Date/Time: Sat, 04 May 2024 20:14:37 +0000
Referencing other studies in ACSIL
View Count: 1313
[2019-07-22 23:07:12] |
User929084 - Posts: 60 |
Can someone point me to documentation where referencing other studies in ACSIL is explained. I saw it couple days ago, but now can't seem to find it. And is there documentation on how to put 2 different studies together. Right now I do it with Color bar based on alert condition, but want to make it into a study. Thank you. |
[2019-07-23 14:35:10] |
TedMar - Posts: 189 |
u find good example in studies2.cpp example file scsf_StudySubgraphsReference or scsf_StudySubgraphReference
[2019-07-23 17:26:40] |
Refer to: ACSIL Programming Concepts: Using or Referencing Study/Indicator Data in an ACSIL Function Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2019-07-23 18:49:40] |
Thank you.
