Date/Time: Sun, 24 Nov 2024 20:58:17 +0000
Exception caught from study name
View Count: 1551
[2013-12-04 21:49:13]
mrobson - Posts: 2
This is just a partial listing
Added 1 Time and Sales records to Intraday data file for ESZ3 after download. | 2013-12-04 16:38:46
Exception caught from study name: | 2013-12-04 16:38:47
Exception caught from study name: | 2013-12-04 16:39:16
Exception caught from study name: | 2013-12-04 16:39:20
Exception caught from study name: | 2013-12-04 16:39:22
Exception caught from study name: | 2013-12-04 16:39:27
[2013-12-04 22:52:38]
There is a problem with one of the custom studies you are using. Refer to help topic 17.1 here:
Http://www.sierrachart.com/index.php?l=doc/helpdetails17.html
[2013-12-05 00:20:20]
mrobson - Posts: 2
I'm not using any custom studies. I'm also having a problem with 'out of order timeslips'
Software version: 1058 | 2013-12-04 19:01:51
Usage end date: 2013-12-26 | 2013-12-04 19:01:51
Enabled for: Sierra Chart Historical Data Service. | 2013-12-04 19:01:51
Active service: TransAct | 2013-12-04 19:01:51
Time Zone: -05:00:00 (EST-05EDT+01,M3.2.0/02:00,M11.1.0/02:00) | 2013-12-04 19:01:51
2013-12-04 19:01:51 Local computer clock time | 2013-12-04 19:01:51
2013-12-05 00:01:51 GMT time | 2013-12-04 19:01:51
2013-12-04 19:01:51 Time zone adjusted time | 2013-12-04 19:01:51
Time difference to server time: 17 seconds. | 2013-12-04 19:01:51
Program path: C:\SierraChart.2\ | 2013-12-04 19:01:51
Data Files path: C:\SierraChart.2\Data\ | 2013-12-04 19:01:51
OS Version Number: 5.1 | 2013-12-04 19:01:51
Checking for new symbol settings for ta | 2013-12-04 19:01:51
Out of order timestamps detected. Chart tool drawings and some chart studies may not function properly. Prior Date Time: 2013-12-03 00:57:00. Next Bar Date Time: 2013-12-02 01:00:00. Filename: C:\SierraChart.2\Data\YMZ3.scid | 2013-12-04 19:02:02
Out of order timestamps detected. Chart tool drawings and some chart studies may not function properly. Prior Date Time: 2013-12-03 00:58:57. Next Bar Date Time: 2013-12-02 01:00:00. Filename: C:\SierraChart.2\Data\YMZ3.scid | 2013-12-04 19:02:05
Out of order timestamps detected. Chart tool drawings and some chart studies may not function properly. Prior Date Time: 2013-08-19 10:30:00. Next Bar Date Time: 2013-08-19 10:00:00. Filename: C:\SierraChart.2\Data\TFZ3.scid | 2013-12-04 19:02:16
Out of order timestamps detected. Chart tool drawings and some chart studies may not function properly. Prior Date Time: 2013-12-03 00:57:00. Next Bar Date Time: 2013-12-02 01:00:00. Filename: C:\SierraChart.2\Data\ESZ3.scid | 2013-12-04 19:02:16
Out of order timestamps detected. Chart tool drawings and some chart studies may not function properly. Prior Date Time: 2013-12-03 00:55:51. Next Bar Date Time: 2013-12-02 01:00:00. Filename: C:\SierraChart.2\Data\ESZ3.scid | 2013-12-04 19:02:21
HD Request # 2 - Downloading Intraday chart data for CLF4 to the file CLF4.scid. Service: ta | 2013-12-04 19:02:39
HD Request # 2 - Last Date-Time in file: 2013-12-04 19:01:13.0 | 2013-12-04 19:02:40
HD Request # 2 - Using server: ds5.sierracharts.com port 10149 | 2013-12-04 19:02:40
Resolved address ds5.sierracharts.com to IP 204.15.192.106 | 2013-12-04 19:02:40
Transact DTC - Starting server: C:\SierraChart.2\Transact\TransactToSierraBridge.exe | 2013-12-04 19:02:40
The network socket is connected. | 2013-12-04 19:02:40
HD Request # 2 - Sending historical data logon request message. | 2013-12-04 19:02:40
HD Request # 2 - Requesting up to 60 days of Intraday data. Record interval: 0 | 2013-12-04 19:02:40
HD Request # 2 - Decompressing data. | 2013-12-04 19:02:40
The network socket for historical data has been closed. | 2013-12-04 19:02:40
HD Request # 2 - Historical data for CLF4 is delayed because connection to main data feed is not present. Current data will be received upon connection. | 2013-12-04 19:02:41
HD Request # 2 - Received 1 record and wrote 0 records for CLF4 | 2013-12-04 19:02:41
HD Request # 2 - Intraday download COMPLETE for CLF4 | 2013-12-04 19:02:42
Transact DTC: Connecting to the server 127.0.0.1. Port 1869 | 2013-12-04 19:02:42
Error received in OnConnect while connecting. Windows error code 10061: No connection could be made because the target machine actively refused it. | 2013-12-04 19:02:44
Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2013-12-04 19:02:44
To prevent further connection attempts, select 'File >> Disconnect'. | 2013-12-04 19:02:44
Transact DTC: Disconnected from the server. | 2013-12-04 19:02:45
HD Request # 3 - Downloading Intraday chart data for 6EZ3 to the file 6EZ3.scid. Service: ta | 2013-12-04 19:02:47
HD Request # 3 - Last Date-Time in file: 2013-12-04 19:01:28.0 | 2013-12-04 19:02:48
HD Request # 3 - Using server: ds3.sierracharts.com port 10149 | 2013-12-04 19:02:48
Resolved address ds3.sierracharts.com to IP 65.182.172.164 | 2013-12-04 19:02:48
The network socket is connected. | 2013-12-04 19:02:48
HD Request # 3 - Sending historical data logon request message. | 2013-12-04 19:02:48
HD Request # 3 - Requesting up to 60 days of Intraday data. Record interval: 0 | 2013-12-04 19:02:49
HD Request # 3 - Decompressing data. | 2013-12-04 19:02:49
The network socket for historical data has been closed. | 2013-12-04 19:02:49
HD Request # 3 - Historical data for 6EZ3 is delayed because connection to main data feed is not present. Current data will be received upon connection. | 2013-12-04 19:02:50
HD Request # 3 - Received 1 record and wrote 0 records for 6EZ3 | 2013-12-04 19:02:50
HD Request # 3 - Intraday download COMPLETE for 6EZ3 | 2013-12-04 19:02:51
HD Request # 4 - Downloading Intraday chart data for ESZ3 to the file ESZ3.scid. Service: ta | 2013-12-04 19:02:53
HD Request # 4 - Last Date-Time in file: 2013-12-04 19:01:15.0 | 2013-12-04 19:02:56
HD Request # 4 - Using server: ds4.sierracharts.com port 10149 | 2013-12-04 19:02:56
Resolved address ds4.sierracharts.com to IP 204.11.49.26 | 2013-12-04 19:02:56
The network socket is connected. | 2013-12-04 19:02:56
HD Request # 4 - Sending historical data logon request message. | 2013-12-04 19:02:56
HD Request # 4 - Requesting up to 60 days of Intraday data. Record interval: 0 | 2013-12-04 19:02:57
HD Request # 4 - Decompressing data. | 2013-12-04 19:02:57
The network socket for historical data has been closed. | 2013-12-04 19:02:57
HD Request # 4 - Historical data for ESZ3 is delayed because connection to main data feed is not present. Current data will be received upon connection. | 2013-12-04 19:02:58
HD Request # 4 - Received 1 record and wrote 0 records for ESZ3 | 2013-12-04 19:02:58
HD Request # 4 - Intraday download COMPLETE for ESZ3 | 2013-12-04 19:02:58
HD Request # 5 - Downloading Intraday chart data for NQZ3 to the file NQZ3.scid. Service: ta | 2013-12-04 19:03:05
HD Request # 5 - Last Date-Time in file: 2013-12-04 19:00:39.0 | 2013-12-04 19:03:05
HD Request # 5 - Using server: ds5.sierracharts.com port 10149 | 2013-12-04 19:03:05
Resolved address ds5.sierracharts.com to IP 204.15.192.106 | 2013-12-04 19:03:05
The network socket is connected. | 2013-12-04 19:03:05
HD Request # 5 - Sending historical data logon request message. | 2013-12-04 19:03:05
HD Request # 5 - Requesting up to 60 days of Intraday data. Record interval: 0 | 2013-12-04 19:03:05
HD Request # 5 - Decompressing data. | 2013-12-04 19:03:05
The network socket for historical data has been closed. | 2013-12-04 19:03:05
HD Request # 5 - Historical data for NQZ3 is delayed because connection to main data feed is not present. Current data will be received upon connection. | 2013-12-04 19:03:06
HD Request # 5 - Received 1 record and wrote 0 records for NQZ3 | 2013-12-04 19:03:06
HD Request # 5 - Intraday download COMPLETE for NQZ3 | 2013-12-04 19:03:07
HD Request # 6 - Downloading Intraday chart data for YMZ3 to the file YMZ3.scid. Service: ta | 2013-12-04 19:03:10
HD Request # 6 - Last Date-Time in file: 2013-12-04 19:01:28.0 | 2013-12-04 19:03:11
HD Request # 6 - Using server: ds3.sierracharts.com port 10149 | 2013-12-04 19:03:11
Resolved address ds3.sierracharts.com to IP 65.182.172.164 | 2013-12-04 19:03:11
The network socket is connected. | 2013-12-04 19:03:11
HD Request # 6 - Sending historical data logon request message. | 2013-12-04 19:03:11
HD Request # 6 - Requesting up to 60 days of Intraday data. Record interval: 0 | 2013-12-04 19:03:11
HD Request # 6 - Decompressing data. | 2013-12-04 19:03:11
The network socket for historical data has been closed. | 2013-12-04 19:03:11
HD Request # 6 - Historical data for YMZ3 is delayed because connection to main data feed is not present. Current data will be received upon connection. | 2013-12-04 19:03:12
HD Request # 6 - Received 1 record and wrote 0 records for YMZ3 | 2013-12-04 19:03:12
HD Request # 6 - Intraday download COMPLETE for YMZ3 | 2013-12-04 19:03:12
HD Request # 7 - Downloading Intraday chart data for TFZ3 to the file TFZ3.scid. Service: ta | 2013-12-04 19:03:13
HD Request # 7 - Last Date-Time in file: 2013-12-04 17:59:59.0 | 2013-12-04 19:03:13
HD Request # 7 - Using server: ds4.sierracharts.com port 10149 | 2013-12-04 19:03:13
Resolved address ds4.sierracharts.com to IP 204.11.49.26 | 2013-12-04 19:03:13
The network socket is connected. | 2013-12-04 19:03:13
HD Request # 7 - Sending historical data logon request message. | 2013-12-04 19:03:13
HD Request # 7 - Requesting up to 60 days of Intraday data. Record interval: 0 | 2013-12-04 19:03:14
The network socket for historical data has been closed. | 2013-12-04 19:03:14
HD Request # 7 - Error downloading historical Intraday data for TFZ3. Symbol not allowed. | 2013-12-04 19:03:14
HD Request # 7 - Received 0 records and wrote 0 records for TFZ3 | 2013-12-04 19:03:14
HD Request # 7 - Intraday download COMPLETE for TFZ3 | 2013-12-04 19:03:15
Transact DTC - Starting server: C:\SierraChart.2\Transact\TransactToSierraBridge.exe | 2013-12-04 19:04:32
Transact DTC: Connecting to the server 127.0.0.1. Port 1869 | 2013-12-04 19:04:33
The network socket is connected. | 2013-12-04 19:04:33
Transact DTC: Connected to server. | 2013-12-04 19:04:33
DTC Server Info - Server Name: TransactToSierraBridge. Server Version: 1.2.2.0. Provider Name: Transact Futures. | 2013-12-04 19:04:34
DTC - Server protocol version: 3. Client protocol version: 3. There is a protocol match. | 2013-12-04 19:04:34
Transact DTC: Sending logon request message. | 2013-12-04 19:04:34
Transact Futures Server Info - Server Name: TransactToSierraBridge. Server Version: 1.2.2.0. Provider Name: Transact Futures. | 2013-12-04 19:05:29
Transact Futures - Server protocol version: 3. Client protocol version: 3. There is a protocol match. | 2013-12-04 19:05:29
Transact Futures - Successfully connected. Operation Successful. | 2013-12-04 19:05:29
Transact DTC - Starting real-time market data updates for: 6EZ3 | 2013-12-04 19:05:39
HD Request # 8 - Downloading Intraday chart data for 6EZ3 to the file 6EZ3.scid. Service: ta | 2013-12-04 19:05:39
HD Request # 8 - Last Date-Time in file: 2013-12-04 19:01:28.0 | 2013-12-04 19:05:39
HD Request # 8 - Using server: ds5.sierracharts.com port 10149 | 2013-12-04 19:05:39
Resolved address ds5.sierracharts.com to IP 204.15.192.106 | 2013-12-04 19:05:39
The network socket is connected. | 2013-12-04 19:05:39
HD Request # 8 - Sending historical data logon request message. | 2013-12-04 19:05:39
HD Request # 8 - Requesting up to 60 days of Intraday data. Record interval: 0 | 2013-12-04 19:05:39
HD Request # 8 - Decompressing data. | 2013-12-04 19:05:39
HD Request # 8 - Receiving Intraday data for 6EZ3 starting at 2013-12-04 19:01:35 | 2013-12-04 19:05:39
HD Request # 8 - Timestamp of first Intraday data file record written: 2013-12-04 19:01:35 | 2013-12-04 19:05:39
The network socket for historical data has been closed. | 2013-12-04 19:05:39
HD Request # 8 - Received 42 records from 2013-12-04 19:01:35 to 2013-12-04 19:05:09 (3.6 minutes) and wrote 42 records for 6EZ3 | 2013-12-04 19:05:42
HD Request # 8 - Intraday download COMPLETE for 6EZ3 | 2013-12-04 19:05:42
Real-time Intraday chart data file updates started for 6EZ3 | 2013-12-04 19:05:42
Transact DTC - Starting real-time market data updates for: ESZ3 | 2013-12-04 19:05:43
HD Request # 9 - Downloading Intraday chart data for ESZ3 to the file ESZ3.scid. Service: ta | 2013-12-04 19:05:43
HD Request # 9 - Last Date-Time in file: 2013-12-04 19:01:15.0 | 2013-12-04 19:05:43
HD Request # 9 - Using server: ds3.sierracharts.com port 10149 | 2013-12-04 19:05:43
Resolved address ds3.sierracharts.com to IP 65.182.172.164 | 2013-12-04 19:05:43
The network socket is connected. | 2013-12-04 19:05:43
HD Request # 9 - Sending historical data logon request message. | 2013-12-04 19:05:43
HD Request # 9 - Requesting up to 60 days of Intraday data. Record interval: 0 | 2013-12-04 19:05:43
HD Request # 9 - Decompressing data. | 2013-12-04 19:05:44
HD Request # 9 - Receiving Intraday data for ESZ3 starting at 2013-12-04 19:01:28 | 2013-12-04 19:05:44
HD Request # 9 - Timestamp of first Intraday data file record written: 2013-12-04 19:01:28 | 2013-12-04 19:05:44
The network socket for historical data has been closed. | 2013-12-04 19:05:44
HD Request # 9 - Received 48 records from 2013-12-04 19:01:28 to 2013-12-04 19:05:25 (4.0 minutes) and wrote 48 records for ESZ3 | 2013-12-04 19:05:46
HD Request # 9 - Intraday download COMPLETE for ESZ3 | 2013-12-04 19:05:47
Real-time Intraday chart data file updates started for ESZ3 | 2013-12-04 19:05:47
Added 1 Time and Sales records to Intraday data file for ESZ3 after download. | 2013-12-04 19:05:48
Transact DTC - Starting real-time market data updates for: NQZ3 | 2013-12-04 19:05:51
HD Request # 10 - Downloading Intraday chart data for NQZ3 to the file NQZ3.scid. Service: ta | 2013-12-04 19:05:51
HD Request # 10 - Last Date-Time in file: 2013-12-04 19:00:39.0 | 2013-12-04 19:05:51
HD Request # 10 - Using server: ds4.sierracharts.com port 10149 | 2013-12-04 19:05:51
Resolved address ds4.sierracharts.com to IP 204.11.49.26 | 2013-12-04 19:05:51
The network socket is connected. | 2013-12-04 19:05:51
HD Request # 10 - Sending historical data logon request message. | 2013-12-04 19:05:51
Transact DTC - Starting real-time market data updates for: YMZ3 | 2013-12-04 19:05:52
HD Request # 10 - Requesting up to 60 days of Intraday data. Record interval: 0 | 2013-12-04 19:05:52
HD Request # 10 - Decompressing data. | 2013-12-04 19:05:52
HD Request # 10 - Receiving Intraday data for NQZ3 starting at 2013-12-04 19:01:31 | 2013-12-04 19:05:52
HD Request # 10 - Timestamp of first Intraday data file record written: 2013-12-04 19:01:31 | 2013-12-04 19:05:52
The network socket for historical data has been closed. | 2013-12-04 19:05:52
HD Request # 10 - Received 59 records from 2013-12-04 19:01:31 to 2013-12-04 19:05:27 (3.9 minutes) and wrote 59 records for NQZ3 | 2013-12-04 19:05:53
HD Request # 10 - Intraday download COMPLETE for NQZ3 | 2013-12-04 19:05:53
Real-time Intraday chart data file updates started for NQZ3 | 2013-12-04 19:05:53
Added 1 Time and Sales records to Intraday data file for NQZ3 after download. | 2013-12-04 19:05:53
HD Request # 11 - Downloading Intraday chart data for YMZ3 to the file YMZ3.scid. Service: ta | 2013-12-04 19:05:54
HD Request # 11 - Last Date-Time in file: 2013-12-04 19:01:28.0 | 2013-12-04 19:05:54
HD Request # 11 - Using server: ds5.sierracharts.com port 10149 | 2013-12-04 19:05:54
Resolved address ds5.sierracharts.com to IP 204.15.192.106 | 2013-12-04 19:05:54
Transact DTC - Starting real-time market data updates for: TFZ3 | 2013-12-04 19:05:54
The network socket is connected. | 2013-12-04 19:05:54
HD Request # 11 - Sending historical data logon request message. | 2013-12-04 19:05:54
HD Request # 11 - Requesting up to 60 days of Intraday data. Record interval: 0 | 2013-12-04 19:05:54
HD Request # 11 - Decompressing data. | 2013-12-04 19:05:54
HD Request # 11 - Receiving Intraday data for YMZ3 starting at 2013-12-04 19:01:50 | 2013-12-04 19:05:54
HD Request # 11 - Timestamp of first Intraday data file record written: 2013-12-04 19:01:50 | 2013-12-04 19:05:54
The network socket for historical data has been closed. | 2013-12-04 19:05:54
HD Request # 11 - Received 45 records from 2013-12-04 19:01:50 to 2013-12-04 19:05:13 (3.4 minutes) and wrote 45 records for YMZ3 | 2013-12-04 19:05:55
HD Request # 11 - Intraday download COMPLETE for YMZ3 | 2013-12-04 19:05:55
Real-time Intraday chart data file updates started for YMZ3 | 2013-12-04 19:05:55
HD Request # 12 - Downloading Intraday chart data for TFZ3 to the file TFZ3.scid. Service: ta | 2013-12-04 19:05:56
HD Request # 12 - Last Date-Time in file: 2013-12-04 17:59:59.0 | 2013-12-04 19:05:56
HD Request # 12 - Using server: ds3.sierracharts.com port 10149 | 2013-12-04 19:05:56
Resolved address ds3.sierracharts.com to IP 65.182.172.164 | 2013-12-04 19:05:56
The network socket is connected. | 2013-12-04 19:05:56
HD Request # 12 - Sending historical data logon request message. | 2013-12-04 19:05:56
HD Request # 12 - Requesting up to 60 days of Intraday data. Record interval: 0 | 2013-12-04 19:05:56
HD Request # 12 - Decompressing data. | 2013-12-04 19:05:56
HD Request # 12 - Receiving Intraday data for TFZ3 starting at 2013-12-04 17:59:59 | 2013-12-04 19:05:56
The network socket for historical data has been closed. | 2013-12-04 19:05:56
Transact DTC - Starting real-time market data updates for: CLF4 | 2013-12-04 19:05:56
HD Request # 12 - Received 3 records from 2013-12-04 17:59:59 to 2013-12-04 17:59:59 (0.0 seconds) and wrote 0 records for TFZ3 | 2013-12-04 19:05:56
HD Request # 12 - Intraday download COMPLETE for TFZ3 | 2013-12-04 19:05:56
Real-time Intraday chart data file updates started for TFZ3 | 2013-12-04 19:05:56
HD Request # 13 - Downloading Intraday chart data for CLF4 to the file CLF4.scid. Service: ta | 2013-12-04 19:05:56
HD Request # 13 - Last Date-Time in file: 2013-12-04 19:01:13.0 | 2013-12-04 19:05:56
HD Request # 13 - Using server: ds4.sierracharts.com port 10149 | 2013-12-04 19:05:56
Resolved address ds4.sierracharts.com to IP 204.11.49.26 | 2013-12-04 19:05:56
HD Request # 13 - Sending historical data logon request message. | 2013-12-04 19:05:56
HD Request # 13 - Requesting up to 60 days of Intraday data. Record interval: 0 | 2013-12-04 19:05:56
HD Request # 13 - Decompressing data. | 2013-12-04 19:05:57
HD Request # 13 - Receiving Intraday data for CLF4 starting at 2013-12-04 19:01:17 | 2013-12-04 19:05:57
HD Request # 13 - Timestamp of first Intraday data file record written: 2013-12-04 19:01:17 | 2013-12-04 19:05:57
The network socket for historical data has been closed. | 2013-12-04 19:05:57
HD Request # 13 - Received 46 records from 2013-12-04 19:01:17 to 2013-12-04 19:05:31 (4.2 minutes) and wrote 46 records for CLF4 | 2013-12-04 19:05:58
HD Request # 13 - Intraday download COMPLETE for CLF4 | 2013-12-04 19:05:59
Real-time Intraday chart data file updates started for CLF4 | 2013-12-04 19:05:59
Out of order timestamps detected. Chart tool drawings and some chart studies may not function properly. Prior Date Time: 2013-10-29 00:30:00. Next Bar Date Time: 2013-10-28 01:00:00. Filename: C:\SierraChart.2\Data\6EZ3.scid | 2013-12-04 19:06:37
Out of order timestamps detected. Chart tool drawings and some chart studies may not function properly. Prior Date Time: 2013-11-18 13:30:00. Next Bar Date Time: 2013-11-18 13:00:00. Filename: C:\SierraChart.2\Data\TFZ3.scid | 2013-12-04 19:08:48
Out of order timestamps detected. Chart tool drawings and some chart studies may not function properly. Prior Date Time: 2013-11-22 13:00:00. Next Bar Date Time: 2013-11-22 12:30:00. Filename: C:\SierraChart.2\Data\TFZ3.scid | 2013-12-04 19:09:25
Out of order timestamps detected. Chart tool drawings and some chart studies may not function properly. Prior Date Time: 2013-12-03 00:59:00. Next Bar Date Time: 2013-12-02 01:00:00. Filename: C:\SierraChart.2\Data\ESZ3.scid | 2013-12-04 19:10:27
Exception caught from study name: | 2013-12-04 19:11:35
Exception caught from study name: | 2013-12-04 19:11:36
Exception caught from study name: | 2013-12-04 19:11:39
Exception caught from study name: | 2013-12-04 19:11:56
Exception caught from study name: | 2013-12-04 19:12:04
Exception caught from study name: | 2013-12-04 19:12:06
Exception caught from study name: | 2013-12-04 19:12:22
Exception caught from study name: | 2013-12-04 19:12:28
Exception caught from study name: | 2013-12-04 19:12:41
Exception caught from study name: | 2013-12-04 19:12:50
Exception caught from study name: | 2013-12-04 19:12:52
Exception caught from study name: | 2013-12-04 19:12:55
Exception caught from study name: | 2013-12-04 19:13:16
Exception caught from study name: | 2013-12-04 19:13:44
Exception caught from study name: | 2013-12-04 19:13:49
Exception caught from study name: | 2013-12-04 19:14:42
Exception caught from study name: | 2013-12-04 19:14:47
Exception caught from study name: | 2013-12-04 19:14:51
Exception caught from study name: | 2013-12-04 19:15:01
Exception caught from study name: | 2013-12-04 19:15:06
Exception caught from study name: | 2013-12-04 19:15:10
Exception caught from study name: | 2013-12-04 19:15:12
Exception caught from study name: | 2013-12-04 19:15:16
Exception caught from study name: | 2013-12-04 19:15:35
Exception caught from study name: | 2013-12-04 19:15:50
Exception caught from study name: | 2013-12-04 19:16:30
Exception caught from study name: | 2013-12-04 19:16:34
Exception caught from study name: | 2013-12-04 19:16:36
Exception caught from study name: | 2013-12-04 19:16:37
Exception caught from study name: | 2013-12-04 19:16:49
Exception caught from study name: | 2013-12-04 19:16:53
Exception caught from study name: | 2013-12-04 19:17:02
Exception caught from study name: | 2013-12-04 19:17:11
Exception caught from study name: | 2013-12-04 19:17:29
Exception caught from study name: | 2013-12-04 19:17:36
Exception caught from study name: | 2013-12-04 19:17:57
Exception caught from study name: | 2013-12-04 19:18:00
Exception caught from study name: | 2013-12-04 19:18:23
Exception caught from study name: | 2013-12-04 19:18:28
Exception caught from study name: | 2013-12-04 19:18:30
Exception caught from study name: | 2013-12-04 19:18:43
Exception caught from study name: | 2013-12-04 19:18:48
Exception caught from study name: | 2013-12-04 19:18:50
Exception caught from study name: | 2013-12-04 19:18:57
Exception caught from study name: | 2013-12-04 19:19:00
Exception caught from study name: | 2013-12-04 19:19:11
Exception caught from study name: | 2013-12-04 19:19:14
Exception caught from study name: | 2013-12-04 19:19:27
Exception caught from study name: | 2013-12-04 19:19:29
Exception caught from study name: | 2013-12-04 19:19:33
[2013-12-05 00:23:40]
For help with the out of order timestamps, refer to this page:
https://www.sierrachart.com/index.php?l=doc/helpdetails63.html
You may be using a study which does not exist anymore it may have been replaced by another one. You need to go through each of the charts and check the studies on the charts. You should see one with an empty name. You will need to remove it.
It definitely is one of the studies on the chart. What exactly the particular problem is, it is hard to say at this point.
Although it does seem as though you may be using a custom study. Possibly not aware of it? If there has been some internal changes to a study, really it should not result in an exception error.
Date Time Of Last Edit: 2013-12-05 00:26:11
