Date/Time: Tue, 04 Nov 2025 11:00:15 +0000
Having to update symbol settings on every SC update
View Count: 653
[2019-07-22 13:02:20]
User104854 - Posts: 460
The last couple of times I've updated the software it's resetting the symbol settings that I have set back to default. I have them set to use commissions, record market depth, etc. Each time I've had to go back and re-enter these settings. Now the market depth doesn't appear to be recording.
Is there a way around this so that I don't have to do this every time I update to a newer version?
Why is the market depth not recording? I went in and put the setting to record to 'yes'. Do I have to restart the program or something? It would be much better if these settings did not have to be re-entered on every update.
Date Time Of Last Edit: 2019-07-22 13:07:45
[2019-07-23 03:09:47]
In newer versions of Sierra Chart this kind of problem is no longer an issue.
What you experienced, when updating to 1953 is a one-time issue and is explained here:
https://www.sierrachart.com/index.php?page=doc/Whats_New.php#SCVer1953
The settings are preserved. You just need to copy the settings that you need as explained in the notes for 1953.
You also need to make sure that Global Settings >> Symbol Settings >> Use Custom Symbol Settings Values is enabled.
Date Time Of Last Edit: 2019-07-23 03:12:00
