrade.com:443 for request ID:24 (3) | Connecting to IP: 198.200.171.201. | 2019-07-25 21:13:18.381
HTTPS connection ID:24 to apis.tdameritrade.com:443 for request ID:24 (3) | Shutdown started. Waiting for graceful close. | 2019-07-25 21:13:18.849
HTTPS connection ID:24 to apis.tdameritrade.com:443 for request ID:24 (3) | Socket gracefully closed by remote side. | 2019-07-25 21:13:18.899
HTTPS connection ID:24 to apis.tdameritrade.com:443 for request ID:24 (3) | Closed. | 2019-07-25 21:13:18.899
HTTPS connection ID:25 to apis.tdameritrade.com:443 for request ID:25 (3) | Creating socket. Using TLS 1.2. | 2019-07-25 21:16:18.364
HTTPS connection ID:25 to apis.tdameritrade.com:443 for request ID:25 (3) | Connecting to IP: 198.200.171.201. | 2019-07-25 21:16:18.364
HTTPS connection ID:25 to apis.tdameritrade.com:443 for request ID:25 (3) | Shutdown started. Waiting for graceful close. | 2019-07-25 21:16:18.836
HTTPS connection ID:25 to apis.tdameritrade.com:443 for request ID:25 (3) | Socket gracefully closed by remote side. | 2019-07-25 21:16:18.893
HTTPS connection ID:25 to apis.tdameritrade.com:443 for request ID:25 (3) | Closed. | 2019-07-25 21:16:18.893
HTTPS connection ID:26 to apis.tdameritrade.com:443 for request ID:26 (3) | Creating socket. Using TLS 1.2. | 2019-07-25 21:19:18.366
HTTPS connection ID:26 to apis.tdameritrade.com:443 for request ID:26 (3) | Connecting to IP: 198.200.171.201. | 2019-07-25 21:19:18.366
HTTPS connection ID:26 to apis.tdameritrade.com:443 for request ID:26 (3) | Shutdown started. Waiting for graceful close. | 2019-07-25 21:19:18.849
HTTPS connection ID:26 to apis.tdameritrade.com:443 for request ID:26 (3) | Socket gracefully closed by remote side. | 2019-07-25 21:19:18.905
HTTPS connection ID:26 to apis.tdameritrade.com:443 for request ID:26 (3) | Closed. | 2019-07-25 21:19:18.905
HTTPS connection ID:27 to apis.tdameritrade.com:443 for request ID:27 (3) | Creating socket. Using TLS 1.2. | 2019-07-25 21:22:18.364
HTTPS connection ID:27 to apis.tdameritrade.com:443 for request ID:27 (3) | Connecting to IP: 198.200.171.201. | 2019-07-25 21:22:18.365
HTTPS connection ID:27 to apis.tdameritrade.com:443 for request ID:27 (3) | Shutdown started. Waiting for graceful close. | 2019-07-25 21:22:18.834
HTTPS connection ID:27 to apis.tdameritrade.com:443 for request ID:27 (3) | Socket gracefully closed by remote side. | 2019-07-25 21:22:18.886
HTTPS connection ID:27 to apis.tdameritrade.com:443 for request ID:27 (3) | Closed. | 2019-07-25 21:22:18.886
HTTPS connection ID:28 to apis.tdameritrade.com:443 for request ID:28 (3) | Creating socket. Using TLS 1.2. | 2019-07-25 21:25:18.364
HTTPS connection ID:28 to apis.tdameritrade.com:443 for request ID:28 (3) | Connecting to IP: 198.200.171.201. | 2019-07-25 21:25:18.364
HTTPS connection ID:28 to apis.tdameritrade.com:443 for request ID:28 (3) | Shutdown started. Waiting for graceful close. | 2019-07-25 21:25:18.817
HTTPS connection ID:28 to apis.tdameritrade.com:443 for request ID:28 (3) | Socket gracefully closed by remote side. | 2019-07-25 21:25:18.870
HTTPS connection ID:28 to apis.tdameritrade.com:443 for request ID:28 (3) | Closed. | 2019-07-25 21:25:18.870
HTTPS connection ID:29 to apis.tdameritrade.com:443 for request ID:29 (3) | Creating socket. Using TLS 1.2. | 2019-07-25 21:28:18.366
HTTPS connection ID:29 to apis.tdameritrade.com:443 for request ID:29 (3) | Connecting to IP: 198.200.171.201. | 2019-07-25 21:28:18.367
HTTPS connection ID:29 to apis.tdameritrade.com:443 for request ID:29 (3) | Shutdown started. Waiting for graceful close. | 2019-07-25 21:28:18.850
HTTPS connection ID:29 to apis.tdameritrade.com:443 for request ID:29 (3) | Socket gracefully closed by remote side. | 2019-07-25 21:28:18.900
HTTPS connection ID:29 to apis.tdameritrade.com:443 for request ID:29 (3) | Closed. | 2019-07-25 21:28:18.900
HTTPS connection ID:30 to apis.tdameritrade.com:443 for request ID:30 (3) | Creating socket. Using TLS 1.2. | 2019-07-25 21:31:18.386
HTTPS connection ID:30 to apis.tdameritrade.com:443 for request ID:30 (3) | Connecting to IP: 198.200.171.201. | 2019-07-25 21:31:18.386
HTTPS connection ID:30 to apis.tdameritrade.com:443 for request ID:30 (3) | Shutdown started. Waiting for graceful close. | 2019-07-25 21:31:18.849
HTTPS connection ID:30 to apis.tdameritrade.com:443 for request ID:30 (3) | Socket gracefully closed by remote side. | 2019-07-25 21:31:18.902
HTTPS connection ID:30 to apis.tdameritrade.com:443 for request ID:30 (3) | Closed. | 2019-07-25 21:31:18.902
HTTPS connection ID:31 to apis.tdameritrade.com:443 for request ID:31 (3) | Creating socket. Using TLS 1.2. | 2019-07-25 21:34:18.365
HTTPS connection ID:31 to apis.tdameritrade.com:443 for request ID:31 (3) | Connecting to IP: 198.200.171.201. | 2019-07-25 21:34:18.365
HTTPS connection ID:31 to apis.tdameritrade.com:443 for request ID:31 (3) | Shutdown started. Waiting for graceful close. | 2019-07-25 21:34:18.820
HTTPS connection ID:31 to apis.tdameritrade.com:443 for request ID:31 (3) | Socket gracefully closed by remote side. | 2019-07-25 21:34:18.870
HTTPS connection ID:31 to apis.tdameritrade.com:443 for request ID:31 (3) | Closed. | 2019-07-25 21:34:18.870
HTTPS connection ID:32 to apis.tdameritrade.com:443 for request ID:32 (3) | Creating socket. Using TLS 1.2. | 2019-07-25 21:37:18.368
HTTPS connection ID:32 to apis.tdameritrade.com:443 for request ID:32 (3) | Connecting to IP: 198.200.171.201. | 2019-07-25 21:37:18.368
HTTPS connection ID:32 to apis.tdameritrade.com:443 for request ID:32 (3) | Shutdown started. Waiting for graceful close. | 2019-07-25 21:37:18.820
HTTPS connection ID:32 to apis.tdameritrade.com:443 for request ID:32 (3) | Socket gracefully closed by remote side. | 2019-07-25 21:37:18.872
HTTPS connection ID:32 to apis.tdameritrade.com:443 for request ID:32 (3) | Closed. | 2019-07-25 21:37:18.872
HTTPS connection ID:33 to apis.tdameritrade.com:443 for request ID:33 (3) | Creating socket. Using TLS 1.2. | 2019-07-25 21:40:18.364
HTTPS connection ID:33 to apis.tdameritrade.com:443 for request ID:33 (3) | Connecting to IP: 198.200.171.201. | 2019-07-25 21:40:18.364
HTTPS connection ID:33 to apis.tdameritrade.com:443 for request ID:33 (3) | Shutdown started. Waiting for graceful close. | 2019-07-25 21:40:18.818
HTTPS connection ID:33 to apis.tdameritrade.com:443 for request ID:33 (3) | Socket gracefully closed by remote side. | 2019-07-25 21:40:18.871
HTTPS connection ID:33 to apis.tdameritrade.com:443 for request ID:33 (3) | Closed. | 2019-07-25 21:40:18.871
HTTPS connection ID:34 to apis.tdameritrade.com:443 for request ID:34 (3) | Creating socket. Using TLS 1.2. | 2019-07-25 21:43:18.366
HTTPS connection ID:34 to apis.tdameritrade.com:443 for request ID:34 (3) | Connecting to IP: 198.200.171.201. | 2019-07-25 21:43:18.366
HTTPS connection ID:34 to apis.tdameritrade.com:443 for request ID:34 (3) | Shutdown started. Waiting for graceful close. | 2019-07-25 21:43:18.836
HTTPS connection ID:34 to apis.tdameritrade.com:443 for request ID:34 (3) | Socket gracefully closed by remote side. | 2019-07-25 21:43:18.888
HTTPS connection ID:34 to apis.tdameritrade.com:443 for request ID:34 (3) | Closed. | 2019-07-25 21:43:18.888
HTTPS connection ID:35 to apis.tdameritrade.com:443 for request ID:35 (3) | Creating socket. Using TLS 1.2. | 2019-07-25 21:46:18.364
HTTPS connection ID:35 to apis.tdameritrade.com:443 for request ID:35 (3) | Connecting to IP: 198.200.171.201. | 2019-07-25 21:46:18.365
HTTPS connection ID:35 to apis.tdameritrade.com:443 for request ID:35 (3) | Shutdown started. Waiting for graceful close. | 2019-07-25 21:46:18.850
HTTPS connection ID:35 to apis.tdameritrade.com:443 for request ID:35 (3) | Socket gracefully closed by remote side. | 2019-07-25 21:46:18.902
HTTPS connection ID:35 to apis.tdameritrade.com:443 for request ID:35 (3) | Closed. | 2019-07-25 21:46:18.902
HTTPS connection ID:36 to apis.tdameritrade.com:443 for request ID:36 (3) | Creating socket. Using TLS 1.2. | 2019-07-25 21:49:18.380
HTTPS connection ID:36 to apis.tdameritrade.com:443 for request ID:36 (3) | Connecting to IP: 198.200.171.201. | 2019-07-25 21:49:18.380
HTTPS connection ID:36 to apis.tdameritrade.com:443 for request ID:36 (3) | Shutdown started. Waiting for graceful close. | 2019-07-25 21:49:18.851
HTTPS connection ID:36 to apis.tdameritrade.com:443 for request ID:36 (3) | Socket gracefully closed by remote side. | 2019-07-25 21:49:18.902
HTTPS connection ID:36 to apis.tdameritrade.com:443 for request ID:36 (3) | Closed. | 2019-07-25 21:49:18.903
HTTPS connection ID:37 to apis.tdameritrade.com:443 for request ID:37 (3) | Creating socket. Using TLS 1.2. | 2019-07-25 21:52:18.366
HTTPS connection ID:37 to apis.tdameritrade.com:443 for request ID:37 (3) | Connecting to IP: 198.200.171.201. | 2019-07-25 21:52:18.366
HTTPS connection ID:37 to apis.tdameritrade.com:443 for request ID:37 (3) | Shutdown started. Waiting for graceful close. | 2019-07-25 21:52:18.835
HTTPS connection ID:37 to apis.tdameritrade.com:443 for request ID:37 (3) | Socket gracefully closed by remote side. | 2019-07-25 21:52:18.903
HTTPS connection ID:37 to apis.tdameritrade.com:443 for request ID:37 (3) | Closed. | 2019-07-25 21:52:18.903
HTTPS connection ID:38 to apis.tdameritrade.com:443 for request ID:38 (3) | Creating socket. Using TLS 1.2. | 2019-07-25 21:55:18.365
HTTPS connection ID:38 to apis.tdameritrade.com:443 for request ID:38 (3) | Connecting to IP: 198.200.171.201. | 2019-07-25 21:55:18.365
HTTPS connection ID:38 to apis.tdameritrade.com:443 for request ID:38 (3) | Shutdown started. Waiting for graceful close. | 2019-07-25 21:55:18.817
HTTPS connection ID:38 to apis.tdameritrade.com:443 for request ID:38 (3) | Socket gracefully closed by remote side. | 2019-07-25 21:55:18.877
HTTPS connection ID:38 to apis.tdameritrade.com:443 for request ID:38 (3) | Closed. | 2019-07-25 21:55:18.877
HTTPS connection ID:39 to apis.tdameritrade.com:443 for request ID:39 (3) | Creating socket. Using TLS 1.2. | 2019-07-25 21:58:18.367
HTTPS connection ID:39 to apis.tdameritrade.com:443 for request ID:39 (3) | Connecting to IP: 198.200.171.201. | 2019-07-25 21:58:18.367
HTTPS connection ID:39 to apis.tdameritrade.com:443 for request ID:39 (3) | Shutdown started. Waiting for graceful close. | 2019-07-25 21:58:18.834
HTTPS connection ID:39 to apis.tdameritrade.com:443 for request ID:39 (3) | Socket gracefully closed by remote side. | 2019-07-25 21:58:18.886
HTTPS connection ID:39 to apis.tdameritrade.com:443 for request ID:39 (3) | Closed. | 2019-07-25 21:58:18.886
HTTPS connection ID:40 to apis.tdameritrade.com:443 for request ID:40 (3) | Creating socket. Using TLS 1.2. | 2019-07-25 22:01:18.364
HTTPS connection ID:40 to apis.tdameritrade.com:443 for request ID:40 (3) | Connecting to IP: 198.200.171.201. | 2019-07-25 22:01:18.364
HTTPS connection ID:40 to apis.tdameritrade.com:443 for request ID:40 (3) | Shutdown started. Waiting for graceful close. | 2019-07-25 22:01:18.836
HTTPS connection ID:40 to apis.tdameritrade.com:443 for request ID:40 (3) | Socket gracefully closed by remote side. | 2019-07-25 22:01:18.886
HTTPS connection ID:40 to apis.tdameritrade.com:443 for request ID:40 (3) | Closed. | 2019-07-25 22:01:18.886
HTTPS connection ID:41 to apis.tdameritrade.com:443 for request ID:41 (3) | Creating socket. Using TLS 1.2. | 2019-07-25 22:04:18.366
HTTPS connection ID:41 to apis.tdameritrade.com:443 for request ID:41 (3) | Connecting to IP: 198.200.171.201. | 2019-07-25 22:04:18.367
HTTPS connection ID:41 to apis.tdameritrade.com:443 for request ID:41 (3) | Shutdown started. Waiting for graceful close. | 2019-07-25 22:04:18.834
HTTPS connection ID:41 to apis.tdameritrade.com:443 for request ID:41 (3) | Socket gracefully closed by remote side. | 2019-07-25 22:04:18.887
HTTPS connection ID:41 to apis.tdameritrade.com:443 for request ID:41 (3) | Closed. | 2019-07-25 22:04:18.887
HTTPS connection ID:42 to apis.tdameritrade.com:443 for request ID:42 (1) | Creating socket. Using TLS 1.2. | 2019-07-25 22:05:30.889
HTTPS connection ID:42 to apis.tdameritrade.com:443 for request ID:42 (1) | Connecting to IP: 198.200.171.201. | 2019-07-25 22:05:30.889
HTTPS connection ID:43 to apis.tdameritrade.com:443 for request ID:43 (3) | Creating socket. Using TLS 1.2. | 2019-07-25 22:05:30.889
HTTPS connection ID:43 to apis.tdameritrade.com:443 for request ID:43 (3) | Connecting to IP: 198.200.171.201. | 2019-07-25 22:05:30.889
HTTPS connection ID:44 to apis.tdameritrade.com:443 for request ID:44 (4) | Creating socket. Using TLS 1.2. | 2019-07-25 22:05:30.889
HTTPS connection ID:44 to apis.tdameritrade.com:443 for request ID:44 (4) | Connecting to IP: 198.200.171.201. | 2019-07-25 22:05:30.889
HTTPS connection ID:45 to apis.tdameritrade.com:443 for request ID:45 (5) | Creating socket. Using TLS 1.2. | 2019-07-25 22:05:30.889
HTTPS connection ID:45 to apis.tdameritrade.com:443 for request ID:45 (5) | Connecting to IP: 198.200.171.201. | 2019-07-25 22:05:30.890
HTTPS connection ID:45 to apis.tdameritrade.com:443 for request ID:45 (5) | Shutdown started. Waiting for graceful close. | 2019-07-25 22:05:31.412
HTTPS connection ID:43 to apis.tdameritrade.com:443 for request ID:43 (3) | Shutdown started. Waiting for graceful close. | 2019-07-25 22:05:31.413
HTTPS connection ID:44 to apis.tdameritrade.com:443 for request ID:44 (4) | Shutdown started. Waiting for graceful close. | 2019-07-25 22:05:31.428
HTTPS connection ID:42 to apis.tdameritrade.com:443 for request ID:42 (1) | Shutdown started. Waiting for graceful close. | 2019-07-25 22:05:31.429
HTTPS connection ID:45 to apis.tdameritrade.com:443 for request ID:45 (5) | Socket gracefully closed by remote side. | 2019-07-25 22:05:31.472
HTTPS connection ID:45 to apis.tdameritrade.com:443 for request ID:45 (5) | Closed. | 2019-07-25 22:05:31.472
HTTPS connection ID:43 to apis.tdameritrade.com:443 for request ID:43 (3) | Socket gracefully closed by remote side. | 2019-07-25 22:05:31.477
HTTPS connection ID:43 to apis.tdameritrade.com:443 for request ID:43 (3) | Closed. | 2019-07-25 22:05:31.477
HTTPS connection ID:44 to apis.tdameritrade.com:443 for request ID:44 (4) | Socket gracefully closed by remote side. | 2019-07-25 22:05:31.483
HTTPS connection ID:44 to apis.tdameritrade.com:443 for request ID:44 (4) | Closed. | 2019-07-25 22:05:31.483
HTTPS connection ID:42 to apis.tdameritrade.com:443 for request ID:42 (1) | Socket gracefully closed by remote side. | 2019-07-25 22:05:31.483
HTTPS connection ID:42 to apis.tdameritrade.com:443 for request ID:42 (1) | Closed. | 2019-07-25 22:05:31.483
HTTPS connection ID:46 to apis.tdameritrade.com:443 for request ID:46 (4) | Creating socket. Using TLS 1.2. | 2019-07-25 22:07:18.364
HTTPS connection ID:46 to apis.tdameritrade.com:443 for request ID:46 (4) | Connecting to IP: 198.200.171.201. | 2019-07-25 22:07:18.364
HTTPS connection ID:46 to apis.tdameritrade.com:443 for request ID:46 (4) | Shutdown started. Waiting for graceful close. | 2019-07-25 22:07:18.834
HTTPS connection ID:46 to apis.tdameritrade.com:443 for request ID:46 (4) | Socket gracefully closed by remote side. | 2019-07-25 22:07:18.884
HTTPS connection ID:46 to apis.tdameritrade.com:443 for request ID:46 (4) | Closed. | 2019-07-25 22:07:18.884
HTTPS connection ID:47 to apis.tdameritrade.com:443 for request ID:47 (3) | Creating socket. Using TLS 1.2. | 2019-07-25 22:10:18.365
HTTPS connection ID:47 to apis.tdameritrade.com:443 for request ID:47 (3) | Connecting to IP: 198.200.171.201. | 2019-07-25 22:10:18.365
HTTPS connection ID:47 to apis.tdameritrade.com:443 for request ID:47 (3) | Shutdown started. Waiting for graceful close. | 2019-07-25 22:10:18.851
HTTPS connection ID:47 to apis.tdameritrade.com:443 for request ID:47 (3) | Socket gracefully closed by remote side. | 2019-07-25 22:10:18.906
HTTPS connection ID:47 to apis.tdameritrade.com:443 for request ID:47 (3) | Closed. | 2019-07-25 22:10:18.907
HTTPS connection ID:48 to apis.tdameritrade.com:443 for request ID:48 (3) | Creating socket. Using TLS 1.2. | 2019-07-25 22:13:18.369
HTTPS connection ID:48 to apis.tdameritrade.com:443 for request ID:48 (3) | Connecting to IP: 198.200.171.201. | 2019-07-25 22:13:18.369
HTTPS connection ID:48 to apis.tdameritrade.com:443 for request ID:48 (3) | Shutdown started. Waiting for graceful close. | 2019-07-25 22:13:18.834
HTTPS connection ID:48 to apis.tdameritrade.com:443 for request ID:48 (3) | Socket gracefully closed by remote side. | 2019-07-25 22:13:18.884
HTTPS connection ID:48 to apis.tdameritrade.com:443 for request ID:48 (3) | Closed. | 2019-07-25 22:13:18.884
HTTPS connection ID:49 to apis.tdameritrade.com:443 for request ID:49 (3) | Creating socket. Using TLS 1.2. | 2019-07-25 22:16:18.364
HTTPS connection ID:49 to apis.tdameritrade.com:443 for request ID:49 (3) | Connecting to IP: 198.200.171.201. | 2019-07-25 22:16:18.365
HTTPS connection ID:49 to apis.tdameritrade.com:443 for request ID:49 (3) | Shutdown started. Waiting for graceful close. | 2019-07-25 22:16:18.818
HTTPS connection ID:49 to apis.tdameritrade.com:443 for request ID:49 (3) | Socket gracefully closed by remote side. | 2019-07-25 22:16:18.875
HTTPS connection ID:49 to apis.tdameritrade.com:443 for request ID:49 (3) | Closed. | 2019-07-25 22:16:18.875
HTTPS connection ID:50 to apis.tdameritrade.com:443 for request ID:50 (3) | Creating socket. Using TLS 1.2. | 2019-07-25 22:19:18.369
HTTPS connection ID:50 to apis.tdameritrade.com:443 for request ID:50 (3) | Connecting to IP: 198.200.171.201. | 2019-07-25 22:19:18.369
HTTPS connection ID:50 to apis.tdameritrade.com:443 for request ID:50 (3) | Shutdown started. Waiting for graceful close. | 2019-07-25 22:19:18.851
HTTPS connection ID:50 to apis.tdameritrade.com:443 for request ID:50 (3) | Socket gracefully closed by remote side. | 2019-07-25 22:19:18.901
HTTPS connection ID:50 to apis.tdameritrade.com:443 for request ID:50 (3) | Closed. | 2019-07-25 22:19:18.901
HTTPS connection ID:51 to apis.tdameritrade.com:443 for request ID:51 (3) | Creating socket. Using TLS 1.2. | 2019-07-25 22:22:18.392
HTTPS connection ID:51 to apis.tdameritrade.com:443 for request ID:51 (3) | Connecting to IP: 198.200.171.201. | 2019-07-25 22:22:18.392
HTTPS connection ID:51 to apis.tdameritrade.com:443 for request ID:51 (3) | Shutdown started. Waiting for graceful close. | 2019-07-25 22:22:18.864
HTTPS connection ID:51 to apis.tdameritrade.com:443 for request ID:51 (3) | Socket gracefully closed by remote side. | 2019-07-25 22:22:18.914
HTTPS connection ID:51 to apis.tdameritrade.com:443 for request ID:51 (3) | Closed. | 2019-07-25 22:22:18.914
HTTPS connection ID:52 to apis.tdameritrade.com:443 for request ID:52 (3) | Creating socket. Using TLS 1.2. | 2019-07-25 22:25:18.365
HTTPS connection ID:52 to apis.tdameritrade.com:443 for request ID:52 (3) | Connecting to IP: 198.200.171.201. | 2019-07-25 22:25:18.365
HTTPS connection ID:52 to apis.tdameritrade.com:443 for request ID:52 (3) | Shutdown started. Waiting for graceful close. | 2019-07-25 22:25:18.836
HTTPS connection ID:52 to apis.tdameritrade.com:443 for request ID:52 (3) | Socket gracefully closed by remote side. | 2019-07-25 22:25:18.888
HTTPS connection ID:52 to apis.tdameritrade.com:443 for request ID:52 (3) | Closed. | 2019-07-25 22:25:18.888
HTTPS connection ID:53 to apis.tdameritrade.com:443 for request ID:53 (3) | Creating socket. Using TLS 1.2. | 2019-07-25 22:28:18.366
HTTPS connection ID:53 to apis.tdameritrade.com:443 for request ID:53 (3) | Connecting to IP: 198.200.171.201. | 2019-07-25 22:28:18.366
HTTPS connection ID:53 to apis.tdameritrade.com:443 for request ID:53 (3) | Shutdown started. Waiting for graceful close. | 2019-07-25 22:28:18.833
HTTPS connection ID:53 to apis.tdameritrade.com:443 for request ID:53 (3) | Socket gracefully closed by remote side. | 2019-07-25 22:28:18.885
HTTPS connection ID:53 to apis.tdameritrade.com:443 for request ID:53 (3) | Closed. | 2019-07-25 22:28:18.885
HTTPS connection ID:54 to apis.tdameritrade.com:443 for request ID:54 (3) | Creating socket. Using TLS 1.2. | 2019-07-25 22:31:18.364
HTTPS connection ID:54 to apis.tdameritrade.com:443 for request ID:54 (3) | Connecting to IP: 198.200.171.201. | 2019-07-25 22:31:18.364
HTTPS connection ID:54 to apis.tdameritrade.com:443 for request ID:54 (3) | Shutdown started. Waiting for graceful close. | 2019-07-25 22:31:18.818
HTTPS connection ID:54 to apis.tdameritrade.com:443 for request ID:54 (3) | Socket gracefully closed by remote side. | 2019-07-25 22:31:18.872
HTTPS connection ID:54 to apis.tdameritrade.com:443 for request ID:54 (3) | Closed. | 2019-07-25 22:31:18.872
HTTPS connection ID:55 to apis.tdameritrade.com:443 for request ID:55 (3) | Creating socket. Using TLS 1.2. | 2019-07-25 22:34:18.367
HTTPS connection ID:55 to apis.tdameritrade.com:443 for request ID:55 (3) | Connecting to IP: 198.200.171.201. | 2019-07-25 22:34:18.367
HTTPS connection ID:55 to apis.tdameritrade.com:443 for request ID:55 (3) | Shutdown started. Waiting for graceful close. | 2019-07-25 22:34:18.834
HTTPS connection ID:55 to apis.tdameritrade.com:443 for request ID:55 (3) | Socket gracefully closed by remote side. | 2019-07-25 22:34:18.884
HTTPS connection ID:55 to apis.tdameritrade.com:443 for request ID:55 (3) | Closed. | 2019-07-25 22:34:18.884
HTTPS connection ID:56 to apis.tdameritrade.com:443 for request ID:56 (3) | Creating socket. Using TLS 1.2. | 2019-07-25 22:37:18.366
HTTPS connection ID:56 to apis.tdameritrade.com:443 for request ID:56 (3) | Connecting to IP: 198.200.171.201. | 2019-07-25 22:37:18.366
HTTPS connection ID:56 to apis.tdameritrade.com:443 for request ID:56 (3) | Shutdown started. Waiting for graceful close. | 2019-07-25 22:37:18.834
HTTPS connection ID:56 to apis.tdameritrade.com:443 for request ID:56 (3) | Socket gracefully closed by remote side. | 2019-07-25 22:37:18.888
HTTPS connection ID:56 to apis.tdameritrade.com:443 for request ID:56 (3) | Closed. | 2019-07-25 22:37:18.888
HTTPS connection ID:57 to apis.tdameritrade.com:443 for request ID:57 (3) | Creating socket. Using TLS 1.2. | 2019-07-25 22:40:18.383
HTTPS connection ID:57 to apis.tdameritrade.com:443 for request ID:57 (3) | Connecting to IP: 198.200.171.201. | 2019-07-25 22:40:18.383
HTTPS connection ID:57 to apis.tdameritrade.com:443 for request ID:57 (3) | Shutdown started. Waiting for graceful close. | 2019-07-25 22:40:18.835
HTTPS connection ID:57 to apis.tdameritrade.com:443 for request ID:57 (3) | Socket gracefully closed by remote side. | 2019-07-25 22:40:18.894
HTTPS connection ID:57 to apis.tdameritrade.com:443 for request ID:57 (3) | Closed. | 2019-07-25 22:40:18.894
The data feed was lost. There was no activity for at least 15.0 minutes. | 2019-07-26 05:38:37.501
Connection to the external service has been lost. | 2019-07-26 05:38:37.501
TD Ameritrade | An HTTP request did not successfully complete. Request ID: 58. Requested script: KeepAlive. | 2019-07-26 05:38:37.534 *
TD Ameritrade | Streamer finished. Request ID: 2. | 2019-07-26 05:38:37.534
TD Ameritrade | Disconnected. | 2019-07-26 05:38:37.534
Disconnected from TD Ameritrade. | 2019-07-26 05:38:37.534
Will reconnect to the server in 3.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2019-07-26 05:38:37.534
HTTPS connection ID:2 to streamer-ext-bin.tdameritrade.com:443 for request ID:2 (2) | Shutdown started. Waiting for graceful close. | 2019-07-26 05:38:37.534
Notice: Detected that the system has resumed from a low-power state. | 2019-07-26 05:38:41.712
Re-connecting to the Data/Trading service. | 2019-07-26 05:38:41.712
TD Ameritrade | Disconnected. | 2019-07-26 05:38:41.712
Disconnected from TD Ameritrade. | 2019-07-26 05:38:41.712
Will reconnect to the server in 3.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2019-07-26 05:38:41.712
TD Ameritrade | Connecting. | 2019-07-26 05:38:44.710
TD Ameritrade | Logging in. (Step 1 of 3) | 2019-07-26 05:38:44.710
HTTPS connection ID:59 to apis.tdameritrade.com:443 for request ID:59 (3) | Creating socket. Using TLS 1.2. | 2019-07-26 05:38:44.711
HTTPS connection ID:59 to apis.tdameritrade.com:443 for request ID:59 (3) | Connecting to IP: 198.200.171.201. | 2019-07-26 05:38:44.711
TD Ameritrade | Authorized for streamer data. Account: 86*** | 2019-07-26 05:38:45.172
HTTPS connection ID:60 to apis.tdameritrade.com:443 for request ID:60 (4) | Creating socket. Using TLS 1.2. | 2019-07-26 05:38:45.172
TD Ameritrade | Getting streamer information. (Step 2 of 3) | 2019-07-26 05:38:45.172
HTTPS connection ID:60 to apis.tdameritrade.com:443 for request ID:60 (4) | Connecting to IP: 198.200.171.201. | 2019-07-26 05:38:45.173
HTTPS connection ID:61 to apis.tdameritrade.com:443 for request ID:61 (5) | Creating socket. Using TLS 1.2. | 2019-07-26 05:38:45.394
TD Ameritrade | Requesting message key for account activity streamer (Step 3 of 3) | 2019-07-26 05:38:45.394
HTTPS connection ID:61 to apis.tdameritrade.com:443 for request ID:61 (5) | Connecting to IP: 198.200.171.201. | 2019-07-26 05:38:45.394
HTTPS connection ID:59 to apis.tdameritrade.com:443 for request ID:59 (3) | Shutdown started. Waiting for graceful close. | 2019-07-26 05:38:45.411
HTTPS connection ID:59 to apis.tdameritrade.com:443 for request ID:59 (3) | Socket gracefully closed by remote side. | 2019-07-26 05:38:45.463
HTTPS connection ID:59 to apis.tdameritrade.com:443 for request ID:59 (3) | Closed. | 2019-07-26 05:38:45.463
TD Ameritrade | Requesting account balance data. Connection will be complete once received. | 2019-07-26 05:38:45.606
HTTPS connection ID:62 to apis.tdameritrade.com:443 for request ID:62 (3) | Creating socket. Using TLS 1.2. | 2019-07-26 05:38:45.606
HTTPS connection ID:62 to apis.tdameritrade.com:443 for request ID:62 (3) | Connecting to IP: 198.200.171.201. | 2019-07-26 05:38:45.607
HTTPS connection ID:63 to apis.tdameritrade.com:443 for request ID:63 (6) | Creating socket. Using TLS 1.2. | 2019-07-26 05:38:45.607
HTTPS connection ID:63 to apis.tdameritrade.com:443 for request ID:63 (6) | Connecting to IP: 198.200.171.201. | 2019-07-26 05:38:45.607
HTTPS connection ID:60 to apis.tdameritrade.com:443 for request ID:60 (4) | Shutdown started. Waiting for graceful close. | 2019-07-26 05:38:45.631
HTTPS connection ID:60 to apis.tdameritrade.com:443 for request ID:60 (4) | Socket gracefully closed by remote side. | 2019-07-26 05:38:45.681
HTTPS connection ID:60 to apis.tdameritrade.com:443 for request ID:60 (4) | Closed. | 2019-07-26 05:38:45.681
HTTPS connection ID:61 to apis.tdameritrade.com:443 for request ID:61 (5) | Shutdown started. Waiting for graceful close. | 2019-07-26 05:38:45.850
TD Ameritrade | Connected to data and trading server. | 2019-07-26 05:38:45.884
HTTPS connection ID:61 to apis.tdameritrade.com:443 for request ID:61 (5) | Socket gracefully closed by remote side. | 2019-07-26 05:38:45.901
HTTPS connection ID:61 to apis.tdameritrade.com:443 for request ID:61 (5) | Closed. | 2019-07-26 05:38:45.901
TD Ameritrade | Starting real-time market data updates for: ESU19. ID: 1 | 2019-07-26 05:38:46.042
TD Ameritrade | Requesting security definition data for: ESU19. ID: 1 | 2019-07-26 05:38:46.043
Starting first historical Intraday data download. When complete another download will be done from the primary service. Symbol: ESU19 | 2019-07-26 05:38:46.043
Intraday data recording state for symbol ESU19 is set to download 'Pending'. | 2019-07-26 05:38:46.043
Delaying start of download for ESU19 | 2019-07-26 05:38:46.045
HTTPS connection ID:63 to apis.tdameritrade.com:443 for request ID:63 (6) | Shutdown started. Waiting for graceful close. | 2019-07-26 05:38:46.098
HTTPS connection ID:62 to apis.tdameritrade.com:443 for request ID:62 (3) | Shutdown started. Waiting for graceful close. | 2019-07-26 05:38:46.135
HTTPS connection ID:63 to apis.tdameritrade.com:443 for request ID:63 (6) | Socket gracefully closed by remote side. | 2019-07-26 05:38:46.150
HTTPS connection ID:63 to apis.tdameritrade.com:443 for request ID:63 (6) | Closed. | 2019-07-26 05:38:46.150
HTTPS connection ID:62 to apis.tdameritrade.com:443 for request ID:62 (3) | Socket gracefully closed by remote side. | 2019-07-26 05:38:46.187
HTTPS connection ID:62 to apis.tdameritrade.com:443 for request ID:62 (3) | Closed. | 2019-07-26 05:38:46.187
TD Ameritrade | Streamer request #3 initiated. | 2019-07-26 05:38:47.040
HTTPS connection ID:3 to streamer-ext-bin.tdameritrade.com:443 for request ID:3 (3) | Creating socket. Using TLS 1.0. | 2019-07-26 05:38:47.058
HTTPS connection ID:3 to streamer-ext-bin.tdameritrade.com:443 for request ID:3 (3) | Connecting to IP: 198.200.171.137. | 2019-07-26 05:38:47.058
TD Ameritrade | Streamer response: STREAMER_SERVER_ID. Additional text: 09-4 | 2019-07-26 05:38:47.266
HTTPS connection ID:64 to apis.tdameritrade.com:443 for request ID:64 (4) | Creating socket. Using TLS 1.2. | 2019-07-26 05:38:50.882
HTTPS connection ID:64 to apis.tdameritrade.com:443 for request ID:64 (4) | Connecting to IP: 198.200.171.201. | 2019-07-26 05:38:50.882
HTTPS connection ID:65 to apis.tdameritrade.com:443 for request ID:65 (5) | Creating socket. Using TLS 1.2. | 2019-07-26 05:38:50.882
HTTPS connection ID:65 to apis.tdameritrade.com:443 for request ID:65 (5) | Connecting to IP: 198.200.171.201. | 2019-07-26 05:38:50.883
HTTPS connection ID:66 to apis.tdameritrade.com:443 for request ID:66 (6) | Creating socket. Using TLS 1.2. | 2019-07-26 05:38:50.883
HTTPS connection ID:66 to apis.tdameritrade.com:443 for request ID:66 (6) | Connecting to IP: 198.200.171.201. | 2019-07-26 05:38:50.883
HTTPS connection ID:67 to apis.tdameritrade.com:443 for request ID:67 (7) | Creating socket. Using TLS 1.2. | 2019-07-26 05:38:50.883
HTTPS connection ID:67 to apis.tdameritrade.com:443 for request ID:67 (7) | Connecting to IP: 198.200.171.201. | 2019-07-26 05:38:50.883
HTTPS connection ID:68 to apis.tdameritrade.com:443 for request ID:68 (8) | Creating socket. Using TLS 1.2. | 2019-07-26 05:38:50.883
HTTPS connection ID:68 to apis.tdameritrade.com:443 for request ID:68 (8) | Connecting to IP: 198.200.171.201. | 2019-07-26 05:38:50.883
HTTPS connection ID:67 to apis.tdameritrade.com:443 for request ID:67 (7) | Shutdown started. Waiting for graceful close. | 2019-07-26 05:38:51.384
HTTPS connection ID:69 to apis.tdameritrade.com:443 for request ID:69 (9) | Creating socket. Using TLS 1.2. | 2019-07-26 05:38:51.384
HTTPS connection ID:69 to apis.tdameritrade.com:443 for request ID:69 (9) | Connecting to IP: 198.200.171.201. | 2019-07-26 05:38:51.384
HTTPS connection ID:65 to apis.tdameritrade.com:443 for request ID:65 (5) | Shutdown started. Waiting for graceful close. | 2019-07-26 05:38:51.384
HTTPS connection ID:66 to apis.tdameritrade.com:443 for request ID:66 (6) | Shutdown started. Waiting for graceful close. | 2019-07-26 05:38:51.384
HTTPS connection ID:68 to apis.tdameritrade.com:443 for request ID:68 (8) | Shutdown started. Waiting for graceful close. | 2019-07-26 05:38:51.384
HTTPS connection ID:64 to apis.tdameritrade.com:443 for request ID:64 (4) | Shutdown started. Waiting for graceful close. | 2019-07-26 05:38:51.397
HTTPS connection ID:67 to apis.tdameritrade.com:443 for request ID:67 (7) | Socket gracefully closed by remote side. | 2019-07-26 05:38:51.435
HTTPS connection ID:67 to apis.tdameritrade.com:443 for request ID:67 (7) | Closed. | 2019-07-26 05:38:51.435
HTTPS connection ID:66 to apis.tdameritrade.com:443 for request ID:66 (6) | Socket gracefully closed by remote side. | 2019-07-26 05:38:51.440
HTTPS connection ID:66 to apis.tdameritrade.com:443 for request ID:66 (6) | Closed. | 2019-07-26 05:38:51.440
HTTPS connection ID:68 to apis.tdameritrade.com:443 for request ID:68 (8) | Socket gracefully closed by remote side. | 2019-07-26 05:38:51.440
HTTPS connection ID:68 to apis.tdameritrade.com:443 for request ID:68 (8) | Closed. | 2019-07-26 05:38:51.440
HTTPS connection ID:65 to apis.tdameritrade.com:443 for request ID:65 (5) | Socket gracefully closed by remote side. | 2019-07-26 05:38:51.441
HTTPS connection ID:65 to apis.tdameritrade.com:443 for request ID:65 (5) | Closed. | 2019-07-26 05:38:51.441
HTTPS connection ID:64 to apis.tdameritrade.com:443 for request ID:64 (4) | Socket gracefully closed by remote side. | 2019-07-26 05:38:51.448
HTTPS connection ID:64 to apis.tdameritrade.com:443 for request ID:64 (4) | Closed. | 2019-07-26 05:38:51.448
HTTPS connection ID:69 to apis.tdameritrade.com:443 for request ID:69 (9) | Shutdown started. Waiting for graceful close. | 2019-07-26 05:38:51.869
HTTPS connection ID:69 to apis.tdameritrade.com:443 for request ID:69 (9) | Socket gracefully closed by remote side. | 2019-07-26 05:38:51.919
HTTPS connection ID:69 to apis.tdameritrade.com:443 for request ID:69 (9) | Closed. | 2019-07-26 05:38:51.919
HD Request # 4 | Downloading Intraday chart data for ESU19 to the file ESU19.scid. Service: cme | 2019-07-26 05:38:52.039
HD Request # 4 | Download start date-time: 2019-07-25 20:27:23.000 | 2019-07-26 05:38:52.040
HD Request # 4 | Using server: exchangehistdata1.sierracharts.com port 10150 | 2019-07-26 05:38:52.040
Socket (4) | Creating socket. | 2019-07-26 05:38:52.056
Socket (4) | Connecting to IP: 8.18.161.135. | 2019-07-26 05:38:52.056
HD Request # 4 | Setting DTC encoding to Binary VLS | 2019-07-26 05:38:52.186
HD Request # 4 | Sending historical data logon request message. | 2019-07-26 05:38:52.186
HD Request # 4 | Requesting Intraday data. Start date-time: 2019-07-25 20:27:23. Record interval: 0. Symbol: ESU19 | 2019-07-26 05:38:52.245
HD Request # 4 | Decompressing data. | 2019-07-26 05:38:52.302
HD Request # 4 | Receiving Intraday data for ESU19 starting at 2019-07-25 20:27:23 | 2019-07-26 05:38:52.497
HD Request # 4 | Timestamp of first Intraday data file record written: 2019-07-25 20:28:24 | 2019-07-26 05:38:52.497
Socket (4) | Shutdown started. Waiting for graceful close. | 2019-07-26 05:38:52.690
Historical data download thread signaled to stop. | 2019-07-26 05:38:52.690
HD Request # 4 | Received 56009 records from 2019-07-25 20:27:23.000 to 2019-07-26 05:28:55.002 (9.0 hours) and wrote 56008 records for ESU19 | 2019-07-26 05:38:52.691
HD Request # 4 | Completion time: 0s | 2019-07-26 05:38:52.696
HD Request # 4 | Intraday data download complete for ESU19. Unique request ID: 3 | 2019-07-26 05:38:52.696
Removed historical data download ID 3 | 2019-07-26 05:38:52.696
Real-time Intraday chart data file updates started for ESU19 | 2019-07-26 05:38:52.696
Intraday chart data file opened for ESU19 | 2019-07-26 05:38:52.696
TD Ameritrade | Using primary service for historical data for ESU19 | 2019-07-26 05:38:52.696
Intraday data recording state for symbol ESU19 is set to download 'Pending'. | 2019-07-26 05:38:52.696
HD Request # 5 | Downloading Intraday chart data for ESU19 to the file ESU19.scid. Service: tda | 2019-07-26 05:38:52.697
HD Request # 5 | Download start date-time: 2019-07-26 05:28:55.000 | 2019-07-26 05:38:52.697
HD Request # 5 | Requesting 0 days of historical Minute data. | 2019-07-26 05:38:52.697
HTTPS connection ID:70 to apis.tdameritrade.com:443 for request ID:70 (5) | Creating socket. Using TLS 1.2. | 2019-07-26 05:38:52.697
HTTPS connection ID:70 to apis.tdameritrade.com:443 for request ID:70 (5) | Connecting to IP: 198.200.171.201. | 2019-07-26 05:38:52.697
Socket (4) | Socket gracefully closed by remote side. | 2019-07-26 05:38:52.751
Socket (4) | Closed. | 2019-07-26 05:38:52.751
HD Request # 5 | Receiving Intraday data for ESU19 starting at 2019-07-26 04:00:00 | 2019-07-26 05:38:52.921
HD Request # 5 | Received 1 record from 2019-07-26 04:00:00.000 to 2019-07-26 04:00:00.000 (0.0 seconds) and wrote 0 records for ESU19 | 2019-07-26 05:38:52.921
HD Request # 5 | Completion time: 0s | 2019-07-26 05:38:52.922
HD Request # 5 | Intraday data download complete for ESU19. Unique request ID: 4 | 2019-07-26 05:38:52.922
Removed historical data download ID 4 | 2019-07-26 05:38:52.922
Real-time Intraday chart data file updates started for ESU19 | 2019-07-26 05:38:52.922
Intraday chart data file opened for ESU19 | 2019-07-26 05:38:52.922
HTTPS connection ID:70 to apis.tdameritrade.com:443 for request ID:70 (5) | Shutdown started. Waiting for graceful close. | 2019-07-26 05:38:53.165
HTTPS connection ID:70 to apis.tdameritrade.com:443 for request ID:70 (5) | Socket gracefully closed by remote side. | 2019-07-26 05:38:53.245
HTTPS connection ID:70 to apis.tdameritrade.com:443 for request ID:70 (5) | Closed. | 2019-07-26 05:38:53.245
HTTPS connection ID:2 to streamer-ext-bin.tdameritrade.com:443 for request ID:2 (2) | Socket gracefully closed by remote side. | 2019-07-26 05:38:56.640
HTTPS connection ID:2 to streamer-ext-bin.tdameritrade.com:443 for request ID:2 (2) | Closed. | 2019-07-26 05:38:56.640
HTTPS connection ID:71 to apis.tdameritrade.com:443 for request ID:71 (1) | Creating socket. Using TLS 1.2. | 2019-07-26 05:41:37.490
HTTPS connection ID:71 to apis.tdameritrade.com:443 for request ID:71 (1) | Connecting to IP: 198.200.171.201. | 2019-07-26 05:41:37.490
HTTPS connection ID:71 to apis.tdameritrade.com:443 for request ID:71 (1) | Shutdown started. Waiting for graceful close. | 2019-07-26 05:41:37.943
HTTPS connection ID:71 to apis.tdameritrade.com:443 for request ID:71 (1) | Socket gracefully closed by remote side. | 2019-07-26 05:41:37.993
HTTPS connection ID:71 to apis.tdameritrade.com:443 for request ID:71 (1) | Closed. | 2019-07-26 05:41:37.993
HTTPS connection ID:72 to apis.tdameritrade.com:443 for request ID:72 (1) | Creating socket. Using TLS 1.2. | 2019-07-26 05:44:37.489
HTTPS connection ID:72 to apis.tdameritrade.com:443 for request ID:72 (1) | Connecting to IP: 198.200.171.201. | 2019-07-26 05:44:37.489
HTTPS connection ID:72 to apis.tdameritrade.com:443 for request ID:72 (1) | Shutdown started. Waiting for graceful close. | 2019-07-26 05:44:37.943
HTTPS connection ID:72 to apis.tdameritrade.com:443 for request ID:72 (1) | Socket gracefully closed by remote side. | 2019-07-26 05:44:37.994
HTTPS connection ID:72 to apis.tdameritrade.com:443 for request ID:72 (1) | Closed. | 2019-07-26 05:44:37.994
HTTPS connection ID:73 to apis.tdameritrade.com:443 for request ID:73 (1) | Creating socket. Using TLS 1.2. | 2019-07-26 05:47:37.490
HTTPS connection ID:73 to apis.tdameritrade.com:443 for request ID:73 (1) | Connecting to IP: 198.200.171.201. | 2019-07-26 05:47:37.490
HTTPS connection ID:73 to apis.tdameritrade.com:443 for request ID:73 (1) | Shutdown started. Waiting for graceful close. | 2019-07-26 05:47:37.943
HTTPS connection ID:73 to apis.tdameritrade.com:443 for request ID:73 (1) | Socket gracefully closed by remote side. | 2019-07-26 05:47:37.994
HTTPS connection ID:73 to apis.tdameritrade.com:443 for request ID:73 (1) | Closed. | 2019-07-26 05:47:37.994
HTTPS connection ID:74 to apis.tdameritrade.com:443 for request ID:74 (1) | Creating socket. Using TLS 1.2. | 2019-07-26 05:50:37.489
HTTPS connection ID:74 to apis.tdameritrade.com:443 for request ID:74 (1) | Connecting to IP: 198.200.171.201. | 2019-07-26 05:50:37.489
HTTPS connection ID:74 to apis.tdameritrade.com:443 for request ID:74 (1) | Shutdown started. Waiting for graceful close. | 2019-07-26 05:50:37.959
HTTPS connection ID:74 to apis.tdameritrade.com:443 for request ID:74 (1) | Socket gracefully closed by remote side. | 2019-07-26 05:50:38.009
HTTPS connection ID:74 to apis.tdameritrade.com:443 for request ID:74 (1) | Closed. | 2019-07-26 05:50:38.009
HTTPS connection ID:75 to apis.tdameritrade.com:443 for request ID:75 (1) | Creating socket. Using TLS 1.2. | 2019-07-26 05:53:37.490
HTTPS connection ID:75 to apis.tdameritrade.com:443 for request ID:75 (1) | Connecting to IP: 198.200.171.201. | 2019-07-26 05:53:37.490
HTTPS connection ID:75 to apis.tdameritrade.com:443 for request ID:75 (1) | Shutdown started. Waiting for graceful close. | 2019-07-26 05:53:37.958
HTTPS connection ID:75 to apis.tdameritrade.com:443 for request ID:75 (1) | Socket gracefully closed by remote side. | 2019-07-26 05:53:38.009
HTTPS connection ID:75 to apis.tdameritrade.com:443 for request ID:75 (1) | Closed. | 2019-07-26 05:53:38.009
HTTPS connection ID:76 to apis.tdameritrade.com:443 for request ID:76 (1) | Creating socket. Using TLS 1.2. | 2019-07-26 05:56:37.501
HTTPS connection ID:76 to apis.tdameritrade.com:443 for request ID:76 (1) | Connecting to IP: 198.200.171.201. | 2019-07-26 05:56:37.501
HTTPS connection ID:76 to apis.tdameritrade.com:443 for request ID:76 (1) | Shutdown started. Waiting for graceful close. | 2019-07-26 05:56:37.959
HTTPS connection ID:76 to apis.tdameritrade.com:443 for request ID:76 (1) | Socket gracefully closed by remote side. | 2019-07-26 05:56:38.010
HTTPS connection ID:76 to apis.tdameritrade.com:443 for request ID:76 (1) | Closed. | 2019-07-26 05:56:38.010
HTTPS connection ID:77 to apis.tdameritrade.com:443 for request ID:77 (1) | Creating socket. Using TLS 1.2. | 2019-07-26 05:59:37.491
HTTPS connection ID:77 to apis.tdameritrade.com:443 for request ID:77 (1) | Connecting to IP: 198.200.171.201. | 2019-07-26 05:59:37.491
HTTPS connection ID:77 to apis.tdameritrade.com:443 for request ID:77 (1) | Shutdown started. Waiting for graceful close. | 2019-07-26 05:59:37.959
HTTPS connection ID:77 to apis.tdameritrade.com:443 for request ID:77 (1) | Socket gracefully closed by remote side. | 2019-07-26 05:59:38.009
HTTPS connection ID:77 to apis.tdameritrade.com:443 for request ID:77 (1) | Closed. | 2019-07-26 05:59:38.009
HTTPS connection ID:78 to apis.tdameritrade.com:443 for request ID:78 (1) | Creating socket. Using TLS 1.2. | 2019-07-26 06:02:37.494
HTTPS connection ID:78 to apis.tdameritrade.com:443 for request ID:78 (1) | Connecting to IP: 198.200.171.201. | 2019-07-26 06:02:37.494
HTTPS connection ID:78 to apis.tdameritrade.com:443 for request ID:78 (1) | Shutdown started. Waiting for graceful close. | 2019-07-26 06:02:37.958
HTTPS connection ID:78 to apis.tdameritrade.com:443 for request ID:78 (1) | Socket gracefully closed by remote side. | 2019-07-26 06:02:38.011
HTTPS connection ID:78 to apis.tdameritrade.com:443 for request ID:78 (1) | Closed. | 2019-07-26 06:02:38.011
HTTPS connection ID:79 to apis.tdameritrade.com:443 for request ID:79 (1) | Creating socket. Using TLS 1.2. | 2019-07-26 06:05:40.654
HTTPS connection ID:79 to apis.tdameritrade.com:443 for request ID:79 (1) | Connecting to IP: 198.200.171.201. | 2019-07-26 06:05:40.655
HTTPS connection ID:79 to apis.tdameritrade.com:443 for request ID:79 (1) | Shutdown started. Waiting for graceful close. | 2019-07-26 06:05:41.108
HTTPS connection ID:79 to apis.tdameritrade.com:443 for request ID:79 (1) | Socket gracefully closed by remote side. | 2019-07-26 06:05:41.158
HTTPS connection ID:79 to apis.tdameritrade.com:443 for request ID:79 (1) | Closed. | 2019-07-26 06:05:41.158
HTTPS connection ID:80 to apis.tdameritrade.com:443 for request ID:80 (1) | Creating socket. Using TLS 1.2. | 2019-07-26 06:08:40.656
HTTPS connection ID:80 to apis.tdameritrade.com:443 for request ID:80 (1) | Connecting to IP: 198.200.171.201. | 2019-07-26 06:08:40.656
HTTPS connection ID:80 to apis.tdameritrade.com:443 for request ID:80 (1) | Shutdown started. Waiting for graceful close. | 2019-07-26 06:08:41.120
HTTPS connection ID:80 to apis.tdameritrade.com:443 for request ID:80 (1) | Socket gracefully closed by remote side. | 2019-07-26 06:08:41.174
HTTPS connection ID:80 to apis.tdameritrade.com:443 for request ID:80 (1) | Closed. | 2019-07-26 06:08:41.174
HTTPS connection ID:81 to apis.tdameritrade.com:443 for request ID:81 (1) | Creating socket. Using TLS 1.2. | 2019-07-26 06:11:40.669
HTTPS connection ID:81 to apis.tdameritrade.com:443 for request ID:81 (1) | Connecting to IP: 198.200.171.201. | 2019-07-26 06:11:40.669
HTTPS connection ID:81 to apis.tdameritrade.com:443 for request ID:81 (1) | Shutdown started. Waiting for graceful close. | 2019-07-26 06:11:41.120
HTTPS connection ID:81 to apis.tdameritrade.com:443 for request ID:81 (1) | Socket gracefully closed by remote side. | 2019-07-26 06:11:41.172
HTTPS connection ID:81 to apis.tdameritrade.com:443 for request ID:81 (1) | Closed. | 2019-07-26 06:11:41.172
HTTPS connection ID:82 to apis.tdameritrade.com:443 for request ID:82 (1) | Creating socket. Using TLS 1.2. | 2019-07-26 06:14:40.652
HTTPS connection ID:82 to apis.tdameritrade.com:443 for request ID:82 (1) | Connecting to IP: 198.200.171.201. | 2019-07-26 06:14:40.653
HTTPS connection ID:82 to apis.tdameritrade.com:443 for request ID:82 (1) | Shutdown started. Waiting for graceful close. | 2019-07-26 06:14:41.107
HTTPS connection ID:82 to apis.tdameritrade.com:443 for request ID:82 (1) | Socket gracefully closed by remote side. | 2019-07-26 06:14:41.159
HTTPS connection ID:82 to apis.tdameritrade.com:443 for request ID:82 (1) | Closed. | 2019-07-26 06:14:41.160
HTTPS connection ID:83 to apis.tdameritrade.com:443 for request ID:83 (1) | Creating socket. Using TLS 1.2. | 2019-07-26 06:17:40.653
HTTPS connection ID:83 to apis.tdameritrade.com:443 for request ID:83 (1) | Connecting to IP: 198.200.171.201. | 2019-07-26 06:17:40.653
HTTPS connection ID:83 to apis.tdameritrade.com:443 for request ID:83 (1) | Shutdown started. Waiting for graceful close. | 2019-07-26 06:17:41.106
HTTPS connection ID:83 to apis.tdameritrade.com:443 for request ID:83 (1) | Socket gracefully closed by remote side. | 2019-07-26 06:17:41.159
HTTPS connection ID:83 to apis.tdameritrade.com:443 for request ID:83 (1) | Closed. | 2019-07-26 06:17:41.159
HTTPS connection ID:84 to apis.tdameritrade.com:443 for request ID:84 (1) | Creating socket. Using TLS 1.2. | 2019-07-26 06:20:40.652
HTTPS connection ID:84 to apis.tdameritrade.com:443 for request ID:84 (1) | Connecting to IP: 198.200.171.201. | 2019-07-26 06:20:40.652
HTTPS connection ID:84 to apis.tdameritrade.com:443 for request ID:84 (1) | Shutdown started. Waiting for graceful close. | 2019-07-26 06:20:41.124
HTTPS connection ID:84 to apis.tdameritrade.com:443 for request ID:84 (1) | Socket gracefully closed by remote side. | 2019-07-26 06:20:41.179
HTTPS connection ID:84 to apis.tdameritrade.com:443 for request ID:84 (1) | Closed. | 2019-07-26 06:20:41.179
HTTPS connection ID:85 to apis.tdameritrade.com:443 for request ID:85 (1) | Creating socket. Using TLS 1.2. | 2019-07-26 06:23:40.652
HTTPS connection ID:85 to apis.tdameritrade.com:443 for request ID:85 (1) | Connecting to IP: 198.200.171.201. | 2019-07-26 06:23:40.652
HTTPS connection ID:85 to apis.tdameritrade.com:443 for request ID:85 (1) | Shutdown started. Waiting for graceful close. | 2019-07-26 06:23:41.107
HTTPS connection ID:85 to apis.tdameritrade.com:443 for request ID:85 (1) | Socket gracefully closed by remote side. | 2019-07-26 06:23:41.157
HTTPS connection ID:85 to apis.tdameritrade.com:443 for request ID:85 (1) | Closed. | 2019-07-26 06:23:41.157
HTTPS connection ID:86 to apis.tdameritrade.com:443 for request ID:86 (1) | Creating socket. Using TLS 1.2. | 2019-07-26 06:26:40.655
HTTPS connection ID:86 to apis.tdameritrade.com:443 for request ID:86 (1) | Connecting to IP: 198.200.171.201. | 2019-07-26 06:26:40.655
HTTPS connection ID:86 to apis.tdameritrade.com:443 for request ID:86 (1) | Shutdown started. Waiting for graceful close. | 2019-07-26 06:26:41.123
HTTPS connection ID:86 to apis.tdameritrade.com:443 for request ID:86 (1) | Socket gracefully closed by remote side. | 2019-07-26 06:26:41.173
HTTPS connection ID:86 to apis.tdameritrade.com:443 for request ID:86 (1) | Closed. | 2019-07-26 06:26:41.173
ESU19 1 Min #2 | Reloading chart. | 2019-07-26 06:28:19.577
+ Chart Data Loading Thread Stopwatch: 2.1842638147372897 seconds. | 2019-07-26 06:28:21.766
ESU19 5 Min #2 | Reloading chart. | 2019-07-26 06:28:25.469
+ Chart Data Loading Thread Stopwatch: 2.1430014809859634 seconds. | 2019-07-26 06:28:27.617
F.US.EPZ18 [C] Aligned Renko 5t #1 | Reloading chart. | 2019-07-26 06:29:06.500
F.US.EPZ18 [C] Aligned Renko 5t #1 | Symbol Settings not found for symbol. Unable to build continuous futures contract chart. | 2019-07-26 06:29:06.500
F.US.EPZ18 [C] Aligned Renko 5t #1 | There are no continuous futures contract symbols. Loading data normally. | 2019-07-26 06:29:06.500
F.US.EPZ18 [C] Rev. 20t #3 | Reloading chart. | 2019-07-26 06:29:06.524
F.US.EPZ18 [C] Rev. 20t #3 | Symbol Settings not found for symbol. Unable to build continuous futures contract chart. | 2019-07-26 06:29:06.524
F.US.EPZ18 [C] Rev. 20t #3 | There are no continuous futures contract symbols. Loading data normally. | 2019-07-26 06:29:06.524
F.US.EPZ18 [C] Aligned Renko 5t #2 | Reloading chart. | 2019-07-26 06:29:06.549
F.US.EPZ18 [C] Aligned Renko 5t #2 | Symbol Settings not found for symbol. Unable to build continuous futures contract chart. | 2019-07-26 06:29:06.549
F.US.EPZ18 [C] Aligned Renko 5t #2 | There are no continuous futures contract symbols. Loading data normally. | 2019-07-26 06:29:06.549
F.US.EPZ18 [C] 1 Min #10 | Reloading chart. | 2019-07-26 06:29:06.573
F.US.EPZ18 [C] 1 Min #10 | Symbol Settings not found for symbol. Unable to build continuous futures contract chart. | 2019-07-26 06:29:06.573
F.US.EPZ18 [C] 1 Min #10 | There are no continuous futures contract symbols. Loading data normally. | 2019-07-26 06:29:06.573
F.US.EPZ18 [C] 3 Min #4 | Reloading chart. | 2019-07-26 06:29:06.600
F.US.EPZ18 [C] 3 Min #4 | Symbol Settings not found for symbol. Unable to build continuous futures contract chart. | 2019-07-26 06:29:06.600
F.US.EPZ18 [C] 3 Min #4 | There are no continuous futures contract symbols. Loading data normally. | 2019-07-26 06:29:06.600
F.US.EPZ18 [C] Daily #7 | Reloading chart. | 2019-07-26 06:29:06.676
F.US.EPZ18 [C] Daily #7 | Symbol Settings not found for symbol. Unable to build continuous futures contract chart. | 2019-07-26 06:29:06.676
F.US.EPZ18 [C] Daily #7 | There are no continuous futures contract symbols. Loading data normally. | 2019-07-26 06:29:06.676
F.US.EPZ18 [C-D] Aligned Renko 5t #1 | Currently no data in file to display. Will start historical data download and real-time updates. File: C:\SierraChart\Data\F.US.EPZ18.scid | 2019-07-26 06:29:06.695
F.US.EPZ18 [C-D] Rev. 20t #3 | Currently no data in file to display. Will start historical data download and real-time updates. File: C:\SierraChart\Data\F.US.EPZ18.scid | 2019-07-26 06:29:06.696
F.US.EPZ18 [C-D] Aligned Renko 5t #2 | Currently no data in file to display. Will start historical data download and real-time updates. File: C:\SierraChart\Data\F.US.EPZ18.scid | 2019-07-26 06:29:06.703
F.US.EPZ18 [C-D] 1 Min #10 | Currently no data in file to display. Will start historical data download and real-time updates. File: C:\SierraChart\Data\F.US.EPZ18.scid | 2019-07-26 06:29:06.703
F.US.EPZ18 [C-D] 3 Min #4 | Currently no data in file to display. Will start historical data download and real-time updates. File: C:\SierraChart\Data\F.US.EPZ18.scid | 2019-07-26 06:29:06.704
F.US.EPZ18 [C] Daily #7 | Currently no data in file to display. Will start historical data download and real-time updates. File: C:\SierraChart\Data\F.US.EPZ18.dly | 2019-07-26 06:29:06.704
TD Ameritrade | Starting real-time market data updates for: F.US.EPZ18. ID: 2 | 2019-07-26 06:29:06.716
TD Ameritrade | Requesting security definition data for: F.US.EPZ18. ID: 2 | 2019-07-26 06:29:06.717
TD Ameritrade | Using primary service for historical data for F.US.EPZ18 | 2019-07-26 06:29:06.717
Intraday data recording state for symbol F.US.EPZ18 is set to download 'Pending'. | 2019-07-26 06:29:06.717
Delaying start of download for F.US.EPZ18 | 2019-07-26 06:29:06.718
TD Ameritrade | Using primary service for historical data for F.US.EPZ18 | 2019-07-26 06:29:07.167
The selected Service cannot handle a historical Daily data request. | 2019-07-26 06:29:07.167 *
Historical data download ID 6 not found when removing ID from outstanding request set. | 2019-07-26 06:29:07.167
TD Ameritrade | Old streamer request finished. Request ID: 3. | 2019-07-26 06:29:07.715
HTTPS connection ID:3 to streamer-ext-bin.tdameritrade.com:443 for request ID:3 (3) | Shutdown started. Waiting for graceful close. | 2019-07-26 06:29:07.964
TD Ameritrade | Streamer request #4 initiated. | 2019-07-26 06:29:08.718
HTTPS connection ID:4 to streamer-ext-bin.tdameritrade.com:443 for request ID:4 (1) | Creating socket. Using TLS 1.0. | 2019-07-26 06:29:08.742
HTTPS connection ID:4 to streamer-ext-bin.tdameritrade.com:443 for request ID:4 (1) | Connecting to IP: 198.200.171.137. | 2019-07-26 06:29:08.742
TD Ameritrade | Streamer response: STREAMER_SERVER_ID. Additional text: 09-4 | 2019-07-26 06:29:08.959
HTTPS connection ID:3 to streamer-ext-bin.tdameritrade.com:443 for request ID:3 (3) | Close event error. Windows error code 10053: An established connection was aborted by the software in your host machine. | 2019-07-26 06:29:08.990 *
HTTPS connection ID:3 to streamer-ext-bin.tdameritrade.com:443 for request ID:3 (3) | Socket gracefully closed by remote side. | 2019-07-26 06:29:08.990
HTTPS connection ID:3 to streamer-ext-bin.tdameritrade.com:443 for request ID:3 (3) | Closed. | 2019-07-26 06:29:08.990
HD Request # 6 | Downloading Intraday chart data for F.US.EPZ18 to the file F.US.EPZ18.scid. Service: tda | 2019-07-26 06:29:14.201
HD Request # 6 | Download start date-time: 2019-01-21 05:29:14.000 | 2019-07-26 06:29:14.201
HD Request # 6 | Requesting 186 days of historical Minute data. | 2019-07-26 06:29:14.201
HTTPS connection ID:87 to apis.tdameritrade.com:443 for request ID:87 (2) | Creating socket. Using TLS 1.2. | 2019-07-26 06:29:14.219
HTTPS connection ID:87 to apis.tdameritrade.com:443 for request ID:87 (2) | Connecting to IP: 198.200.171.201. | 2019-07-26 06:29:14.219
HD Request # 6 | Receiving Intraday data for F.US.EPZ18 starting at 2019-07-26 04:00:00 | 2019-07-26 06:29:14.434
HD Request # 6 | Timestamp of first Intraday data file record written: 2019-07-26 04:00:00 | 2019-07-26 06:29:14.435
HD Request # 6 | Received 1 record from 2019-07-26 04:00:00.000 to 2019-07-26 04:00:00.000 (0.0 seconds) and wrote 1 record for F.US.EPZ18 | 2019-07-26 06:29:14.435
HD Request # 6 | Completion time: 0s | 2019-07-26 06:29:14.439
HD Request # 6 | Intraday data download complete for F.US.EPZ18. Unique request ID: 5 | 2019-07-26 06:29:14.439
Removed historical data download ID 5 | 2019-07-26 06:29:14.439
Real-time Intraday chart data file updates started for F.US.EPZ18 | 2019-07-26 06:29:14.439
Intraday chart data file opened for F.US.EPZ18 | 2019-07-26 06:29:14.439
HTTPS connection ID:87 to apis.tdameritrade.com:443 for request ID:87 (2) | Shutdown started. Waiting for graceful close. | 2019-07-26 06:29:14.683
HTTPS connection ID:87 to apis.tdameritrade.com:443 for request ID:87 (2) | Socket gracefully closed by remote side. | 2019-07-26 06:29:14.738
HTTPS connection ID:87 to apis.tdameritrade.com:443 for request ID:87 (2) | Closed. | 2019-07-26 06:29:14.738
F.US.EPU18 [C] Aligned Renko 5t #1 | Reloading chart. | 2019-07-26 06:29:28.429
F.US.EPU18 [C] Aligned Renko 5t #1 | Symbol Settings not found for symbol. Unable to build continuous futures contract chart. | 2019-07-26 06:29:28.429
F.US.EPU18 [C] Aligned Renko 5t #1 | There are no continuous futures contract symbols. Loading data normally. | 2019-07-26 06:29:28.429
F.US.EPU18 [C] Rev. 20t #5 | Reloading chart. | 2019-07-26 06:29:28.459
F.US.EPU18 [C] Rev. 20t #5 | Symbol Settings not found for symbol. Unable to build continuous futures contract chart. | 2019-07-26 06:29:28.459
F.US.EPU18 [C] Rev. 20t #5 | There are no continuous futures contract symbols. Loading data normally. | 2019-07-26 06:29:28.459
F.US.EPU18 [C] Aligned Renko 5t #6 | Reloading chart. | 2019-07-26 06:29:28.483
F.US.EPU18 [C] Aligned Renko 5t #6 | Symbol Settings not found for symbol. Unable to build continuous futures contract chart. | 2019-07-26 06:29:28.483
F.US.EPU18 [C] Aligned Renko 5t #6 | There are no continuous futures contract symbols. Loading data normally. | 2019-07-26 06:29:28.483
F.US.EPU18 [C] Daily #7 | Reloading chart. | 2019-07-26 06:29:28.560
F.US.EPU18 [C] Daily #7 | Symbol Settings not found for symbol. Unable to build continuous futures contract chart. | 2019-07-26 06:29:28.560
F.US.EPU18 [C] Daily #7 | There are no continuous futures contract symbols. Loading data normally. | 2019-07-26 06:29:28.560
F.US.EPU18 [C] 120 Min #9 | Reloading chart. | 2019-07-26 06:29:28.639
F.US.EPU18 [C] 120 Min #9 | Symbol Settings not found for symbol. Unable to build continuous futures contract chart. | 2019-07-26 06:29:28.639
F.US.EPU18 [C] 120 Min #9 | There are no continuous futures contract symbols. Loading data normally. | 2019-07-26 06:29:28.639
F.US.EPU18 1 Min #10 | Reloading chart. | 2019-07-26 06:29:28.719
F.US.EPU18 [C] 1 Min #4 | Reloading chart. | 2019-07-26 06:29:28.804
F.US.EPU18 [C] 1 Min #4 | Symbol Settings not found for symbol. Unable to build continuous futures contract chart. | 2019-07-26 06:29:28.804
F.US.EPU18 [C] 1 Min #4 | There are no continuous futures contract symbols. Loading data normally. | 2019-07-26 06:29:28.804
F.US.EPU18 [C-D] Aligned Renko 5t #1 | Currently no data in file to display. Will start historical data download and real-time updates. File: C:\SierraChart\Data\F.US.EPU18.scid | 2019-07-26 06:29:28.828
F.US.EPU18 [C-D] Rev. 20t #5 | Currently no data in file to display. Will start historical data download and real-time updates. File: C:\SierraChart\Data\F.US.EPU18.scid | 2019-07-26 06:29:28.837
F.US.EPU18 [C-D] Aligned Renko 5t #6 | Currently no data in file to display. Will start historical data download and real-time updates. File: C:\SierraChart\Data\F.US.EPU18.scid | 2019-07-26 06:29:28.844
F.US.EPU18 [C] Daily #7 | Currently no data in file to display. Will start historical data download and real-time updates. File: C:\SierraChart\Data\F.US.EPU18.dly | 2019-07-26 06:29:28.849
F.US.EPU18 [C-D] 120 Min #9 | Currently no data in file to display. Will start historical data download and real-time updates. File: C:\SierraChart\Data\F.US.EPU18.scid | 2019-07-26 06:29:28.851
F.US.EPU18 1 Min #10 | Currently no data in file to display. Will start historical data download and real-time updates. File: C:\SierraChart\Data\F.US.EPU18.scid | 2019-07-26 06:29:28.855
F.US.EPU18 [C-D] 1 Min #4 | Currently no data in file to display. Will start historical data download and real-time updates. File: C:\SierraChart\Data\F.US.EPU18.scid | 2019-07-26 06:29:28.858
TD Ameritrade | Starting real-time market data updates for: F.US.EPU18. ID: 3 | 2019-07-26 06:29:28.867
TD Ameritrade | Requesting security definition data for: F.US.EPU18. ID: 3 | 2019-07-26 06:29:28.867
TD Ameritrade | Using primary service for historical data for F.US.EPU18 | 2019-07-26 06:29:28.867
Intraday data recording state for symbol F.US.EPU18 is set to download 'Pending'. | 2019-07-26 06:29:28.867
Delaying start of download for F.US.EPU18 | 2019-07-26 06:29:28.867
TD Ameritrade | Using primary service for historical data for F.US.EPU18 | 2019-07-26 06:29:29.058
The selected Service cannot handle a historical Daily data request. | 2019-07-26 06:29:29.058 *
Historical data download ID 8 not found when removing ID from outstanding request set. | 2019-07-26 06:29:29.058
TD Ameritrade | Old streamer request finished. Request ID: 4. | 2019-07-26 06:29:29.859
HTTPS connection ID:4 to streamer-ext-bin.tdameritrade.com:443 for request ID:4 (1) | Shutdown started. Waiting for graceful close. | 2019-07-26 06:29:30.277
HTTPS connection ID:5 to streamer-ext-bin.tdameritrade.com:443 for request ID:5 (2) | Creating socket. Using TLS 1.0. | 2019-07-26 06:29:30.856
TD Ameritrade | Streamer request #5 initiated. | 2019-07-26 06:29:30.856
HTTPS connection ID:5 to streamer-ext-bin.tdameritrade.com:443 for request ID:5 (2) | Connecting to IP: 198.200.171.137. | 2019-07-26 06:29:30.856
TD Ameritrade | Streamer response: STREAMER_SERVER_ID. Additional text: 09-4 | 2019-07-26 06:29:31.071
HTTPS connection ID:4 to streamer-ext-bin.tdameritrade.com:443 for request ID:4 (1) | Socket gracefully closed by remote side. | 2019-07-26 06:29:31.111
HTTPS connection ID:4 to streamer-ext-bin.tdameritrade.com:443 for request ID:4 (1) | Closed. | 2019-07-26 06:29:31.111
HD Request # 7 | Downloading Intraday chart data for F.US.EPU18 to the file F.US.EPU18.scid. Service: tda | 2019-07-26 06:29:36.202
HD Request # 7 | Download start date-time: 2019-07-25 04:00:00.000 | 2019-07-26 06:29:36.202
HD Request # 7 | Requesting 1 day of historical Minute data. | 2019-07-26 06:29:36.202
HTTPS connection ID:88 to apis.tdameritrade.com:443 for request ID:88 (1) | Creating socket. Using TLS 1.2. | 2019-07-26 06:29:36.202
HTTPS connection ID:88 to apis.tdameritrade.com:443 for request ID:88 (1) | Connecting to IP: 198.200.171.201. | 2019-07-26 06:29:36.203
HD Request # 7 | Receiving Intraday data for F.US.EPU18 starting at 2019-07-26 04:00:00 | 2019-07-26 06:29:36.415
HD Request # 7 | Timestamp of first Intraday data file record written: 2019-07-26 04:00:00 | 2019-07-26 06:29:36.416
HD Request # 7 | Received 1 record from 2019-07-26 04:00:00.000 to 2019-07-26 04:00:00.000 (0.0 seconds) and wrote 1 record for F.US.EPU18 | 2019-07-26 06:29:36.416
HD Request # 7 | Completion time: 0s | 2019-07-26 06:29:36.420
HD Request # 7 | Intraday data download complete for F.US.EPU18. Unique request ID: 7 | 2019-07-26 06:29:36.420
Removed historical data download ID 7 | 2019-07-26 06:29:36.420
Real-time Intraday chart data file updates started for F.US.EPU18 | 2019-07-26 06:29:36.420
Intraday chart data file opened for F.US.EPU18 | 2019-07-26 06:29:36.420
HTTPS connection ID:88 to apis.tdameritrade.com:443 for request ID:88 (1) | Shutdown started. Waiting for graceful close. | 2019-07-26 06:29:36.668
HTTPS connection ID:88 to apis.tdameritrade.com:443 for request ID:88 (1) | Socket gracefully closed by remote side. | 2019-07-26 06:29:36.718
HTTPS connection ID:88 to apis.tdameritrade.com:443 for request ID:88 (1) | Closed. | 2019-07-26 06:29:36.718
HTTPS connection ID:89 to apis.tdameritrade.com:443 for request ID:89 (1) | Creating socket. Using TLS 1.2. | 2019-07-26 06:29:40.651
HTTPS connection ID:89 to apis.tdameritrade.com:443 for request ID:89 (1) | Connecting to IP: 198.200.171.201. | 2019-07-26 06:29:40.652
HTTPS connection ID:89 to apis.tdameritrade.com:443 for request ID:89 (1) | Shutdown started. Waiting for graceful close. | 2019-07-26 06:29:41.107
HTTPS connection ID:89 to apis.tdameritrade.com:443 for request ID:89 (1) | Socket gracefully closed by remote side. | 2019-07-26 06:29:41.167
HTTPS connection ID:89 to apis.tdameritrade.com:443 for request ID:89 (1) | Closed. | 2019-07-26 06:29:41.167
HTTPS connection ID:90 to apis.tdameritrade.com:443 for request ID:90 (1) | Creating socket. Using TLS 1.2. | 2019-07-26 06:32:40.653
HTTPS connection ID:90 to apis.tdameritrade.com:443 for request ID:90 (1) | Connecting to IP: 198.200.171.201. | 2019-07-26 06:32:40.653
HTTPS connection ID:90 to apis.tdameritrade.com:443 for request ID:90 (1) | Shutdown started. Waiting for graceful close. | 2019-07-26 06:32:41.121
HTTPS connection ID:90 to apis.tdameritrade.com:443 for request ID:90 (1) | Socket gracefully closed by remote side. | 2019-07-26 06:32:41.172
HTTPS connection ID:90 to apis.tdameritrade.com:443 for request ID:90 (1) | Closed. | 2019-07-26 06:32:41.172
HTTPS connection ID:91 to apis.tdameritrade.com:443 for request ID:91 (1) | Creating socket. Using TLS 1.2. | 2019-07-26 06:35:40.652
HTTPS connection ID:91 to apis.tdameritrade.com:443 for request ID:91 (1) | Connecting to IP: 198.200.171.201. | 2019-07-26 06:35:40.652
HTTPS connection ID:91 to apis.tdameritrade.com:443 for request ID:91 (1) | Shutdown started. Waiting for graceful close. | 2019-07-26 06:35:41.106
HTTPS connection ID:91 to apis.tdameritrade.com:443 for request ID:91 (1) | Socket gracefully closed by remote side. | 2019-07-26 06:35:41.162
HTTPS connection ID:91 to apis.tdameritrade.com:443 for request ID:91 (1) | Closed. | 2019-07-26 06:35:41.162
HTTPS connection ID:92 to apis.tdameritrade.com:443 for request ID:92 (1) | Creating socket. Using TLS 1.2. | 2019-07-26 06:38:40.653
HTTPS connection ID:92 to apis.tdameritrade.com:443 for request ID:92 (1) | Connecting to IP: 198.200.171.201. | 2019-07-26 06:38:40.653
HTTPS connection ID:92 to apis.tdameritrade.com:443 for request ID:92 (1) | Shutdown started. Waiting for graceful close. | 2019-07-26 06:38:41.105
HTTPS connection ID:92 to apis.tdameritrade.com:443 for request ID:92 (1) | Socket gracefully closed by remote side. | 2019-07-26 06:38:41.159
HTTPS connection ID:92 to apis.tdameritrade.com:443 for request ID:92 (1) | Closed. | 2019-07-26 06:38:41.159
HTTPS connection ID:93 to apis.tdameritrade.com:443 for request ID:93 (1) | Creating socket. Using TLS 1.2. | 2019-07-26 06:41:40.652
HTTPS connection ID:93 to apis.tdameritrade.com:443 for request ID:93 (1) | Connecting to IP: 198.200.171.201. | 2019-07-26 06:41:40.653
HTTPS connection ID:93 to apis.tdameritrade.com:443 for request ID:93 (1) | Shutdown started. Waiting for graceful close. | 2019-07-26 06:41:41.107
HTTPS connection ID:93 to apis.tdameritrade.com:443 for request ID:93 (1) | Socket gracefully closed by remote side. | 2019-07-26 06:41:41.161
HTTPS connection ID:93 to apis.tdameritrade.com:443 for request ID:93 (1) | Closed. | 2019-07-26 06:41:41.161
HTTPS connection ID:94 to apis.tdameritrade.com:443 for request ID:94 (1) | Creating socket. Using TLS 1.2. | 2019-07-26 06:44:40.673
HTTPS connection ID:94 to apis.tdameritrade.com:443 for request ID:94 (1) | Connecting to IP: 198.200.171.201. | 2019-07-26 06:44:40.673
HTTPS connection ID:94 to apis.tdameritrade.com:443 for request ID:94 (1) | Shutdown started. Waiting for graceful close. | 2019-07-26 06:44:41.137
HTTPS connection ID:94 to apis.tdameritrade.com:443 for request ID:94 (1) | Socket gracefully closed by remote side. | 2019-07-26 06:44:41.187
HTTPS connection ID:94 to apis.tdameritrade.com:443 for request ID:94 (1) | Closed. | 2019-07-26 06:44:41.187
HTTPS connection ID:95 to apis.tdameritrade.com:443 for request ID:95 (1) | Creating socket. Using TLS 1.2. | 2019-07-26 06:47:40.652
HTTPS connection ID:95 to apis.tdameritrade.com:443 for request ID:95 (1) | Connecting to IP: 198.200.171.201. | 2019-07-26 06:47:40.652
HTTPS connection ID:95 to apis.tdameritrade.com:443 for request ID:95 (1) | Shutdown started. Waiting for graceful close. | 2019-07-26 06:47:41.120
HTTPS connection ID:95 to apis.tdameritrade.com:443 for request ID:95 (1) | Socket gracefully closed by remote side. | 2019-07-26 06:47:41.172
HTTPS connection ID:95 to apis.tdameritrade.com:443 for request ID:95 (1) | Closed. | 2019-07-26 06:47:41.172
HTTPS connection ID:96 to apis.tdameritrade.com:443 for request ID:96 (1) | Creating socket. Using TLS 1.2. | 2019-07-26 06:50:40.653
HTTPS connection ID:96 to apis.tdameritrade.com:443 for request ID:96 (1) | Connecting to IP: 198.200.171.201. | 2019-07-26 06:50:40.653
HTTPS connection ID:96 to apis.tdameritrade.com:443 for request ID:96 (1) | Shutdown started. Waiting for graceful close. | 2019-07-26 06:50:41.120
HTTPS connection ID:96 to apis.tdameritrade.com:443 for request ID:96 (1) | Socket gracefully closed by remote side. | 2019-07-26 06:50:41.172
HTTPS connection ID:96 to apis.tdameritrade.com:443 for request ID:96 (1) | Closed. | 2019-07-26 06:50:41.172
HTTPS connection ID:97 to apis.tdameritrade.com:443 for request ID:97 (1) | Creating socket. Using TLS 1.2. | 2019-07-26 06:53:40.653
HTTPS connection ID:97 to apis.tdameritrade.com:443 for request ID:97 (1) | Connecting to IP: 198.200.171.201. | 2019-07-26 06:53:40.653
HTTPS connection ID:97 to apis.tdameritrade.com:443 for request ID:97 (1) | Shutdown started. Waiting for graceful close. | 2019-07-26 06:53:41.122
HTTPS connection ID:97 to apis.tdameritrade.com:443 for request ID:97 (1) | Socket gracefully closed by remote side. | 2019-07-26 06:53:41.172
HTTPS connection ID:97 to apis.tdameritrade.com:443 for request ID:97 (1) | Closed. | 2019-07-26 06:53:41.172
HTTPS connection ID:98 to apis.tdameritrade.com:443 for request ID:98 (1) | Creating socket. Using TLS 1.2. | 2019-07-26 06:56:40.656
HTTPS connection ID:98 to apis.tdameritrade.com:443 for request ID:98 (1) | Connecting to IP: 198.200.171.201. | 2019-07-26 06:56:40.656
HTTPS connection ID:98 to apis.tdameritrade.com:443 for request ID:98 (1) | Shutdown started. Waiting for graceful close. | 2019-07-26 06:56:41.123
HTTPS connection ID:98 to apis.tdameritrade.com:443 for request ID:98 (1) | Socket gracefully closed by remote side. | 2019-07-26 06:56:41.175
HTTPS connection ID:98 to apis.tdameritrade.com:443 for request ID:98 (1) | Closed. | 2019-07-26 06:56:41.175
HTTPS connection ID:99 to apis.tdameritrade.com:443 for request ID:99 (1) | Creating socket. Using TLS 1.2. | 2019-07-26 06:59:40.652
HTTPS connection ID:99 to apis.tdameritrade.com:443 for request ID:99 (1) | Connecting to IP: 198.200.171.201. | 2019-07-26 06:59:40.652
HTTPS connection ID:99 to apis.tdameritrade.com:443 for request ID:99 (1) | Shutdown started. Waiting for graceful close. | 2019-07-26 06:59:41.105
HTTPS connection ID:99 to apis.tdameritrade.com:443 for request ID:99 (1) | Socket gracefully closed by remote side. | 2019-07-26 06:59:41.157
HTTPS connection ID:99 to apis.tdameritrade.com:443 for request ID:99 (1) | Closed. | 2019-07-26 06:59:41.157
HTTPS connection ID:100 to apis.tdameritrade.com:443 for request ID:100 (1) | Creating socket. Using TLS 1.2. | 2019-07-26 07:02:40.665
HTTPS connection ID:100 to apis.tdameritrade.com:443 for request ID:100 (1) | Connecting to IP: 198.200.171.201. | 2019-07-26 07:02:40.665
HTTPS connection ID:100 to apis.tdameritrade.com:443 for request ID:100 (1) | Shutdown started. Waiting for graceful close. | 2019-07-26 07:02:41.120
HTTPS connection ID:100 to apis.tdameritrade.com:443 for request ID:100 (1) | Socket gracefully closed by remote side. | 2019-07-26 07:02:41.174
HTTPS connection ID:100 to apis.tdameritrade.com:443 for request ID:100 (1) | Closed. | 2019-07-26 07:02:41.174
HTTPS connection ID:101 to apis.tdameritrade.com:443 for request ID:101 (1) | Creating socket. Using TLS 1.2. | 2019-07-26 07:05:40.653
HTTPS connection ID:101 to apis.tdameritrade.com:443 for request ID:101 (1) | Connecting to IP: 198.200.171.201. | 2019-07-26 07:05:40.653
HTTPS connection ID:101 to apis.tdameritrade.com:443 for request ID:101 (1) | Shutdown started. Waiting for graceful close. | 2019-07-26 07:05:41.109
HTTPS connection ID:101 to apis.tdameritrade.com:443 for request ID:101 (1) | Socket gracefully closed by remote side. | 2019-07-26 07:05:41.160
HTTPS connection ID:101 to apis.tdameritrade.com:443 for request ID:101 (1) | Closed. | 2019-07-26 07:05:41.160
HTTPS connection ID:102 to apis.tdameritrade.com:443 for request ID:102 (3) | Creating socket. Using TLS 1.2. | 2019-07-26 07:08:40.652
HTTPS connection ID:102 to apis.tdameritrade.com:443 for request ID:102 (3) | Connecting to IP: 198.200.171.201. | 2019-07-26 07:08:40.652
HTTPS connection ID:102 to apis.tdameritrade.com:443 for request ID:102 (3) | Shutdown started. Waiting for graceful close. | 2019-07-26 07:08:41.120
HTTPS connection ID:102 to apis.tdameritrade.com:443 for request ID:102 (3) | Socket gracefully closed by remote side. | 2019-07-26 07:08:41.177
HTTPS connection ID:102 to apis.tdameritrade.com:443 for request ID:102 (3) | Closed. | 2019-07-26 07:08:41.177
HTTPS connection ID:103 to apis.tdameritrade.com:443 for request ID:103 (1) | Creating socket. Using TLS 1.2. | 2019-07-26 07:11:40.653
HTTPS connection ID:103 to apis.tdameritrade.com:443 for request ID:103 (1) | Connecting to IP: 198.200.171.201. | 2019-07-26 07:11:40.654
HTTPS connection ID:103 to apis.tdameritrade.com:443 for request ID:103 (1) | Shutdown started. Waiting for graceful close. | 2019-07-26 07:11:41.107
HTTPS connection ID:103 to apis.tdameritrade.com:443 for request ID:103 (1) | Socket gracefully closed by remote side. | 2019-07-26 07:11:41.157
HTTPS connection ID:103 to apis.tdameritrade.com:443 for request ID:103 (1) | Closed. | 2019-07-26 07:11:41.157
HTTPS connection ID:104 to apis.tdameritrade.com:443 for request ID:104 (1) | Creating socket. Using TLS 1.2. | 2019-07-26 07:14:40.653
HTTPS connection ID:104 to apis.tdameritrade.com:443 for request ID:104 (1) | Connecting to IP: 198.200.171.201. | 2019-07-26 07:14:40.653
HTTPS connection ID:104 to apis.tdameritrade.com:443 for request ID:104 (1) | Shutdown started. Waiting for graceful close. | 2019-07-26 07:14:41.136
HTTPS connection ID:104 to apis.tdameritrade.com:443 for request ID:104 (1) | Socket gracefully closed by remote side. | 2019-07-26 07:14:41.195
HTTPS connection ID:104 to apis.tdameritrade.com:443 for request ID:104 (1) | Closed. | 2019-07-26 07:14:41.195
HTTPS connection ID:105 to apis.tdameritrade.com:443 for request ID:105 (1) | Creating socket. Using TLS 1.2. | 2019-07-26 07:17:40.652
HTTPS connection ID:105 to apis.tdameritrade.com:443 for request ID:105 (1) | Connecting to IP: 198.200.171.201. | 2019-07-26 07:17:40.652
HTTPS connection ID:105 to apis.tdameritrade.com:443 for request ID:105 (1) | Shutdown started. Waiting for graceful close. | 2019-07-26 07:17:41.105
HTTPS connection ID:105 to apis.tdameritrade.com:443 for request ID:105 (1) | Socket gracefully closed by remote side. | 2019-07-26 07:17:41.157
HTTPS connection ID:105 to apis.tdameritrade.com:443 for request ID:105 (1) | Closed. | 2019-07-26 07:17:41.158
HTTPS connection ID:106 to apis.tdameritrade.com:443 for request ID:106 (1) | Creating socket. Using TLS 1.2. | 2019-07-26 07:20:40.669
HTTPS connection ID:106 to apis.tdameritrade.com:443 for request ID:106 (1) | Connecting to IP: 198.200.171.201. | 2019-07-26 07:20:40.670
HTTPS connection ID:106 to apis.tdameritrade.com:443 for request ID:106 (1) | Shutdown started. Waiting for graceful close. | 2019-07-26 07:20:41.137
HTTPS connection ID:106 to apis.tdameritrade.com:443 for request ID:106 (1) | Socket gracefully closed by remote side. | 2019-07-26 07:20:41.192
HTTPS connection ID:106 to apis.tdameritrade.com:443 for request ID:106 (1) | Closed. | 2019-07-26 07:20:41.192
HTTPS connection ID:107 to apis.tdameritrade.com:443 for request ID:107 (1) | Creating socket. Using TLS 1.2. | 2019-07-26 07:23:40.652
HTTPS connection ID:107 to apis.tdameritrade.com:443 for request ID:107 (1) | Connecting to IP: 198.200.171.201. | 2019-07-26 07:23:40.652
HTTPS connection ID:107 to apis.tdameritrade.com:443 for request ID:107 (1) | Shutdown started. Waiting for graceful close. | 2019-07-26 07:23:41.121
HTTPS connection ID:107 to apis.tdameritrade.com:443 for request ID:107 (1) | Socket gracefully closed by remote side. | 2019-07-26 07:23:41.172
HTTPS connection ID:107 to apis.tdameritrade.com:443 for request ID:107 (1) | Closed. | 2019-07-26 07:23:41.172
HTTPS connection ID:108 to apis.tdameritrade.com:443 for request ID:108 (1) | Creating socket. Using TLS 1.2. | 2019-07-26 07:26:40.655
HTTPS connection ID:108 to apis.tdameritrade.com:443 for request ID:108 (1) | Connecting to IP: 198.200.171.201. | 2019-07-26 07:26:40.655
HTTPS connection ID:108 to apis.tdameritrade.com:443 for request ID:108 (1) | Shutdown started. Waiting for graceful close. | 2019-07-26 07:26:41.122
HTTPS connection ID:108 to apis.tdameritrade.com:443 for request ID:108 (1) | Socket gracefully closed by remote side. | 2019-07-26 07:26:41.172
HTTPS connection ID:108 to apis.tdameritrade.com:443 for request ID:108 (1) | Closed. | 2019-07-26 07:26:41.172
HTTPS connection ID:109 to apis.tdameritrade.com:443 for request ID:109 (1) | Creating socket. Using TLS 1.2. | 2019-07-26 07:29:40.652
HTTPS connection ID:109 to apis.tdameritrade.com:443 for request ID:109 (1) | Connecting to IP: 198.200.171.201. | 2019-07-26 07:29:40.652
HTTPS connection ID:109 to apis.tdameritrade.com:443 for request ID:109 (1) | Shutdown started. Waiting for graceful close. | 2019-07-26 07:29:41.120
HTTPS connection ID:109 to apis.tdameritrade.com:443 for request ID:109 (1) | Socket gracefully closed by remote side. | 2019-07-26 07:29:41.172
HTTPS connection ID:109 to apis.tdameritrade.com:443 for request ID:109 (1) | Closed. | 2019-07-26 07:29:41.172
HTTPS connection ID:110 to apis.tdameritrade.com:443 for request ID:110 (1) | Creating socket. Using TLS 1.2. | 2019-07-26 07:32:40.651
HTTPS connection ID:110 to apis.tdameritrade.com:443 for request ID:110 (1) | Connecting to IP: 198.200.171.201. | 2019-07-26 07:32:40.651
HTTPS connection ID:110 to apis.tdameritrade.com:443 for request ID:110 (1) | Shutdown started. Waiting for graceful close. | 2019-07-26 07:32:41.123
HTTPS connection ID:110 to apis.tdameritrade.com:443 for request ID:110 (1) | Socket gracefully closed by remote side. | 2019-07-26 07:32:41.182
HTTPS connection ID:110 to apis.tdameritrade.com:443 for request ID:110 (1) | Closed. | 2019-07-26 07:32:41.182
HTTPS connection ID:111 to apis.tdameritrade.com:443 for request ID:111 (1) | Creating socket. Using TLS 1.2. | 2019-07-26 07:34:05.814
HTTPS connection ID:111 to apis.tdameritrade.com:443 for request ID:111 (1) | Connecting to IP: 198.200.171.201. | 2019-07-26 07:34:05.814
HTTPS connection ID:112 to apis.tdameritrade.com:443 for request ID:112 (3) | Creating socket. Using TLS 1.2. | 2019-07-26 07:34:06.153
HTTPS connection ID:112 to apis.tdameritrade.com:443 for request ID:112 (3) | Connecting to IP: 198.200.171.201. | 2019-07-26 07:34:06.153
HTTPS connection ID:112 to apis.tdameritrade.com:443 for request ID:112 (3) | Shutdown started. Waiting for graceful close. | 2019-07-26 07:34:06.652
HTTPS connection ID:112 to apis.tdameritrade.com:443 for request ID:112 (3) | Socket gracefully closed by remote side. | 2019-07-26 07:34:06.706
HTTPS connection ID:112 to apis.tdameritrade.com:443 for request ID:112 (3) | Closed. | 2019-07-26 07:34:06.706
HTTPS connection ID:113 to apis.tdameritrade.com:443 for request ID:113 (3) | Creating socket. Using TLS 1.2. | 2019-07-26 07:34:07.652
HTTPS connection ID:113 to apis.tdameritrade.com:443 for request ID:113 (3) | Connecting to IP: 198.200.171.201. | 2019-07-26 07:34:07.652
HTTPS connection ID:114 to apis.tdameritrade.com:443 for request ID:114 (4) | Creating socket. Using TLS 1.2. | 2019-07-26 07:34:07.652
HTTPS connection ID:114 to apis.tdameritrade.com:443 for request ID:114 (4) | Connecting to IP: 198.200.171.201. | 2019-07-26 07:34:07.652
HTTPS connection ID:115 to apis.tdameritrade.com:443 for request ID:115 (5) | Creating socket. Using TLS 1.2. | 2019-07-26 07:34:07.652
HTTPS connection ID:115 to apis.tdameritrade.com:443 for request ID:115 (5) | Connecting to IP: 198.200.171.201. | 2019-07-26 07:34:07.652
HTTPS connection ID:116 to apis.tdameritrade.com:443 for request ID:116 (6) | Creating socket. Using TLS 1.2. | 2019-07-26 07:34:07.652
HTTPS connection ID:116 to apis.tdameritrade.com:443 for request ID:116 (6) | Connecting to IP: 198.200.171.201. | 2019-07-26 07:34:07.653
HTTPS connection ID:115 to apis.tdameritrade.com:443 for request ID:115 (5) | Shutdown started. Waiting for graceful close. | 2019-07-26 07:34:08.135
HTTPS connection ID:116 to apis.tdameritrade.com:443 for request ID:116 (6) | Shutdown started. Waiting for graceful close. | 2019-07-26 07:34:08.152
HTTPS connection ID:114 to apis.tdameritrade.com:443 for request ID:114 (4) | Shutdown started. Waiting for graceful close. | 2019-07-26 07:34:08.153
HTTPS connection ID:113 to apis.tdameritrade.com:443 for request ID:113 (3) | Shutdown started. Waiting for graceful close. | 2019-07-26 07:34:08.169
HTTPS connection ID:115 to apis.tdameritrade.com:443 for request ID:115 (5) | Socket gracefully closed by remote side. | 2019-07-26 07:34:08.190
HTTPS connection ID:115 to apis.tdameritrade.com:443 for request ID:115 (5) | Closed. | 2019-07-26 07:34:08.190
HTTPS connection ID:116 to apis.tdameritrade.com:443 for request ID:116 (6) | Socket gracefully closed by remote side. | 2019-07-26 07:34:08.203
HTTPS connection ID:116 to apis.tdameritrade.com:443 for request ID:116 (6) | Closed. | 2019-07-26 07:34:08.203
HTTPS connection ID:114 to apis.tdameritrade.com:443 for request ID:114 (4) | Socket gracefully closed by remote side. | 2019-07-26 07:34:08.203
HTTPS connection ID:114 to apis.tdameritrade.com:443 for request ID:114 (4) | Closed. | 2019-07-26 07:34:08.203
HTTPS connection ID:113 to apis.tdameritrade.com:443 for request ID:113 (3) | Socket gracefully closed by remote side. | 2019-07-26 07:34:08.223
HTTPS connection ID:113 to apis.tdameritrade.com:443 for request ID:113 (3) | Closed. | 2019-07-26 07:34:08.224
HTTPS connection ID:111 to apis.tdameritrade.com:443 for request ID:111 (1) | Shutdown started. Waiting for graceful close. | 2019-07-26 07:34:09.278
HTTPS connection ID:111 to apis.tdameritrade.com:443 for request ID:111 (1) | Socket gracefully closed by remote side. | 2019-07-26 07:34:09.329
HTTPS connection ID:111 to apis.tdameritrade.com:443 for request ID:111 (1) | Closed. | 2019-07-26 07:34:09.329
HTTPS connection ID:117 to apis.tdameritrade.com:443 for request ID:117 (1) | Creating socket. Using TLS 1.2. | 2019-07-26 07:34:27.310
HTTPS connection ID:117 to apis.tdameritrade.com:443 for request ID:117 (1) | Connecting to IP: 198.200.171.201. | 2019-07-26 07:34:27.310
HTTPS connection ID:118 to apis.tdameritrade.com:443 for request ID:118 (3) | Creating socket. Using TLS 1.2. | 2019-07-26 07:34:27.310
HTTPS connection ID:118 to apis.tdameritrade.com:443 for request ID:118 (3) | Connecting to IP: 198.200.171.201. | 2019-07-26 07:34:27.311
HTTPS connection ID:119 to apis.tdameritrade.com:443 for request ID:119 (4) | Creating socket. Using TLS 1.2. | 2019-07-26 07:34:27.311
HTTPS connection ID:119 to apis.tdameritrade.com:443 for request ID:119 (4) | Connecting to IP: 198.200.171.201. | 2019-07-26 07:34:27.311
HTTPS connection ID:120 to apis.tdameritrade.com:443 for request ID:120 (5) | Creating socket. Using TLS 1.2. | 2019-07-26 07:34:27.311
HTTPS connection ID:120 to apis.tdameritrade.com:443 for request ID:120 (5) | Connecting to IP: 198.200.171.201. | 2019-07-26 07:34:27.311
HTTPS connection ID:120 to apis.tdameritrade.com:443 for request ID:120 (5) | Shutdown started. Waiting for graceful close. | 2019-07-26 07:34:27.824
HTTPS connection ID:117 to apis.tdameritrade.com:443 for request ID:117 (1) | Shutdown started. Waiting for graceful close. | 2019-07-26 07:34:27.824
HTTPS connection ID:118 to apis.tdameritrade.com:443 for request ID:118 (3) | Shutdown started. Waiting for graceful close. | 2019-07-26 07:34:27.824
HTTPS connection ID:119 to apis.tdameritrade.com:443 for request ID:119 (4) | Shutdown started. Waiting for graceful close. | 2019-07-26 07:34:27.840
HTTPS connection ID:120 to apis.tdameritrade.com:443 for request ID:120 (5) | Socket gracefully closed by remote side. | 2019-07-26 07:34:27.874
HTTPS connection ID:120 to apis.tdameritrade.com:443 for request ID:120 (5) | Closed. | 2019-07-26 07:34:27.874
HTTPS connection ID:118 to apis.tdameritrade.com:443 for request ID:118 (3) | Socket gracefully closed by remote side. | 2019-07-26 07:34:27.875
HTTPS connection ID:118 to apis.tdameritrade.com:443 for request ID:118 (3) | Closed. | 2019-07-26 07:34:27.875
HTTPS connection ID:117 to apis.tdameritrade.com:443 for request ID:117 (1) | Socket gracefully closed by remote side. | 2019-07-26 07:34:27.875
HTTPS connection ID:117 to apis.tdameritrade.com:443 for request ID:117 (1) | Closed. | 2019-07-26 07:34:27.875
HTTPS connection ID:119 to apis.tdameritrade.com:443 for request ID:119 (4) | Socket gracefully closed by remote side. | 2019-07-26 07:34:27.891
HTTPS connection ID:119 to apis.tdameritrade.com:443 for request ID:119 (4) | Closed. | 2019-07-26 07:34:27.891
HTTPS connection ID:121 to apis.tdameritrade.com:443 for request ID:121 (1) | Creating socket. Using TLS 1.2. | 2019-07-26 07:35:40.654
HTTPS connection ID:121 to apis.tdameritrade.com:443 for request ID:121 (1) | Connecting to IP: 198.200.171.201. | 2019-07-26 07:35:40.654
HTTPS connection ID:121 to apis.tdameritrade.com:443 for request ID:121 (1) | Shutdown started. Waiting for graceful close. | 2019-07-26 07:35:41.139
HTTPS connection ID:121 to apis.tdameritrade.com:443 for request ID:121 (1) | Socket gracefully closed by remote side. | 2019-07-26 07:35:41.192
HTTPS connection ID:121 to apis.tdameritrade.com:443 for request ID:121 (1) | Closed. | 2019-07-26 07:35:41.192
HTTPS connection ID:122 to apis.tdameritrade.com:443 for request ID:122 (1) | Creating socket. Using TLS 1.2. | 2019-07-26 07:38:40.679
HTTPS connection ID:122 to apis.tdameritrade.com:443 for request ID:122 (1) | Connecting to IP: 198.200.171.201. | 2019-07-26 07:38:40.679
HTTPS connection ID:122 to apis.tdameritrade.com:443 for request ID:122 (1) | Shutdown started. Waiting for graceful close. | 2019-07-26 07:38:41.138
HTTPS connection ID:122 to apis.tdameritrade.com:443 for request ID:122 (1) | Socket gracefully closed by remote side. | 2019-07-26 07:38:41.189
HTTPS connection ID:122 to apis.tdameritrade.com:443 for request ID:122 (1) | Closed. | 2019-07-26 07:38:41.189
HTTPS connection ID:123 to apis.tdameritrade.com:443 for request ID:123 (1) | Creating socket. Using TLS 1.2. | 2019-07-26 07:41:40.654
HTTPS connection ID:123 to apis.tdameritrade.com:443 for request ID:123 (1) | Connecting to IP: 198.200.171.201. | 2019-07-26 07:41:40.654
HTTPS connection ID:123 to apis.tdameritrade.com:443 for request ID:123 (1) | Shutdown started. Waiting for graceful close. | 2019-07-26 07:41:41.105
HTTPS connection ID:123 to apis.tdameritrade.com:443 for request ID:123 (1) | Socket gracefully closed by remote side. | 2019-07-26 07:41:41.163
HTTPS connection ID:123 to apis.tdameritrade.com:443 for request ID:123 (1) | Closed. | 2019-07-26 07:41:41.163
HTTPS connection ID:124 to apis.tdameritrade.com:443 for request ID:124 (1) | Creating socket. Using TLS 1.2. | 2019-07-26 07:44:40.652
HTTPS connection ID:124 to apis.tdameritrade.com:443 for request ID:124 (1) | Connecting to IP: 198.200.171.201. | 2019-07-26 07:44:40.653
HTTPS connection ID:124 to apis.tdameritrade.com:443 for request ID:124 (1) | Shutdown started. Waiting for graceful close. | 2019-07-26 07:44:41.105
HTTPS connection ID:124 to apis.tdameritrade.com:443 for request ID:124 (1) | Socket gracefully closed by remote side. | 2019-07-26 07:44:41.157
HTTPS connection ID:124 to apis.tdameritrade.com:443 for request ID:124 (1) | Closed. | 2019-07-26 07:44:41.157
HTTPS connection ID:125 to apis.tdameritrade.com:443 for request ID:125 (1) | Creating socket. Using TLS 1.2. | 2019-07-26 07:47:40.652
HTTPS connection ID:125 to apis.tdameritrade.com:443 for request ID:125 (1) | Connecting to IP: 198.200.171.201. | 2019-07-26 07:47:40.652
HTTPS connection ID:125 to apis.tdameritrade.com:443 for request ID:125 (1) | Shutdown started. Waiting for graceful close. | 2019-07-26 07:47:41.105
HTTPS connection ID:125 to apis.tdameritrade.com:443 for request ID:125 (1) | Socket gracefully closed by remote side. | 2019-07-26 07:47:41.159
HTTPS connection ID:125 to apis.tdameritrade.com:443 for request ID:125 (1) | Closed. | 2019-07-26 07:47:41.159
HTTPS connection ID:126 to apis.tdameritrade.com:443 for request ID:126 (1) | Creating socket. Using TLS 1.2. | 2019-07-26 07:50:40.654
HTTPS connection ID:126 to apis.tdameritrade.com:443 for request ID:126 (1) | Connecting to IP: 198.200.171.201. | 2019-07-26 07:50:40.655
HTTPS connection ID:126 to apis.tdameritrade.com:443 for request ID:126 (1) | Shutdown started. Waiting for graceful close. | 2019-07-26 07:50:41.125
HTTPS connection ID:126 to apis.tdameritrade.com:443 for request ID:126 (1) | Socket gracefully closed by remote side. | 2019-07-26 07:50:41.176
HTTPS connection ID:126 to apis.tdameritrade.com:443 for request ID:126 (1) | Closed. | 2019-07-26 07:50:41.176
HTTPS connection ID:127 to apis.tdameritrade.com:443 for request ID:127 (1) | Creating socket. Using TLS 1.2. | 2019-07-26 07:53:40.653
HTTPS connection ID:127 to apis.tdameritrade.com:443 for request ID:127 (1) | Connecting to IP: 198.200.171.201. | 2019-07-26 07:53:40.653
HTTPS connection ID:127 to apis.tdameritrade.com:443 for request ID:127 (1) | Shutdown started. Waiting for graceful close. | 2019-07-26 07:53:41.109
HTTPS connection ID:127 to apis.tdameritrade.com:443 for request ID:127 (1) | Socket gracefully closed by remote side. | 2019-07-26 07:53:41.160
HTTPS connection ID:127 to apis.tdameritrade.com:443 for request ID:127 (1) | Closed. | 2019-07-26 07:53:41.160
HTTPS connection ID:128 to apis.tdameritrade.com:443 for request ID:128 (1) | Creating socket. Using TLS 1.2. | 2019-07-26 07:56:40.670
HTTPS connection ID:128 to apis.tdameritrade.com:443 for request ID:128 (1) | Connecting to IP: 198.200.171.201. | 2019-07-26 07:56:40.670
HTTPS connection ID:128 to apis.tdameritrade.com:443 for request ID:128 (1) | Shutdown started. Waiting for graceful close. | 2019-07-26 07:56:41.138
HTTPS connection ID:128 to apis.tdameritrade.com:443 for request ID:128 (1) | Socket gracefully closed by remote side. | 2019-07-26 07:56:41.189
HTTPS connection ID:128 to apis.tdameritrade.com:443 for request ID:128 (1) | Closed. | 2019-07-26 07:56:41.189
HTTPS connection ID:129 to apis.tdameritrade.com:443 for request ID:129 (1) | Creating socket. Using TLS 1.2. | 2019-07-26 07:59:40.652
HTTPS connection ID:129 to apis.tdameritrade.com:443 for request ID:129 (1) | Connecting to IP: 198.200.171.201. | 2019-07-26 07:59:40.652
HTTPS connection ID:129 to apis.tdameritrade.com:443 for request ID:129 (1) | Shutdown started. Waiting for graceful close. | 2019-07-26 07:59:41.125
HTTPS connection ID:129 to apis.tdameritrade.com:443 for request ID:129 (1) | Socket gracefully closed by remote side. | 2019-07-26 07:59:41.179
HTTPS connection ID:129 to apis.tdameritrade.com:443 for request ID:129 (1) | Closed. | 2019-07-26 07:59:41.179
HTTPS connection ID:130 to apis.tdameritrade.com:443 for request ID:130 (1) | Creating socket. Using TLS 1.2. | 2019-07-26 08:02:40.654
HTTPS connection ID:130 to apis.tdameritrade.com:443 for request ID:130 (1) | Connecting to IP: 198.200.171.201. | 2019-07-26 08:02:40.654
HTTPS connection ID:130 to apis.tdameritrade.com:443 for request ID:130 (1) | Shutdown started. Waiting for graceful close. | 2019-07-26 08:02:41.105
HTTPS connection ID:130 to apis.tdameritrade.com:443 for request ID:130 (1) | Socket gracefully closed by remote side. | 2019-07-26 08:02:41.155
HTTPS connection ID:130 to apis.tdameritrade.com:443 for request ID:130 (1) | Closed. | 2019-07-26 08:02:41.155
HTTPS connection ID:131 to apis.tdameritrade.com:443 for request ID:131 (1) | Creating socket. Using TLS 1.2. | 2019-07-26 08:05:40.656
HTTPS connection ID:131 to apis.tdameritrade.com:443 for request ID:131 (1) | Connecting to IP: 198.200.171.201. | 2019-07-26 08:05:40.656
HTTPS connection ID:131 to apis.tdameritrade.com:443 for request ID:131 (1) | Shutdown started. Waiting for graceful close. | 2019-07-26 08:05:41.125
HTTPS connection ID:131 to apis.tdameritrade.com:443 for request ID:131 (1) | Socket gracefully closed by remote side. | 2019-07-26 08:05:41.177
HTTPS connection ID:131 to apis.tdameritrade.com:443 for request ID:131 (1) | Closed. | 2019-07-26 08:05:41.177
HTTPS connection ID:132 to apis.tdameritrade.com:443 for request ID:132 (1) | Creating socket. Using TLS 1.2. | 2019-07-26 08:08:40.652
HTTPS connection ID:132 to apis.tdameritrade.com:443 for request ID:132 (1) | Connecting to IP: 198.200.171.201. | 2019-07-26 08:08:40.652
HTTPS connection ID:132 to apis.tdameritrade.com:443 for request ID:132 (1) | Shutdown started. Waiting for graceful close. | 2019-07-26 08:08:41.122
HTTPS connection ID:132 to apis.tdameritrade.com:443 for request ID:132 (1) | Socket gracefully closed by remote side. | 2019-07-26 08:08:41.173
HTTPS connection ID:132 to apis.tdameritrade.com:443 for request ID:132 (1) | Closed. | 2019-07-26 08:08:41.173
HTTPS connection ID:133 to apis.tdameritrade.com:443 for request ID:133 (1) | Creating socket. Using TLS 1.2. | 2019-07-26 08:11:40.653
HTTPS connection ID:133 to apis.tdameritrade.com:443 for request ID:133 (1) | Connecting to IP: 198.200.171.201. | 2019-07-26 08:11:40.653
HTTPS connection ID:133 to apis.tdameritrade.com:443 for request ID:133 (1) | Shutdown started. Waiting for graceful close. | 2019-07-26 08:11:41.106
HTTPS connection ID:133 to apis.tdameritrade.com:443 for request ID:133 (1) | Socket gracefully closed by remote side. | 2019-07-26 08:11:41.157
HTTPS connection ID:133 to apis.tdameritrade.com:443 for request ID:133 (1) | Closed. | 2019-07-26 08:11:41.157
HTTPS connection ID:134 to apis.tdameritrade.com:443 for request ID:134 (1) | Creating socket. Using TLS 1.2. | 2019-07-26 08:14:40.664
HTTPS connection ID:134 to apis.tdameritrade.com:443 for request ID:134 (1) | Connecting to IP: 198.200.171.201. | 2019-07-26 08:14:40.664
HTTPS connection ID:134 to apis.tdameritrade.com:443 for request ID:134 (1) | Shutdown started. Waiting for graceful close. | 2019-07-26 08:14:41.121
HTTPS connection ID:134 to apis.tdameritrade.com:443 for request ID:134 (1) | Socket gracefully closed by remote side. | 2019-07-26 08:14:41.175
HTTPS connection ID:134 to apis.tdameritrade.com:443 for request ID:134 (1) | Closed. | 2019-07-26 08:14:41.175
HTTPS connection ID:135 to apis.tdameritrade.com:443 for request ID:135 (1) | Creating socket. Using TLS 1.2. | 2019-07-26 08:17:40.656
HTTPS connection ID:135 to apis.tdameritrade.com:443 for request ID:135 (1) | Connecting to IP: 198.200.171.201. | 2019-07-26 08:17:40.656
HTTPS connection ID:135 to apis.tdameritrade.com:443 for request ID:135 (1) | Shutdown started. Waiting for graceful close. | 2019-07-26 08:17:41.106
HTTPS connection ID:135 to apis.tdameritrade.com:443 for request ID:135 (1) | Socket gracefully closed by remote side. | 2019-07-26 08:17:41.157
HTTPS connection ID:135 to apis.tdameritrade.com:443 for request ID:135 (1) | Closed. | 2019-07-26 08:17:41.158
HTTPS connection ID:136 to apis.tdameritrade.com:443 for request ID:136 (1) | Creating socket. Using TLS 1.2. | 2019-07-26 08:20:40.654
HTTPS connection ID:136 to apis.tdameritrade.com:443 for request ID:136 (1) | Connecting to IP: 198.200.171.201. | 2019-07-26 08:20:40.654
HTTPS connection ID:136 to apis.tdameritrade.com:443 for request ID:136 (1) | Shutdown started. Waiting for graceful close. | 2019-07-26 08:20:41.106
HTTPS connection ID:136 to apis.tdameritrade.com:443 for request ID:136 (1) | Socket gracefully closed by remote side. | 2019-07-26 08:20:41.162
HTTPS connection ID:136 to apis.tdameritrade.com:443 for request ID:136 (1) | Closed. | 2019-07-26 08:20:41.162
HTTPS connection ID:137 to apis.tdameritrade.com:443 for request ID:137 (1) | Creating socket. Using TLS 1.2. | 2019-07-26 08:23:40.651
HTTPS connection ID:137 to apis.tdameritrade.com:443 for request ID:137 (1) | Connecting to IP: 198.200.171.201. | 2019-07-26 08:23:40.652
HTTPS connection ID:137 to apis.tdameritrade.com:443 for request ID:137 (1) | Shutdown started. Waiting for graceful close. | 2019-07-26 08:23:41.125
HTTPS connection ID:137 to apis.tdameritrade.com:443 for request ID:137 (1) | Socket gracefully closed by remote side. | 2019-07-26 08:23:41.176
HTTPS connection ID:137 to apis.tdameritrade.com:443 for request ID:137 (1) | Closed. | 2019-07-26 08:23:41.176
HTTPS connection ID:138 to apis.tdameritrade.com:443 for request ID:138 (1) | Creating socket. Using TLS 1.2. | 2019-07-26 08:26:40.652
HTTPS connection ID:138 to apis.tdameritrade.com:443 for request ID:138 (1) | Connecting to IP: 198.200.171.201. | 2019-07-26 08:26:40.653
HTTPS connection ID:138 to apis.tdameritrade.com:443 for request ID:138 (1) | Shutdown started. Waiting for graceful close. | 2019-07-26 08:26:41.123
HTTPS connection ID:138 to apis.tdameritrade.com:443 for request ID:138 (1) | Socket gracefully closed by remote side. | 2019-07-26 08:26:41.172
HTTPS connection ID:138 to apis.tdameritrade.com:443 for request ID:138 (1) | Closed. | 2019-07-26 08:26:41.173
HTTPS connection ID:139 to apis.tdameritrade.com:443 for request ID:139 (1) | Creating socket. Using TLS 1.2. | 2019-07-26 08:29:40.655
HTTPS connection ID:139 to apis.tdameritrade.com:443 for request ID:139 (1) | Connecting to IP: 198.200.171.201. | 2019-07-26 08:29:40.655
HTTPS connection ID:139 to apis.tdameritrade.com:443 for request ID:139 (1) | Shutdown started. Waiting for graceful close. | 2019-07-26 08:29:41.105
HTTPS connection ID:139 to apis.tdameritrade.com:443 for request ID:139 (1) | Socket gracefully closed by remote side. | 2019-07-26 08:29:41.157
HTTPS connection ID:139 to apis.tdameritrade.com:443 for request ID:139 (1) | Closed. | 2019-07-26 08:29:41.157
HTTPS connection ID:140 to apis.tdameritrade.com:443 for request ID:140 (1) | Creating socket. Using TLS 1.2. | 2019-07-26 08:32:40.674
HTTPS connection ID:140 to apis.tdameritrade.com:443 for request ID:140 (1) | Connecting to IP: 198.200.171.201. | 2019-07-26 08:32:40.674
HTTPS connection ID:140 to apis.tdameritrade.com:443 for request ID:140 (1) | Shutdown started. Waiting for graceful close. | 2019-07-26 08:32:41.139
HTTPS connection ID:140 to apis.tdameritrade.com:443 for request ID:140 (1) | Socket gracefully closed by remote side. | 2019-07-26 08:32:41.193
HTTPS connection ID:140 to apis.tdameritrade.com:443 for request ID:140 (1) | Closed. | 2019-07-26 08:32:41.193
HTTPS connection ID:141 to apis.tdameritrade.com:443 for request ID:141 (1) | Creating socket. Using TLS 1.2. | 2019-07-26 08:35:40.653
HTTPS connection ID:141 to apis.tdameritrade.com:443 for request ID:141 (1) | Connecting to IP: 198.200.171.201. | 2019-07-26 08:35:40.654
HTTPS connection ID:141 to apis.tdameritrade.com:443 for request ID:141 (1) | Shutdown started. Waiting for graceful close. | 2019-07-26 08:35:41.109
HTTPS connection ID:141 to apis.tdameritrade.com:443 for request ID:141 (1) | Socket gracefully closed by remote side. | 2019-07-26 08:35:41.165
HTTPS connection ID:141 to apis.tdameritrade.com:443 for request ID:141 (1) | Closed. | 2019-07-26 08:35:41.165
HTTPS connection ID:142 to apis.tdameritrade.com:443 for request ID:142 (3) | Creating socket. Using TLS 1.2. | 2019-07-26 08:38:40.652
HTTPS connection ID:142 to apis.tdameritrade.com:443 for request ID:142 (3) | Connecting to IP: 198.200.171.201. | 2019-07-26 08:38:40.652
HTTPS connection ID:142 to apis.tdameritrade.com:443 for request ID:142 (3) | Shutdown started. Waiting for graceful close. | 2019-07-26 08:38:41.120
HTTPS connection ID:142 to apis.tdameritrade.com:443 for request ID:142 (3) | Socket gracefully closed by remote side. | 2019-07-26 08:38:41.172
HTTPS connection ID:142 to apis.tdameritrade.com:443 for request ID:142 (3) | Closed. | 2019-07-26 08:38:41.172
HTTPS connection ID:143 to apis.tdameritrade.com:443 for request ID:143 (1) | Creating socket. Using TLS 1.2. | 2019-07-26 08:41:40.652
HTTPS connection ID:143 to apis.tdameritrade.com:443 for request ID:143 (1) | Connecting to IP: 198.200.171.201. | 2019-07-26 08:41:40.652
HTTPS connection ID:143 to apis.tdameritrade.com:443 for request ID:143 (1) | Shutdown started. Waiting for graceful close. | 2019-07-26 08:41:41.124
HTTPS connection ID:143 to apis.tdameritrade.com:443 for request ID:143 (1) | Socket gracefully closed by remote side. | 2019-07-26 08:41:41.178
HTTPS connection ID:143 to apis.tdameritrade.com:443 for request ID:143 (1) | Closed. | 2019-07-26 08:41:41.178
HTTPS connection ID:144 to apis.tdameritrade.com:443 for request ID:144 (1) | Creating socket. Using TLS 1.2. | 2019-07-26 08:44:40.652
HTTPS connection ID:144 to apis.tdameritrade.com:443 for request ID:144 (1) | Connecting to IP: 198.200.171.201. | 2019-07-26 08:44:40.652
HTTPS connection ID:144 to apis.tdameritrade.com:443 for request ID:144 (1) | Shutdown started. Waiting for graceful close. | 2019-07-26 08:44:41.124
HTTPS connection ID:144 to apis.tdameritrade.com:443 for request ID:144 (1) | Socket gracefully closed by remote side. | 2019-07-26 08:44:41.182
HTTPS connection ID:144 to apis.tdameritrade.com:443 for request ID:144 (1) | Closed. | 2019-07-26 08:44:41.182
HTTPS connection ID:145 to apis.tdameritrade.com:443 for request ID:145 (1) | Creating socket. Using TLS 1.2. | 2019-07-26 08:47:40.653
HTTPS connection ID:145 to apis.tdameritrade.com:443 for request ID:145 (1) | Connecting to IP: 198.200.171.201. | 2019-07-26 08:47:40.653
HTTPS connection ID:145 to apis.tdameritrade.com:443 for request ID:145 (1) | Shutdown started. Waiting for graceful close. | 2019-07-26 08:47:41.110
HTTPS connection ID:145 to apis.tdameritrade.com:443 for request ID:145 (1) | Socket gracefully closed by remote side. | 2019-07-26 08:47:41.162
HTTPS connection ID:145 to apis.tdameritrade.com:443 for request ID:145 (1) | Closed. | 2019-07-26 08:47:41.162
HTTPS connection ID:146 to apis.tdameritrade.com:443 for request ID:146 (1) | Creating socket. Using TLS 1.2. | 2019-07-26 08:50:40.666
HTTPS connection ID:146 to apis.tdameritrade.com:443 for request ID:146 (1) | Connecting to IP: 198.200.171.201. | 2019-07-26 08:50:40.666
HTTPS connection ID:146 to apis.tdameritrade.com:443 for request ID:146 (1) | Shutdown started. Waiting for graceful close. | 2019-07-26 08:50:41.137
HTTPS connection ID:146 to apis.tdameritrade.com:443 for request ID:146 (1) | Socket gracefully closed by remote side. | 2019-07-26 08:50:41.189
HTTPS connection ID:146 to apis.tdameritrade.com:443 for request ID:146 (1) | Closed. | 2019-07-26 08:50:41.189
HTTPS connection ID:147 to apis.tdameritrade.com:443 for request ID:147 (1) | Creating socket. Using TLS 1.2. | 2019-07-26 08:53:40.652
HTTPS connection ID:147 to apis.tdameritrade.com:443 for request ID:147 (1) | Connecting to IP: 198.200.171.201. | 2019-07-26 08:53:40.652
HTTPS connection ID:147 to apis.tdameritrade.com:443 for request ID:147 (1) | Shutdown started. Waiting for graceful close. | 2019-07-26 08:53:41.121
HTTPS connection ID:147 to apis.tdameritrade.com:443 for request ID:147 (1) | Socket gracefully closed by remote side. | 2019-07-26 08:53:41.171
HTTPS connection ID:147 to apis.tdameritrade.com:443 for request ID:147 (1) | Closed. | 2019-07-26 08:53:41.171
HTTPS connection ID:148 to apis.tdameritrade.com:443 for request ID:148 (1) | Creating socket. Using TLS 1.2. | 2019-07-26 08:56:40.652
HTTPS connection ID:148 to apis.tdameritrade.com:443 for request ID:148 (1) | Connecting to IP: 198.200.171.201. | 2019-07-26 08:56:40.652
HTTPS connection ID:148 to apis.tdameritrade.com:443 for request ID:148 (1) | Shutdown started. Waiting for graceful close. | 2019-07-26 08:56:41.136
HTTPS connection ID:148 to apis.tdameritrade.com:443 for request ID:148 (1) | Socket gracefully closed by remote side. | 2019-07-26 08:56:41.187
HTTPS connection ID:148 to apis.tdameritrade.com:443 for request ID:148 (1) | Closed. | 2019-07-26 08:56:41.187
HTTPS connection ID:149 to apis.tdameritrade.com:443 for request ID:149 (1) | Creating socket. Using TLS 1.2. | 2019-07-26 08:59:40.652
HTTPS connection ID:149 to apis.tdameritrade.com:443 for request ID:149 (1) | Connecting to IP: 198.200.171.201. | 2019-07-26 08:59:40.652
HTTPS connection ID:149 to apis.tdameritrade.com:443 for request ID:149 (1) | Shutdown started. Waiting for graceful close. | 2019-07-26 08:59:41.105
HTTPS connection ID:149 to apis.tdameritrade.com:443 for request ID:149 (1) | Socket gracefully closed by remote side. | 2019-07-26 08:59:41.156
HTTPS connection ID:149 to apis.tdameritrade.com:443 for request ID:149 (1) | Closed. | 2019-07-26 08:59:41.156
HTTPS connection ID:150 to apis.tdameritrade.com:443 for request ID:150 (1) | Creating socket. Using TLS 1.2. | 2019-07-26 09:02:40.655
HTTPS connection ID:150 to apis.tdameritrade.com:443 for request ID:150 (1) | Connecting to IP: 198.200.171.201. | 2019-07-26 09:02:40.656
HTTPS connection ID:150 to apis.tdameritrade.com:443 for request ID:150 (1) | Shutdown started. Waiting for graceful close. | 2019-07-26 09:02:41.109
HTTPS connection ID:150 to apis.tdameritrade.com:443 for request ID:150 (1) | Socket gracefully closed by remote side. | 2019-07-26 09:02:41.159
HTTPS connection ID:150 to apis.tdameritrade.com:443 for request ID:150 (1) | Closed. | 2019-07-26 09:02:41.159
HTTPS connection ID:151 to apis.tdameritrade.com:443 for request ID:151 (1) | Creating socket. Using TLS 1.2. | 2019-07-26 09:05:40.652
HTTPS connection ID:151 to apis.tdameritrade.com:443 for request ID:151 (1) | Connecting to IP: 198.200.171.201. | 2019-07-26 09:05:40.652
HTTPS connection ID:151 to apis.tdameritrade.com:443 for request ID:151 (1) | Shutdown started. Waiting for graceful close. | 2019-07-26 09:05:41.109
HTTPS connection ID:151 to apis.tdameritrade.com:443 for request ID:151 (1) | Socket gracefully closed by remote side. | 2019-07-26 09:05:41.161
HTTPS connection ID:151 to apis.tdameritrade.com:443 for request ID:151 (1) | Closed. | 2019-07-26 09:05:41.162
HTTPS connection ID:152 to apis.tdameritrade.com:443 for request ID:152 (1) | Creating socket. Using TLS 1.2. | 2019-07-26 09:08:40.670
HTTPS connection ID:152 to apis.tdameritrade.com:443 for request ID:152 (1) | Connecting to IP: 198.200.171.201. | 2019-07-26 09:08:40.671
HTTPS connection ID:152 to apis.tdameritrade.com:443 for request ID:152 (1) | Shutdown started. Waiting for graceful close. | 2019-07-26 09:08:41.137
HTTPS connection ID:152 to apis.tdameritrade.com:443 for request ID:152 (1) | Socket gracefully closed by remote side. | 2019-07-26 09:08:41.194
HTTPS connection ID:152 to apis.tdameritrade.com:443 for request ID:152 (1) | Closed. | 2019-07-26 09:08:41.194
HTTPS connection ID:153 to apis.tdameritrade.com:443 for request ID:153 (1) | Creating socket. Using TLS 1.2. | 2019-07-26 09:11:40.652
HTTPS connection ID:153 to apis.tdameritrade.com:443 for request ID:153 (1) | Connecting to IP: 198.200.171.201. | 2019-07-26 09:11:40.652
HTTPS connection ID:153 to apis.tdameritrade.com:443 for request ID:153 (1) | Shutdown started. Waiting for graceful close. | 2019-07-26 09:11:41.120
HTTPS connection ID:153 to apis.tdameritrade.com:443 for request ID:153 (1) | Socket gracefully closed by remote side. | 2019-07-26 09:11:41.174
HTTPS connection ID:153 to apis.tdameritrade.com:443 for request ID:153 (1) | Closed. | 2019-07-26 09:11:41.174
HTTPS connection ID:154 to apis.tdameritrade.com:443 for request ID:154 (1) | Creating socket. Using TLS 1.2. | 2019-07-26 09:14:40.651
HTTPS connection ID:154 to apis.tdameritrade.com:443 for request ID:154 (1) | Connecting to IP: 198.200.171.201. | 2019-07-26 09:14:40.651
HTTPS connection ID:154 to apis.tdameritrade.com:443 for request ID:154 (1) | Shutdown started. Waiting for graceful close. | 2019-07-26 09:14:41.105
HTTPS connection ID:154 to apis.tdameritrade.com:443 for request ID:154 (1) | Socket gracefully closed by remote side. | 2019-07-26 09:14:41.157
HTTPS connection ID:154 to apis.tdameritrade.com:443 for request ID:154 (1) | Closed. | 2019-07-26 09:14:41.157
HTTPS connection ID:155 to apis.tdameritrade.com:443 for request ID:155 (1) | Creating socket. Using TLS 1.2. | 2019-07-26 09:17:40.652
HTTPS connection ID:155 to apis.tdameritrade.com:443 for request ID:155 (1) | Connecting to IP: 198.200.171.201. | 2019-07-26 09:17:40.652
HTTPS connection ID:155 to apis.tdameritrade.com:443 for request ID:155 (1) | Shutdown started. Waiting for graceful close. | 2019-07-26 09:17:41.105
HTTPS connection ID:155 to apis.tdameritrade.com:443 for request ID:155 (1) | Socket gracefully closed by remote side. | 2019-07-26 09:17:41.158
HTTPS connection ID:155 to apis.tdameritrade.com:443 for request ID:155 (1) | Closed. | 2019-07-26 09:17:41.158
HTTPS connection ID:156 to apis.tdameritrade.com:443 for request ID:156 (1) | Creating socket. Using TLS 1.2. | 2019-07-26 09:18:34.545
HTTPS connection ID:156 to apis.tdameritrade.com:443 for request ID:156 (1) | Connecting to IP: 198.200.171.201. | 2019-07-26 09:18:34.545
HTTPS connection ID:156 to apis.tdameritrade.com:443 for request ID:156 (1) | Shutdown started. Waiting for graceful close. | 2019-07-26 09:18:35.043
HTTPS connection ID:156 to apis.tdameritrade.com:443 for request ID:156 (1) | Socket gracefully closed by remote side. | 2019-07-26 09:18:35.093
HTTPS connection ID:156 to apis.tdameritrade.com:443 for request ID:156 (1) | Closed. | 2019-07-26 09:18:35.094
HTTPS connection ID:157 to apis.tdameritrade.com:443 for request ID:157 (1) | Creating socket. Using TLS 1.2. | 2019-07-26 09:18:36.046
HTTPS connection ID:157 to apis.tdameritrade.com:443 for request ID:157 (1) | Connecting to IP: 198.200.171.201. | 2019-07-26 09:18:36.046
HTTPS connection ID:158 to apis.tdameritrade.com:443 for request ID:158 (3) | Creating socket. Using TLS 1.2. | 2019-07-26 09:18:36.046
HTTPS connection ID:158 to apis.tdameritrade.com:443 for request ID:158 (3) | Connecting to IP: 198.200.171.201. | 2019-07-26 09:18:36.046
HTTPS connection ID:159 to apis.tdameritrade.com:443 for request ID:159 (4) | Creating socket. Using TLS 1.2. | 2019-07-26 09:18:36.046
HTTPS connection ID:159 to apis.tdameritrade.com:443 for request ID:159 (4) | Connecting to IP: 198.200.171.201. | 2019-07-26 09:18:36.046
HTTPS connection ID:160 to apis.tdameritrade.com:443 for request ID:160 (5) | Creating socket. Using TLS 1.2. | 2019-07-26 09:18:36.046
HTTPS connection ID:160 to apis.tdameritrade.com:443 for request ID:160 (5) | Connecting to IP: 198.200.171.201. | 2019-07-26 09:18:36.046
HTTPS connection ID:160 to apis.tdameritrade.com:443 for request ID:160 (5) | Shutdown started. Waiting for graceful close. | 2019-07-26 09:18:36.560
HTTPS connection ID:159 to apis.tdameritrade.com:443 for request ID:159 (4) | Shutdown started. Waiting for graceful close. | 2019-07-26 09:18:36.561
HTTPS connection ID:158 to apis.tdameritrade.com:443 for request ID:158 (3) | Shutdown started. Waiting for graceful close. | 2019-07-26 09:18:36.561
HTTPS connection ID:157 to apis.tdameritrade.com:443 for request ID:157 (1) | Shutdown started. Waiting for graceful close. | 2019-07-26 09:18:36.562
HTTPS connection ID:160 to apis.tdameritrade.com:443 for request ID:160 (5) | Socket gracefully closed by remote side. | 2019-07-26 09:18:36.611
HTTPS connection ID:160 to apis.tdameritrade.com:443 for request ID:160 (5) | Closed. | 2019-07-26 09:18:36.611
HTTPS connection ID:159 to apis.tdameritrade.com:443 for request ID:159 (4) | Socket gracefully closed by remote side. | 2019-07-26 09:18:36.611
HTTPS connection ID:159 to apis.tdameritrade.com:443 for request ID:159 (4) | Closed. | 2019-07-26 09:18:36.611
HTTPS connection ID:158 to apis.tdameritrade.com:443 for request ID:158 (3) | Socket gracefully closed by remote side. | 2019-07-26 09:18:36.616
HTTPS connection ID:158 to apis.tdameritrade.com:443 for request ID:158 (3) | Closed. | 2019-07-26 09:18:36.616
HTTPS connection ID:157 to apis.tdameritrade.com:443 for request ID:157 (1) | Socket gracefully closed by remote side. | 2019-07-26 09:18:36.616
HTTPS connection ID:157 to apis.tdameritrade.com:443 for request ID:157 (1) | Closed. | 2019-07-26 09:18:36.616
HTTPS connection ID:161 to apis.tdameritrade.com:443 for request ID:161 (1) | Creating socket. Using TLS 1.2. | 2019-07-26 09:18:51.198
HTTPS connection ID:161 to apis.tdameritrade.com:443 for request ID:161 (1) | Connecting to IP: 198.200.171.201. | 2019-07-26 09:18:51.198
HTTPS connection ID:162 to apis.tdameritrade.com:443 for request ID:162 (3) | Creating socket. Using TLS 1.2. | 2019-07-26 09:18:51.403
HTTPS connection ID:162 to apis.tdameritrade.com:443 for request ID:162 (3) | Connecting to IP: 198.200.171.201. | 2019-07-26 09:18:51.403
HTTPS connection ID:161 to apis.tdameritrade.com:443 for request ID:161 (1) | Shutdown started. Waiting for graceful close. | 2019-07-26 09:18:51.683
HTTPS connection ID:161 to apis.tdameritrade.com:443 for request ID:161 (1) | Socket gracefully closed by remote side. | 2019-07-26 09:18:51.737
HTTPS connection ID:161 to apis.tdameritrade.com:443 for request ID:161 (1) | Closed. | 2019-07-26 09:18:51.737
HTTPS connection ID:162 to apis.tdameritrade.com:443 for request ID:162 (3) | Shutdown started. Waiting for graceful close. | 2019-07-26 09:18:51.887
HTTPS connection ID:162 to apis.tdameritrade.com:443 for request ID:162 (3) | Socket gracefully closed by remote side. | 2019-07-26 09:18:51.944
HTTPS connection ID:162 to apis.tdameritrade.com:443 for request ID:162 (3) | Closed. | 2019-07-26 09:18:51.944
HTTPS connection ID:163 to apis.tdameritrade.com:443 for request ID:163 (1) | Creating socket. Using TLS 1.2. | 2019-07-26 09:18:51.967
HTTPS connection ID:163 to apis.tdameritrade.com:443 for request ID:163 (1) | Connecting to IP: 198.200.171.201. | 2019-07-26 09:18:51.968
HTTPS connection ID:163 to apis.tdameritrade.com:443 for request ID:163 (1) | Shutdown started. Waiting for graceful close. | 2019-07-26 09:18:52.453
HTTPS connection ID:163 to apis.tdameritrade.com:443 for request ID:163 (1) | Socket gracefully closed by remote side. | 2019-07-26 09:18:52.504
HTTPS connection ID:163 to apis.tdameritrade.com:443 for request ID:163 (1) | Closed. | 2019-07-26 09:18:52.504
HTTPS connection ID:164 to apis.tdameritrade.com:443 for request ID:164 (1) | Creating socket. Using TLS 1.2. | 2019-07-26 09:18:53.464
HTTPS connection ID:164 to apis.tdameritrade.com:443 for request ID:164 (1) | Connecting to IP: 198.200.171.201. | 2019-07-26 09:18:53.465
HTTPS connection ID:165 to apis.tdameritrade.com:443 for request ID:165 (3) | Creating socket. Using TLS 1.2. | 2019-07-26 09:18:53.465
HTTPS connection ID:165 to apis.tdameritrade.com:443 for request ID:165 (3) | Connecting to IP: 198.200.171.201. | 2019-07-26 09:18:53.465
HTTPS connection ID:166 to apis.tdameritrade.com:443 for request ID:166 (4) | Creating socket. Using TLS 1.2. | 2019-07-26 09:18:53.465
HTTPS connection ID:166 to apis.tdameritrade.com:443 for request ID:166 (4) | Connecting to IP: 198.200.171.201. | 2019-07-26 09:18:53.465
HTTPS connection ID:167 to apis.tdameritrade.com:443 for request ID:167 (5) | Creating socket. Using TLS 1.2. | 2019-07-26 09:18:53.465
HTTPS connection ID:167 to apis.tdameritrade.com:443 for request ID:167 (5) | Connecting to IP: 198.200.171.201. | 2019-07-26 09:18:53.465
HTTPS connection ID:165 to apis.tdameritrade.com:443 for request ID:165 (3) | Shutdown started. Waiting for graceful close. | 2019-07-26 09:18:55.029
HTTPS connection ID:165 to apis.tdameritrade.com:443 for request ID:165 (3) | Socket gracefully closed by remote side. | 2019-07-26 09:18:55.082
HTTPS connection ID:165 to apis.tdameritrade.com:443 for request ID:165 (3) | Closed. | 2019-07-26 09:18:55.082
HTTPS connection ID:166 to apis.tdameritrade.com:443 for request ID:166 (4) | Shutdown started. Waiting for graceful close. | 2019-07-26 09:18:55.107
HTTPS connection ID:164 to apis.tdameritrade.com:443 for request ID:164 (1) | Shutdown started. Waiting for graceful close. | 2019-07-26 09:18:55.122
HTTPS connection ID:166 to apis.tdameritrade.com:443 for request ID:166 (4) | Socket gracefully closed by remote side. | 2019-07-26 09:18:55.160
HTTPS connection ID:166 to apis.tdameritrade.com:443 for request ID:166 (4) | Closed. | 2019-07-26 09:18:55.160
HTTPS connection ID:167 to apis.tdameritrade.com:443 for request ID:167 (5) | Shutdown started. Waiting for graceful close. | 2019-07-26 09:18:55.171
HTTPS connection ID:164 to apis.tdameritrade.com:443 for request ID:164 (1) | Socket gracefully closed by remote side. | 2019-07-26 09:18:55.172
HTTPS connection ID:164 to apis.tdameritrade.com:443 for request ID:164 (1) | Closed. | 2019-07-26 09:18:55.172
HTTPS connection ID:167 to apis.tdameritrade.com:443 for request ID:167 (5) | Socket gracefully closed by remote side. | 2019-07-26 09:18:55.232
HTTPS connection ID:167 to apis.tdameritrade.com:443 for request ID:167 (5) | Closed. | 2019-07-26 09:18:55.232
HTTPS connection ID:168 to apis.tdameritrade.com:443 for request ID:168 (1) | Creating socket. Using TLS 1.2. | 2019-07-26 09:19:20.604
HTTPS connection ID:168 to apis.tdameritrade.com:443 for request ID:168 (1) | Connecting to IP: 198.200.171.201. | 2019-07-26 09:19:20.604
HTTPS connection ID:169 to apis.tdameritrade.com:443 for request ID:169 (3) | Creating socket. Using TLS 1.2. | 2019-07-26 09:19:20.605
HTTPS connection ID:169 to apis.tdameritrade.com:443 for request ID:169 (3) | Connecting to IP: 198.200.171.201. | 2019-07-26 09:19:20.605
HTTPS connection ID:170 to apis.tdameritrade.com:443 for request ID:170 (4) | Creating socket. Using TLS 1.2. | 2019-07-26 09:19:20.605
HTTPS connection ID:170 to apis.tdameritrade.com:443 for request ID:170 (4) | Connecting to IP: 198.200.171.201. | 2019-07-26 09:19:20.605
HTTPS connection ID:171 to apis.tdameritrade.com:443 for request ID:171 (5) | Creating socket. Using TLS 1.2. | 2019-07-26 09:19:20.605
HTTPS connection ID:171 to apis.tdameritrade.com:443 for request ID:171 (5) | Connecting to IP: 198.200.171.201. | 2019-07-26 09:19:20.605
HTTPS connection ID:168 to apis.tdameritrade.com:443 for request ID:168 (1) | Shutdown started. Waiting for graceful close. | 2019-07-26 09:19:21.107
HTTPS connection ID:170 to apis.tdameritrade.com:443 for request ID:170 (4) | Shutdown started. Waiting for graceful close. | 2019-07-26 09:19:21.107
HTTPS connection ID:169 to apis.tdameritrade.com:443 for request ID:169 (3) | Shutdown started. Waiting for graceful close. | 2019-07-26 09:19:21.107
HTTPS connection ID:171 to apis.tdameritrade.com:443 for request ID:171 (5) | Shutdown started. Waiting for graceful close. | 2019-07-26 09:19:21.107
HTTPS connection ID:168 to apis.tdameritrade.com:443 for request ID:168 (1) | Socket gracefully closed by remote side. | 2019-07-26 09:19:21.156
HTTPS connection ID:168 to apis.tdameritrade.com:443 for request ID:168 (1) | Closed. | 2019-07-26 09:19:21.156
HTTPS connection ID:170 to apis.tdameritrade.com:443 for request ID:170 (4) | Socket gracefully closed by remote side. | 2019-07-26 09:19:21.161
HTTPS connection ID:170 to apis.tdameritrade.com:443 for request ID:170 (4) | Closed. | 2019-07-26 09:19:21.162
HTTPS connection ID:169 to apis.tdameritrade.com:443 for request ID:169 (3) | Socket gracefully closed by remote side. | 2019-07-26 09:19:21.162
HTTPS connection ID:169 to apis.tdameritrade.com:443 for request ID:169 (3) | Closed. | 2019-07-26 09:19:21.162
HTTPS connection ID:171 to apis.tdameritrade.com:443 for request ID:171 (5) | Socket gracefully closed by remote side. | 2019-07-26 09:19:21.162
HTTPS connection ID:171 to apis.tdameritrade.com:443 for request ID:171 (5) | Closed. | 2019-07-26 09:19:21.162
HTTPS connection ID:172 to apis.tdameritrade.com:443 for request ID:172 (1) | Creating socket. Using TLS 1.2. | 2019-07-26 09:20:40.655
HTTPS connection ID:172 to apis.tdameritrade.com:443 for request ID:172 (1) | Connecting to IP: 198.200.171.201. | 2019-07-26 09:20:40.655
HTTPS connection ID:172 to apis.tdameritrade.com:443 for request ID:172 (1) | Shutdown started. Waiting for graceful close. | 2019-07-26 09:20:41.121
HTTPS connection ID:172 to apis.tdameritrade.com:443 for request ID:172 (1) | Socket gracefully closed by remote side. | 2019-07-26 09:20:41.176
HTTPS connection ID:172 to apis.tdameritrade.com:443 for request ID:172 (1) | Closed. | 2019-07-26 09:20:41.176
HTTPS connection ID:173 to apis.tdameritrade.com:443 for request ID:173 (1) | Creating socket. Using TLS 1.2. | 2019-07-26 09:23:40.656
HTTPS connection ID:173 to apis.tdameritrade.com:443 for request ID:173 (1) | Connecting to IP: 198.200.171.201. | 2019-07-26 09:23:40.657
HTTPS connection ID:173 to apis.tdameritrade.com:443 for request ID:173 (1) | Shutdown started. Waiting for graceful close. | 2019-07-26 09:23:41.109
HTTPS connection ID:173 to apis.tdameritrade.com:443 for request ID:173 (1) | Socket gracefully closed by remote side. | 2019-07-26 09:23:41.163
HTTPS connection ID:173 to apis.tdameritrade.com:443 for request ID:173 (1) | Closed. | 2019-07-26 09:23:41.163
HTTPS connection ID:174 to apis.tdameritrade.com:443 for request ID:174 (1) | Creating socket. Using TLS 1.2. | 2019-07-26 09:26:40.666
HTTPS connection ID:174 to apis.tdameritrade.com:443 for request ID:174 (1) | Connecting to IP: 198.200.171.201. | 2019-07-26 09:26:40.666
HTTPS connection ID:174 to apis.tdameritrade.com:443 for request ID:174 (1) | Shutdown started. Waiting for graceful close. | 2019-07-26 09:26:41.139
HTTPS connection ID:174 to apis.tdameritrade.com:443 for request ID:174 (1) | Socket gracefully closed by remote side. | 2019-07-26 09:26:41.189
HTTPS connection ID:174 to apis.tdameritrade.com:443 for request ID:174 (1) | Closed. | 2019-07-26 09:26:41.189
HTTPS connection ID:175 to apis.tdameritrade.com:443 for request ID:175 (1) | Creating socket. Using TLS 1.2. | 2019-07-26 09:29:40.652
HTTPS connection ID:175 to apis.tdameritrade.com:443 for request ID:175 (1) | Connecting to IP: 198.200.171.201. | 2019-07-26 09:29:40.652
HTTPS connection ID:175 to apis.tdameritrade.com:443 for request ID:175 (1) | Shutdown started. Waiting for graceful close. | 2019-07-26 09:29:41.121
HTTPS connection ID:175 to apis.tdameritrade.com:443 for request ID:175 (1) | Socket gracefully closed by remote side. | 2019-07-26 09:29:41.173
HTTPS connection ID:175 to apis.tdameritrade.com:443 for request ID:175 (1) | Closed. | 2019-07-26 09:29:41.173
HTTPS connection ID:176 to apis.tdameritrade.com:443 for request ID:176 (1) | Creating socket. Using TLS 1.2. | 2019-07-26 09:32:40.655
HTTPS connection ID:176 to apis.tdameritrade.com:443 for request ID:176 (1) | Connecting to IP: 198.200.171.201. | 2019-07-26 09:32:40.655
HTTPS connection ID:176 to apis.tdameritrade.com:443 for request ID:176 (1) | Shutdown started. Waiting for graceful close. | 2019-07-26 09:32:41.107
HTTPS connection ID:176 to apis.tdameritrade.com:443 for request ID:176 (1) | Socket gracefully closed by remote side. | 2019-07-26 09:32:41.160
HTTPS connection ID:176 to apis.tdameritrade.com:443 for request ID:176 (1) | Closed. | 2019-07-26 09:32:41.160
HTTPS connection ID:177 to apis.tdameritrade.com:443 for request ID:177 (1) | Creating socket. Using TLS 1.2. | 2019-07-26 09:35:40.651
HTTPS connection ID:177 to apis.tdameritrade.com:443 for request ID:177 (1) | Connecting to IP: 198.200.171.201. | 2019-07-26 09:35:40.651
HTTPS connection ID:177 to apis.tdameritrade.com:443 for request ID:177 (1) | Shutdown started. Waiting for graceful close. | 2019-07-26 09:35:41.106
HTTPS connection ID:177 to apis.tdameritrade.com:443 for request ID:177 (1) | Socket gracefully closed by remote side. | 2019-07-26 09:35:41.157
HTTPS connection ID:177 to apis.tdameritrade.com:443 for request ID:177 (1) | Closed. | 2019-07-26 09:35:41.157
HTTPS connection ID:178 to apis.tdameritrade.com:443 for request ID:178 (1) | Creating socket. Using TLS 1.2. | 2019-07-26 09:38:40.654
HTTPS connection ID:178 to apis.tdameritrade.com:443 for request ID:178 (1) | Connecting to IP: 198.200.171.201. | 2019-07-26 09:38:40.654
HTTPS connection ID:178 to apis.tdameritrade.com:443 for request ID:178 (1) | Shutdown started. Waiting for graceful close. | 2019-07-26 09:38:41.136
HTTPS connection ID:178 to apis.tdameritrade.com:443 for request ID:178 (1) | Socket gracefully closed by remote side. | 2019-07-26 09:38:41.192
HTTPS connection ID:178 to apis.tdameritrade.com:443 for request ID:178 (1) | Closed. | 2019-07-26 09:38:41.192
HTTPS connection ID:179 to apis.tdameritrade.com:443 for request ID:179 (1) | Creating socket. Using TLS 1.2. | 2019-07-26 09:41:40.653
HTTPS connection ID:179 to apis.tdameritrade.com:443 for request ID:179 (1) | Connecting to IP: 198.200.171.201. | 2019-07-26 09:41:40.653
HTTPS connection ID:179 to apis.tdameritrade.com:443 for request ID:179 (1) | Shutdown started. Waiting for graceful close. | 2019-07-26 09:41:41.123
HTTPS connection ID:179 to apis.tdameritrade.com:443 for request ID:179 (1) | Socket gracefully closed by remote side. | 2019-07-26 09:41:41.177
HTTPS connection ID:179 to apis.tdameritrade.com:443 for request ID:179 (1) | Closed. | 2019-07-26 09:41:41.177
HTTPS connection ID:180 to apis.tdameritrade.com:443 for request ID:180 (1) | Creating socket. Using TLS 1.2. | 2019-07-26 09:44:40.669
HTTPS connection ID:180 to apis.tdameritrade.com:443 for request ID:180 (1) | Connecting to IP: 198.200.171.201. | 2019-07-26 09:44:40.669
HTTPS connection ID:180 to apis.tdameritrade.com:443 for request ID:180 (1) | Shutdown started. Waiting for graceful close. | 2019-07-26 09:44:41.121
HTTPS connection ID:180 to apis.tdameritrade.com:443 for request ID:180 (1) | Socket gracefully closed by remote side. | 2019-07-26 09:44:41.177
HTTPS connection ID:180 to apis.tdameritrade.com:443 for request ID:180 (1) | Closed. | 2019-07-26 09:44:41.177
HTTPS connection ID:181 to apis.tdameritrade.com:443 for request ID:181 (1) | Creating socket. Using TLS 1.2. | 2019-07-26 09:47:40.652
HTTPS connection ID:181 to apis.tdameritrade.com:443 for request ID:181 (1) | Connecting to IP: 198.200.171.201. | 2019-07-26 09:47:40.652
HTTPS connection ID:181 to apis.tdameritrade.com:443 for request ID:181 (1) | Shutdown started. Waiting for graceful close. | 2019-07-26 09:47:41.123
HTTPS connection ID:181 to apis.tdameritrade.com:443 for request ID:181 (1) | Socket gracefully closed by remote side. | 2019-07-26 09:47:41.179
HTTPS connection ID:181 to apis.tdameritrade.com:443 for request ID:181 (1) | Closed. | 2019-07-26 09:47:41.179
HTTPS connection ID:182 to apis.tdameritrade.com:443 for request ID:182 (1) | Creating socket. Using TLS 1.2. | 2019-07-26 09:50:40.654
HTTPS connection ID:182 to apis.tdameritrade.com:443 for request ID:182 (1) | Connecting to IP: 198.200.171.201. | 2019-07-26 09:50:40.654
HTTPS connection ID:182 to apis.tdameritrade.com:443 for request ID:182 (1) | Shutdown started. Waiting for graceful close. | 2019-07-26 09:50:41.105
HTTPS connection ID:182 to apis.tdameritrade.com:443 for request ID:182 (1) | Socket gracefully closed by remote side. | 2019-07-26 09:50:41.154
HTTPS connection ID:182 to apis.tdameritrade.com:443 for request ID:182 (1) | Closed. | 2019-07-26 09:50:41.154
HTTPS connection ID:183 to apis.tdameritrade.com:443 for request ID:183 (1) | Creating socket. Using TLS 1.2. | 2019-07-26 09:53:40.653
HTTPS connection ID:183 to apis.tdameritrade.com:443 for request ID:183 (1) | Connecting to IP: 198.200.171.201. | 2019-07-26 09:53:40.653
HTTPS connection ID:183 to apis.tdameritrade.com:443 for request ID:183 (1) | Shutdown started. Waiting for graceful close. | 2019-07-26 09:53:41.121
HTTPS connection ID:183 to apis.tdameritrade.com:443 for request ID:183 (1) | Socket gracefully closed by remote side. | 2019-07-26 09:53:41.178
HTTPS connection ID:183 to apis.tdameritrade.com:443 for request ID:183 (1) | Closed. | 2019-07-26 09:53:41.178
HTTPS connection ID:184 to apis.tdameritrade.com:443 for request ID:184 (1) | Creating socket. Using TLS 1.2. | 2019-07-26 09:56:40.654
HTTPS connection ID:184 to apis.tdameritrade.com:443 for request ID:184 (1) | Connecting to IP: 198.200.171.201. | 2019-07-26 09:56:40.654
HTTPS connection ID:184 to apis.tdameritrade.com:443 for request ID:184 (1) | Shutdown started. Waiting for graceful close. | 2019-07-26 09:56:41.108
HTTPS connection ID:184 to apis.tdameritrade.com:443 for request ID:184 (1) | Socket gracefully closed by remote side. | 2019-07-26 09:56:41.158
HTTPS connection ID:184 to apis.tdameritrade.com:443 for request ID:184 (1) | Closed. | 2019-07-26 09:56:41.158
HTTPS connection ID:185 to apis.tdameritrade.com:443 for request ID:185 (1) | Creating socket. Using TLS 1.2. | 2019-07-26 09:59:40.654
HTTPS connection ID:185 to apis.tdameritrade.com:443 for request ID:185 (1) | Connecting to IP: 198.200.171.201. | 2019-07-26 09:59:40.654
HTTPS connection ID:185 to apis.tdameritrade.com:443 for request ID:185 (1) | Shutdown started. Waiting for graceful close. | 2019-07-26 09:59:41.123
HTTPS connection ID:185 to apis.tdameritrade.com:443 for request ID:185 (1) | Socket gracefully closed by remote side. | 2019-07-26 09:59:41.174
HTTPS connection ID:185 to apis.tdameritrade.com:443 for request ID:185 (1) | Closed. | 2019-07-26 09:59:41.174
HTTPS connection ID:186 to apis.tdameritrade.com:443 for request ID:186 (1) | Creating socket. Using TLS 1.2. | 2019-07-26 10:02:40.672
HTTPS connection ID:186 to apis.tdameritrade.com:443 for request ID:186 (1) | Connecting to IP: 198.200.171.201. | 2019-07-26 10:02:40.672
HTTPS connection ID:186 to apis.tdameritrade.com:443 for request ID:186 (1) | Shutdown started. Waiting for graceful close. | 2019-07-26 10:02:41.121
HTTPS connection ID:186 to apis.tdameritrade.com:443 for request ID:186 (1) | Socket gracefully closed by remote side. | 2019-07-26 10:02:41.171
HTTPS connection ID:186 to apis.tdameritrade.com:443 for request ID:186 (1) | Closed. | 2019-07-26 10:02:41.171
HTTPS connection ID:187 to apis.tdameritrade.com:443 for request ID:187 (1) | Creating socket. Using TLS 1.2. | 2019-07-26 10:05:40.654
HTTPS connection ID:187 to apis.tdameritrade.com:443 for request ID:187 (1) | Connecting to IP: 198.200.171.201. | 2019-07-26 10:05:40.654
HTTPS connection ID:187 to apis.tdameritrade.com:443 for request ID:187 (1) | Shutdown started. Waiting for graceful close. | 2019-07-26 10:05:41.121
HTTPS connection ID:187 to apis.tdameritrade.com:443 for request ID:187 (1) | Socket gracefully closed by remote side. | 2019-07-26 10:05:41.176
HTTPS connection ID:187 to apis.tdameritrade.com:443 for request ID:187 (1) | Closed. | 2019-07-26 10:05:41.176
HTTPS connection ID:188 to apis.tdameritrade.com:443 for request ID:188 (3) | Creating socket. Using TLS 1.2. | 2019-07-26 10:08:40.653
HTTPS connection ID:188 to apis.tdameritrade.com:443 for request ID:188 (3) | Connecting to IP: 198.200.171.201. | 2019-07-26 10:08:40.653
HTTPS connection ID:188 to apis.tdameritrade.com:443 for request ID:188 (3) | Shutdown started. Waiting for graceful close. | 2019-07-26 10:08:41.120
HTTPS connection ID:188 to apis.tdameritrade.com:443 for request ID:188 (3) | Socket gracefully closed by remote side. | 2019-07-26 10:08:41.179
HTTPS connection ID:188 to apis.tdameritrade.com:443 for request ID:188 (3) | Closed. | 2019-07-26 10:08:41.179
HTTPS connection ID:189 to apis.tdameritrade.com:443 for request ID:189 (1) | Creating socket. Using TLS 1.2. | 2019-07-26 10:11:40.652
HTTPS connection ID:189 to apis.tdameritrade.com:443 for request ID:189 (1) | Connecting to IP: 198.200.171.201. | 2019-07-26 10:11:40.652
HTTPS connection ID:189 to apis.tdameritrade.com:443 for request ID:189 (1) | Shutdown started. Waiting for graceful close. | 2019-07-26 10:11:41.120
HTTPS connection ID:189 to apis.tdameritrade.com:443 for request ID:189 (1) | Socket gracefully closed by remote side. | 2019-07-26 10:11:41.171
HTTPS connection ID:189 to apis.tdameritrade.com:443 for request ID:189 (1) | Closed. | 2019-07-26 10:11:41.171
HTTPS connection ID:190 to apis.tdameritrade.com:443 for request ID:190 (1) | Creating socket. Using TLS 1.2. | 2019-07-26 10:14:40.652
HTTPS connection ID:190 to apis.tdameritrade.com:443 for request ID:190 (1) | Connecting to IP: 198.200.171.201. | 2019-07-26 10:14:40.653
HTTPS connection ID:190 to apis.tdameritrade.com:443 for request ID:190 (1) | Shutdown started. Waiting for graceful close. | 2019-07-26 10:14:41.121
HTTPS connection ID:190 to apis.tdameritrade.com:443 for request ID:190 (1) | Socket gracefully closed by remote side. | 2019-07-26 10:14:41.171
HTTPS connection ID:190 to apis.tdameritrade.com:443 for request ID:190 (1) | Closed. | 2019-07-26 10:14:41.171
HTTPS connection ID:191 to apis.tdameritrade.com:443 for request ID:191 (1) | Creating socket. Using TLS 1.2. | 2019-07-26 10:17:40.652
HTTPS connection ID:191 to apis.tdameritrade.com:443 for request ID:191 (1) | Connecting to IP: 198.200.171.201. | 2019-07-26 10:17:40.652
HTTPS connection ID:191 to apis.tdameritrade.com:443 for request ID:191 (1) | Shutdown started. Waiting for graceful close. | 2019-07-26 10:17:41.104
HTTPS connection ID:191 to apis.tdameritrade.com:443 for request ID:191 (1) | Socket gracefully closed by remote side. | 2019-07-26 10:17:41.159
HTTPS connection ID:191 to apis.tdameritrade.com:443 for request ID:191 (1) | Closed. | 2019-07-26 10:17:41.159
HTTPS connection ID:192 to apis.tdameritrade.com:443 for request ID:192 (1) | Creating socket. Using TLS 1.2. | 2019-07-26 10:20:40.672
HTTPS connection ID:192 to apis.tdameritrade.com:443 for request ID:192 (1) | Connecting to IP: 198.200.171.201. | 2019-07-26 10:20:40.672
HTTPS connection ID:192 to apis.tdameritrade.com:443 for request ID:192 (1) | Shutdown started. Waiting for graceful close. | 2019-07-26 10:20:41.152
HTTPS connection ID:192 to apis.tdameritrade.com:443 for request ID:192 (1) | Socket gracefully closed by remote side. | 2019-07-26 10:20:41.203
HTTPS connection ID:192 to apis.tdameritrade.com:443 for request ID:192 (1) | Closed. | 2019-07-26 10:20:41.203
HTTPS connection ID:193 to apis.tdameritrade.com:443 for request ID:193 (1) | Creating socket. Using TLS 1.2. | 2019-07-26 10:23:40.657
HTTPS connection ID:193 to apis.tdameritrade.com:443 for request ID:193 (1) | Connecting to IP: 198.200.171.201. | 2019-07-26 10:23:40.657
HTTPS connection ID:193 to apis.tdameritrade.com:443 for request ID:193 (1) | Shutdown started. Waiting for graceful close. | 2019-07-26 10:23:41.138
HTTPS connection ID:193 to apis.tdameritrade.com:443 for request ID:193 (1) | Socket gracefully closed by remote side. | 2019-07-26 10:23:41.188
HTTPS connection ID:193 to apis.tdameritrade.com:443 for request ID:193 (1) | Closed. | 2019-07-26 10:23:41.188
HTTPS connection ID:194 to apis.tdameritrade.com:443 for request ID:194 (1) | Creating socket. Using TLS 1.2. | 2019-07-26 10:26:40.654
HTTPS connection ID:194 to apis.tdameritrade.com:443 for request ID:194 (1) | Connecting to IP: 198.200.171.201. | 2019-07-26 10:26:40.654
HTTPS connection ID:194 to apis.tdameritrade.com:443 for request ID:194 (1) | Shutdown started. Waiting for graceful close. | 2019-07-26 10:26:41.122
HTTPS connection ID:194 to apis.tdameritrade.com:443 for request ID:194 (1) | Socket gracefully closed by remote side. | 2019-07-26 10:26:41.174
HTTPS connection ID:194 to apis.tdameritrade.com:443 for request ID:194 (1) | Closed. | 2019-07-26 10:26:41.174
HTTPS connection ID:195 to apis.tdameritrade.com:443 for request ID:195 (1) | Creating socket. Using TLS 1.2. | 2019-07-26 10:29:40.651
HTTPS connection ID:195 to apis.tdameritrade.com:443 for request ID:195 (1) | Connecting to IP: 198.200.171.201. | 2019-07-26 10:29:40.651
HTTPS connection ID:195 to apis.tdameritrade.com:443 for request ID:195 (1) | Shutdown started. Waiting for graceful close. | 2019-07-26 10:29:41.109
HTTPS connection ID:195 to apis.tdameritrade.com:443 for request ID:195 (1) | Socket gracefully closed by remote side. | 2019-07-26 10:29:41.161
HTTPS connection ID:195 to apis.tdameritrade.com:443 for request ID:195 (1) | Closed. | 2019-07-26 10:29:41.161
HTTPS connection ID:196 to apis.tdameritrade.com:443 for request ID:196 (1) | Creating socket. Using TLS 1.2. | 2019-07-26 10:32:40.653
HTTPS connection ID:196 to apis.tdameritrade.com:443 for request ID:196 (1) | Connecting to IP: 198.200.171.201. | 2019-07-26 10:32:40.653
HTTPS connection ID:196 to apis.tdameritrade.com:443 for request ID:196 (1) | Shutdown started. Waiting for graceful close. | 2019-07-26 10:32:41.121
HTTPS connection ID:196 to apis.tdameritrade.com:443 for request ID:196 (1) | Socket gracefully closed by remote side. | 2019-07-26 10:32:41.175
HTTPS connection ID:196 to apis.tdameritrade.com:443 for request ID:196 (1) | Closed. | 2019-07-26 10:32:41.175
HTTPS connection ID:197 to apis.tdameritrade.com:443 for request ID:197 (1) | Creating socket. Using TLS 1.2. | 2019-07-26 10:35:40.653
HTTPS connection ID:197 to apis.tdameritrade.com:443 for request ID:197 (1) | Connecting to IP: 198.200.171.201. | 2019-07-26 10:35:40.653
HTTPS connection ID:197 to apis.tdameritrade.com:443 for request ID:197 (1) | Shutdown started. Waiting for graceful close. | 2019-07-26 10:35:41.105
HTTPS connection ID:197 to apis.tdameritrade.com:443 for request ID:197 (1) | Socket gracefully closed by remote side. | 2019-07-26 10:35:41.167
HTTPS connection ID:197 to apis.tdameritrade.com:443 for request ID:197 (1) | Closed. | 2019-07-26 10:35:41.167
HTTPS connection ID:198 to apis.tdameritrade.com:443 for request ID:198 (1) | Creating socket. Using TLS 1.2. | 2019-07-26 10:38:40.669
HTTPS connection ID:198 to apis.tdameritrade.com:443 for request ID:198 (1) | Connecting to IP: 198.200.171.201. | 2019-07-26 10:38:40.670
HTTPS connection ID:198 to apis.tdameritrade.com:443 for request ID:198 (1) | Shutdown started. Waiting for graceful close. | 2019-07-26 10:38:41.138
HTTPS connection ID:198 to apis.tdameritrade.com:443 for request ID:198 (1) | Socket gracefully closed by remote side. | 2019-07-26 10:38:41.190
HTTPS connection ID:198 to apis.tdameritrade.com:443 for request ID:198 (1) | Closed. | 2019-07-26 10:38:41.190
HTTPS connection ID:199 to apis.tdameritrade.com:443 for request ID:199 (1) | Creating socket. Using TLS 1.2. | 2019-07-26 10:41:40.655
HTTPS connection ID:199 to apis.tdameritrade.com:443 for request ID:199 (1) | Connecting to IP: 198.200.171.201. | 2019-07-26 10:41:40.656
HTTPS connection ID:199 to apis.tdameritrade.com:443 for request ID:199 (1) | Shutdown started. Waiting for graceful close. | 2019-07-26 10:41:41.121
HTTPS connection ID:199 to apis.tdameritrade.com:443 for request ID:199 (1) | Socket gracefully closed by remote side. | 2019-07-26 10:41:41.170
HTTPS connection ID:199 to apis.tdameritrade.com:443 for request ID:199 (1) | Closed. | 2019-07-26 10:41:41.170
HTTPS connection ID:200 to apis.tdameritrade.com:443 for request ID:200 (1) | Creating socket. Using TLS 1.2. | 2019-07-26 10:44:40.654
HTTPS connection ID:200 to apis.tdameritrade.com:443 for request ID:200 (1) | Connecting to IP: 198.200.171.201. | 2019-07-26 10:44:40.655
HTTPS connection ID:200 to apis.tdameritrade.com:443 for request ID:200 (1) | Shutdown started. Waiting for graceful close. | 2019-07-26 10:44:41.120
HTTPS connection ID:200 to apis.tdameritrade.com:443 for request ID:200 (1) | Socket gracefully closed by remote side. | 2019-07-26 10:44:41.172
HTTPS connection ID:200 to apis.tdameritrade.com:443 for request ID:200 (1) | Closed. | 2019-07-26 10:44:41.172
HTTPS connection ID:201 to apis.tdameritrade.com:443 for request ID:201 (1) | Creating socket. Using TLS 1.2. | 2019-07-26 10:47:40.656
HTTPS connection ID:201 to apis.tdameritrade.com:443 for request ID:201 (1) | Connecting to IP: 198.200.171.201. | 2019-07-26 10:47:40.656
HTTPS connection ID:201 to apis.tdameritrade.com:443 for request ID:201 (1) | Shutdown started. Waiting for graceful close. | 2019-07-26 10:47:41.121
HTTPS connection ID:201 to apis.tdameritrade.com:443 for request ID:201 (1) | Socket gracefully closed by remote side. | 2019-07-26 10:47:41.172
HTTPS connection ID:201 to apis.tdameritrade.com:443 for request ID:201 (1) | Closed. | 2019-07-26 10:47:41.172
HTTPS connection ID:202 to apis.tdameritrade.com:443 for request ID:202 (1) | Creating socket. Using TLS 1.2. | 2019-07-26 10:50:40.653
HTTPS connection ID:202 to apis.tdameritrade.com:443 for request ID:202 (1) | Connecting to IP: 198.200.171.201. | 2019-07-26 10:50:40.653
HTTPS connection ID:202 to apis.tdameritrade.com:443 for request ID:202 (1) | Shutdown started. Waiting for graceful close. | 2019-07-26 10:50:41.105
HTTPS connection ID:202 to apis.tdameritrade.com:443 for request ID:202 (1) | Socket gracefully closed by remote side. | 2019-07-26 10:50:41.157
HTTPS connection ID:202 to apis.tdameritrade.com:443 for request ID:202 (1) | Closed. | 2019-07-26 10:50:41.157
HTTPS connection ID:203 to apis.tdameritrade.com:443 for request ID:203 (1) | Creating socket. Using TLS 1.2. | 2019-07-26 10:53:40.653
HTTPS connection ID:203 to apis.tdameritrade.com:443 for request ID:203 (1) | Connecting to IP: 198.200.171.201. | 2019-07-26 10:53:40.653
HTTPS connection ID:203 to apis.tdameritrade.com:443 for request ID:203 (1) | Shutdown started. Waiting for graceful close. | 2019-07-26 10:53:41.105
HTTPS connection ID:203 to apis.tdameritrade.com:443 for request ID:203 (1) | Socket gracefully closed by remote side. | 2019-07-26 10:53:41.155
HTTPS connection ID:203 to apis.tdameritrade.com:443 for request ID:203 (1) | Closed. | 2019-07-26 10:53:41.155
HTTPS connection ID:204 to apis.tdameritrade.com:443 for request ID:204 (1) | Creating socket. Using TLS 1.2. | 2019-07-26 10:56:40.674
HTTPS connection ID:204 to apis.tdameritrade.com:443 for request ID:204 (1) | Connecting to IP: 198.200.171.201. | 2019-07-26 10:56:40.674
HTTPS connection ID:204 to apis.tdameritrade.com:443 for request ID:204 (1) | Shutdown started. Waiting for graceful close. | 2019-07-26 10:56:41.136
HTTPS connection ID:204 to apis.tdameritrade.com:443 for request ID:204 (1) | Socket gracefully closed by remote side. | 2019-07-26 10:56:41.189
HTTPS connection ID:204 to apis.tdameritrade.com:443 for request ID:204 (1) | Closed. | 2019-07-26 10:56:41.189
HTTPS connection ID:205 to apis.tdameritrade.com:443 for request ID:205 (1) | Creating socket. Using TLS 1.2. | 2019-07-26 10:59:40.654
HTTPS connection ID:205 to apis.tdameritrade.com:443 for request ID:205 (1) | Connecting to IP: 198.200.171.201. | 2019-07-26 10:59:40.654
HTTPS connection ID:205 to apis.tdameritrade.com:443 for request ID:205 (1) | Shutdown started. Waiting for graceful close. | 2019-07-26 10:59:41.106
HTTPS connection ID:205 to apis.tdameritrade.com:443 for request ID:205 (1) | Socket gracefully closed by remote side. | 2019-07-26 10:59:41.159
HTTPS connection ID:205 to apis.tdameritrade.com:443 for request ID:205 (1) | Closed. | 2019-07-26 10:59:41.159
HTTPS connection ID:206 to apis.tdameritrade.com:443 for request ID:206 (1) | Creating socket. Using TLS 1.2. | 2019-07-26 11:02:40.652
HTTPS connection ID:206 to apis.tdameritrade.com:443 for request ID:206 (1) | Connecting to IP: 198.200.171.201. | 2019-07-26 11:02:40.653
HTTPS connection ID:206 to apis.tdameritrade.com:443 for request ID:206 (1) | Shutdown started. Waiting for graceful close. | 2019-07-26 11:02:41.121
HTTPS connection ID:206 to apis.tdameritrade.com:443 for request ID:206 (1) | Socket gracefully closed by remote side. | 2019-07-26 11:02:41.172
HTTPS connection ID:206 to apis.tdameritrade.com:443 for request ID:206 (1) | Closed. | 2019-07-26 11:02:41.172
HTTPS connection ID:207 to apis.tdameritrade.com:443 for request ID:207 (1) | Creating socket. Using TLS 1.2. | 2019-07-26 11:05:40.652
HTTPS connection ID:207 to apis.tdameritrade.com:443 for request ID:207 (1) | Connecting to IP: 198.200.171.201. | 2019-07-26 11:05:40.652
HTTPS connection ID:207 to apis.tdameritrade.com:443 for request ID:207 (1) | Shutdown started. Waiting for graceful close. | 2019-07-26 11:05:41.105
HTTPS connection ID:207 to apis.tdameritrade.com:443 for request ID:207 (1) | Socket gracefully closed by remote side. | 2019-07-26 11:05:41.158
HTTPS connection ID:207 to apis.tdameritrade.com:443 for request ID:207 (1) | Closed. | 2019-07-26 11:05:41.158
HTTPS connection ID:208 to apis.tdameritrade.com:443 for request ID:208 (1) | Creating socket. Using TLS 1.2. | 2019-07-26 11:08:40.652
HTTPS connection ID:208 to apis.tdameritrade.com:443 for request ID:208 (1) | Connecting to IP: 198.200.171.201. | 2019-07-26 11:08:40.652
HTTPS connection ID:208 to apis.tdameritrade.com:443 for request ID:208 (1) | Shutdown started. Waiting for graceful close. | 2019-07-26 11:08:41.122
HTTPS connection ID:208 to apis.tdameritrade.com:443 for request ID:208 (1) | Socket gracefully closed by remote side. | 2019-07-26 11:08:41.178
HTTPS connection ID:208 to apis.tdameritrade.com:443 for request ID:208 (1) | Closed. | 2019-07-26 11:08:41.178
HTTPS connection ID:209 to apis.tdameritrade.com:443 for request ID:209 (1) | Creating socket. Using TLS 1.2. | 2019-07-26 11:09:13.960
HTTPS connection ID:209 to apis.tdameritrade.com:443 for request ID:209 (1) | Connecting to IP: 198.200.171.201. | 2019-07-26 11:09:13.961
HTTPS connection ID:210 to apis.tdameritrade.com:443 for request ID:210 (3) | Creating socket. Using TLS 1.2. | 2019-07-26 11:09:13.961
HTTPS connection ID:210 to apis.tdameritrade.com:443 for request ID:210 (3) | Connecting to IP: 198.200.171.201. | 2019-07-26 11:09:13.961
HTTPS connection ID:210 to apis.tdameritrade.com:443 for request ID:210 (3) | Shutdown started. Waiting for graceful close. | 2019-07-26 11:09:14.434
HTTPS connection ID:209 to apis.tdameritrade.com:443 for request ID:209 (1) | Shutdown started. Waiting for graceful close. | 2019-07-26 11:09:14.480
HTTPS connection ID:210 to apis.tdameritrade.com:443 for request ID:210 (3) | Socket gracefully closed by remote side. | 2019-07-26 11:09:14.486
HTTPS connection ID:210 to apis.tdameritrade.com:443 for request ID:210 (3) | Closed. | 2019-07-26 11:09:14.486
HTTPS connection ID:211 to apis.tdameritrade.com:443 for request ID:211 (3) | Creating socket. Using TLS 1.2. | 2019-07-26 11:09:14.525
HTTPS connection ID:211 to apis.tdameritrade.com:443 for request ID:211 (3) | Connecting to IP: 198.200.171.201. | 2019-07-26 11:09:14.525
HTTPS connection ID:212 to apis.tdameritrade.com:443 for request ID:212 (4) | Creating socket. Using TLS 1.2. | 2019-07-26 11:09:14.525
HTTPS connection ID:212 to apis.tdameritrade.com:443 for request ID:212 (4) | Connecting to IP: 198.200.171.201. | 2019-07-26 11:09:14.525
HTTPS connection ID:209 to apis.tdameritrade.com:443 for request ID:209 (1) | Socket gracefully closed by remote side. | 2019-07-26 11:09:14.532
HTTPS connection ID:209 to apis.tdameritrade.com:443 for request ID:209 (1) | Closed. | 2019-07-26 11:09:14.532
HTTPS connection ID:211 to apis.tdameritrade.com:443 for request ID:211 (3) | Shutdown started. Waiting for graceful close. | 2019-07-26 11:09:14.984
HTTPS connection ID:212 to apis.tdameritrade.com:443 for request ID:212 (4) | Shutdown started. Waiting for graceful close. | 2019-07-26 11:09:15.012
HTTPS connection ID:211 to apis.tdameritrade.com:443 for request ID:211 (3) | Socket gracefully closed by remote side. | 2019-07-26 11:09:15.034
HTTPS connection ID:211 to apis.tdameritrade.com:443 for request ID:211 (3) | Closed. | 2019-07-26 11:09:15.034
HTTPS connection ID:212 to apis.tdameritrade.com:443 for request ID:212 (4) | Socket gracefully closed by remote side. | 2019-07-26 11:09:15.061
HTTPS connection ID:212 to apis.tdameritrade.com:443 for request ID:212 (4) | Closed. | 2019-07-26 11:09:15.061
HTTPS connection ID:213 to apis.tdameritrade.com:443 for request ID:213 (1) | Creating socket. Using TLS 1.2. | 2019-07-26 11:09:16.012
HTTPS connection ID:213 to apis.tdameritrade.com:443 for request ID:213 (1) | Connecting to IP: 198.200.171.201. | 2019-07-26 11:09:16.013
HTTPS connection ID:214 to apis.tdameritrade.com:443 for request ID:214 (3) | Creating socket. Using TLS 1.2. | 2019-07-26 11:09:16.013
HTTPS connection ID:214 to apis.tdameritrade.com:443 for request ID:214 (3) | Connecting to IP: 198.200.171.201. | 2019-07-26 11:09:16.013
HTTPS connection ID:215 to apis.tdameritrade.com:443 for request ID:215 (4) | Creating socket. Using TLS 1.2. | 2019-07-26 11:09:16.013
HTTPS connection ID:215 to apis.tdameritrade.com:443 for request ID:215 (4) | Connecting to IP: 198.200.171.201. | 2019-07-26 11:09:16.013
HTTPS connection ID:216 to apis.tdameritrade.com:443 for request ID:216 (5) | Creating socket. Using TLS 1.2. | 2019-07-26 11:09:16.013
HTTPS connection ID:216 to apis.tdameritrade.com:443 for request ID:216 (5) | Connecting to IP: 198.200.171.201. | 2019-07-26 11:09:16.013
HTTPS connection ID:214 to apis.tdameritrade.com:443 for request ID:214 (3) | Shutdown started. Waiting for graceful close. | 2019-07-26 11:09:16.530
HTTPS connection ID:216 to apis.tdameritrade.com:443 for request ID:216 (5) | Shutdown started. Waiting for graceful close. | 2019-07-26 11:09:16.530
HTTPS connection ID:213 to apis.tdameritrade.com:443 for request ID:213 (1) | Shutdown started. Waiting for graceful close. | 2019-07-26 11:09:16.530
HTTPS connection ID:215 to apis.tdameritrade.com:443 for request ID:215 (4) | Shutdown started. Waiting for graceful close. | 2019-07-26 11:09:16.545
HTTPS connection ID:214 to apis.tdameritrade.com:443 for request ID:214 (3) | Socket gracefully closed by remote side. | 2019-07-26 11:09:16.585
HTTPS connection ID:214 to apis.tdameritrade.com:443 for request ID:214 (3) | Closed. | 2019-07-26 11:09:16.585
HTTPS connection ID:216 to apis.tdameritrade.com:443 for request ID:216 (5) | Socket gracefully closed by remote side. | 2019-07-26 11:09:16.585
HTTPS connection ID:216 to apis.tdameritrade.com:443 for request ID:216 (5) | Closed. | 2019-07-26 11:09:16.585
HTTPS connection ID:213 to apis.tdameritrade.com:443 for request ID:213 (1) | Socket gracefully closed by remote side. | 2019-07-26 11:09:16.588
HTTPS connection ID:213 to apis.tdameritrade.com:443 for request ID:213 (1) | Closed. | 2019-07-26 11:09:16.588
HTTPS connection ID:215 to apis.tdameritrade.com:443 for request ID:215 (4) | Socket gracefully closed by remote side. | 2019-07-26 11:09:16.604
HTTPS connection ID:215 to apis.tdameritrade.com:443 for request ID:215 (4) | Closed. | 2019-07-26 11:09:16.604
HTTPS connection ID:217 to apis.tdameritrade.com:443 for request ID:217 (1) | Creating socket. Using TLS 1.2. | 2019-07-26 11:09:30.465
HTTPS connection ID:217 to apis.tdameritrade.com:443 for request ID:217 (1) | Connecting to IP: 198.200.171.201. | 2019-07-26 11:09:30.465
HTTPS connection ID:218 to apis.tdameritrade.com:443 for request ID:218 (3) | Creating socket. Using TLS 1.2. | 2019-07-26 11:09:30.465
HTTPS connection ID:218 to apis.tdameritrade.com:443 for request ID:218 (3) | Connecting to IP: 198.200.171.201. | 2019-07-26 11:09:30.465
HTTPS connection ID:219 to apis.tdameritrade.com:443 for request ID:219 (4) | Creating socket. Using TLS 1.2. | 2019-07-26 11:09:30.465
HTTPS connection ID:219 to apis.tdameritrade.com:443 for request ID:219 (4) | Connecting to IP: 198.200.171.201. | 2019-07-26 11:09:30.465
HTTPS connection ID:220 to apis.tdameritrade.com:443 for request ID:220 (5) | Creating socket. Using TLS 1.2. | 2019-07-26 11:09:30.466
HTTPS connection ID:220 to apis.tdameritrade.com:443 for request ID:220 (5) | Connecting to IP: 198.200.171.201. | 2019-07-26 11:09:30.466
HTTPS connection ID:218 to apis.tdameritrade.com:443 for request ID:218 (3) | Shutdown started. Waiting for graceful close. | 2019-07-26 11:09:30.965
HTTPS connection ID:220 to apis.tdameritrade.com:443 for request ID:220 (5) | Shutdown started. Waiting for graceful close. | 2019-07-26 11:09:30.965
HTTPS connection ID:217 to apis.tdameritrade.com:443 for request ID:217 (1) | Shutdown started. Waiting for graceful close. | 2019-07-26 11:09:30.982
HTTPS connection ID:219 to apis.tdameritrade.com:443 for request ID:219 (4) | Shutdown started. Waiting for graceful close. | 2019-07-26 11:09:30.996
HTTPS connection ID:218 to apis.tdameritrade.com:443 for request ID:218 (3) | Socket gracefully closed by remote side. | 2019-07-26 11:09:31.014
HTTPS connection ID:218 to apis.tdameritrade.com:443 for request ID:218 (3) | Closed. | 2019-07-26 11:09:31.014
HTTPS connection ID:220 to apis.tdameritrade.com:443 for request ID:220 (5) | Socket gracefully closed by remote side. | 2019-07-26 11:09:31.019
HTTPS connection ID:220 to apis.tdameritrade.com:443 for request ID:220 (5) | Closed. | 2019-07-26 11:09:31.019
HTTPS connection ID:217 to apis.tdameritrade.com:443 for request ID:217 (1) | Socket gracefully closed by remote side. | 2019-07-26 11:09:31.033
HTTPS connection ID:217 to apis.tdameritrade.com:443 for request ID:217 (1) | Closed. | 2019-07-26 11:09:31.033
HTTPS connection ID:219 to apis.tdameritrade.com:443 for request ID:219 (4) | Socket gracefully closed by remote side. | 2019-07-26 11:09:31.046
HTTPS connection ID:219 to apis.tdameritrade.com:443 for request ID:219 (4) | Closed. | 2019-07-26 11:09:31.046
HTTPS connection ID:221 to apis.tdameritrade.com:443 for request ID:221 (1) | Creating socket. Using TLS 1.2. | 2019-07-26 11:11:40.651
HTTPS connection ID:221 to apis.tdameritrade.com:443 for request ID:221 (1) | Connecting to IP: 198.200.171.201. | 2019-07-26 11:11:40.652
HTTPS connection ID:221 to apis.tdameritrade.com:443 for request ID:221 (1) | Shutdown started. Waiting for graceful close. | 2019-07-26 11:11:41.120
HTTPS connection ID:221 to apis.tdameritrade.com:443 for request ID:221 (1) | Socket gracefully closed by remote side. | 2019-07-26 11:11:41.173
HTTPS connection ID:221 to apis.tdameritrade.com:443 for request ID:221 (1) | Closed. | 2019-07-26 11:11:41.173
HTTPS connection ID:222 to apis.tdameritrade.com:443 for request ID:222 (1) | Creating socket. Using TLS 1.2. | 2019-07-26 11:14:40.667
HTTPS connection ID:222 to apis.tdameritrade.com:443 for request ID:222 (1) | Connecting to IP: 198.200.171.201. | 2019-07-26 11:14:40.668
HTTPS connection ID:222 to apis.tdameritrade.com:443 for request ID:222 (1) | Shutdown started. Waiting for graceful close. | 2019-07-26 11:14:41.121
HTTPS connection ID:222 to apis.tdameritrade.com:443 for request ID:222 (1) | Socket gracefully closed by remote side. | 2019-07-26 11:14:41.171
HTTPS connection ID:222 to apis.tdameritrade.com:443 for request ID:222 (1) | Closed. | 2019-07-26 11:14:41.171
HTTPS connection ID:223 to apis.tdameritrade.com:443 for request ID:223 (1) | Creating socket. Using TLS 1.2. | 2019-07-26 11:17:40.652
HTTPS connection ID:223 to apis.tdameritrade.com:443 for request ID:223 (1) | Connecting to IP: 198.200.171.201. | 2019-07-26 11:17:40.653
HTTPS connection ID:223 to apis.tdameritrade.com:443 for request ID:223 (1) | Shutdown started. Waiting for graceful close. | 2019-07-26 11:17:41.121
HTTPS connection ID:223 to apis.tdameritrade.com:443 for request ID:223 (1) | Socket gracefully closed by remote side. | 2019-07-26 11:17:41.172
HTTPS connection ID:223 to apis.tdameritrade.com:443 for request ID:223 (1) | Closed. | 2019-07-26 11:17:41.172
HTTPS connection ID:224 to apis.tdameritrade.com:443 for request ID:224 (1) | Creating socket. Using TLS 1.2. | 2019-07-26 11:20:40.652
HTTPS connection ID:224 to apis.tdameritrade.com:443 for request ID:224 (1) | Connecting to IP: 198.200.171.201. | 2019-07-26 11:20:40.652
HTTPS connection ID:224 to apis.tdameritrade.com:443 for request ID:224 (1) | Shutdown started. Waiting for graceful close. | 2019-07-26 11:20:41.110
HTTPS connection ID:224 to apis.tdameritrade.com:443 for request ID:224 (1) | Socket gracefully closed by remote side. | 2019-07-26 11:20:41.160
HTTPS connection ID:224 to apis.tdameritrade.com:443 for request ID:224 (1) | Closed. | 2019-07-26 11:20:41.160
HTTPS connection ID:225 to apis.tdameritrade.com:443 for request ID:225 (1) | Creating socket. Using TLS 1.2. | 2019-07-26 11:23:40.652
HTTPS connection ID:225 to apis.tdameritrade.com:443 for request ID:225 (1) | Connecting to IP: 198.200.171.201. | 2019-07-26 11:23:40.652
HTTPS connection ID:225 to apis.tdameritrade.com:443 for request ID:225 (1) | Shutdown started. Waiting for graceful close. | 2019-07-26 11:23:41.109
HTTPS connection ID:225 to apis.tdameritrade.com:443 for request ID:225 (1) | Socket gracefully closed by remote side. | 2019-07-26 11:23:41.160
HTTPS connection ID:225 to apis.tdameritrade.com:443 for request ID:225 (1) | Closed. | 2019-07-26 11:23:41.160
ESU19 5 Min #2 | Reloading chart. | 2019-07-26 11:25:30.717
+ Chart Data Loading Thread Stopwatch: 2.179129569065083 seconds. | 2019-07-26 11:25:32.901
ESU19 1 Min #3 | Reloading chart. | 2019-07-26 11:25:38.834
+ Chart Data Loading Thread Stopwatch: 2.098805551312571 seconds. | 2019-07-26 11:25:40.938
ESU19 5 Min #3 | Reloading chart. | 2019-07-26 11:25:45.036
+ Chart Data Loading Thread Stopwatch: 2.154827633881916 seconds. | 2019-07-26 11:25:47.198
HTTPS connection ID:226 to apis.tdameritrade.com:443 for request ID:226 (1) | Creating socket. Using TLS 1.2. | 2019-07-26 11:26:40.659
HTTPS connection ID:226 to apis.tdameritrade.com:443 for request ID:226 (1) | Connecting to IP: 198.200.171.201. | 2019-07-26 11:26:40.659
HTTPS connection ID:226 to apis.tdameritrade.com:443 for request ID:226 (1) | Shutdown started. Waiting for graceful close. | 2019-07-26 11:26:41.121
HTTPS connection ID:226 to apis.tdameritrade.com:443 for request ID:226 (1) | Socket gracefully closed by remote side. | 2019-07-26 11:26:41.175
HTTPS connection ID:226 to apis.tdameritrade.com:443 for request ID:226 (1) | Closed. | 2019-07-26 11:26:41.175
ESU19 1 Min #4 | Reloading chart. | 2019-07-26 11:26:55.555
+ Chart Data Loading Thread Stopwatch: 2.0659014603982664 seconds. | 2019-07-26 11:26:57.627
ESU19 5 Min #4 | Reloading chart. | 2019-07-26 11:26:59.354
+ Chart Data Loading Thread Stopwatch: 2.1465771594894494 seconds. | 2019-07-26 11:27:01.508
[2019-07-26 18:28:40]
You first need to follow through the instructions here to connect to your TD Ameritrade account:
https://www.sierrachart.com/index.php?page=doc/AmeriTrade.php#SetupInstructions
Understand that we have no control over this connection. If you have any problem with the connection, follow the instructions here to provide the Message Log:
Date Time Of Last Edit: 2019-07-26 18:28:59
