Date/Time: Mon, 28 Sep 2026 07:36:51 +0000
volume bars on the chart dom not displaying
View Count: 2140
| [2019-07-19 19:54:15] |
| User736519 - Posts: 26 |
Volume bars on the chart dom not displaying even though Show Volume Bars (Trade >> Customize Chart/Trade DOM Columns) is enabled. Check box for these volume bars option is disabled in Global Setting>Graphic settings. |
| [2019-07-19 20:17:28] |
Provide an image of the chart or Trade DOM, by following these instructions: https://www.sierrachart.com/index.php?page=doc/PostingInformation.php#Image Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
| [2019-07-19 20:24:56] |
http://www.sierrachart.com/image.php?Image=1563567848130.png
| [2019-07-21 00:36:52] |
Could you attach that chart by following the instructions here: Support Board Posting Information: Providing Chartbook with Only a Single Chart Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
| [2019-07-22 14:52:49] |
Here is the chartbook requested.
Private File |
| [2019-07-22 18:58:33] |
Hi, Is there any update on this? Thanks |
| [2019-07-23 14:12:39] |
Dont see any response. Can someone help with this?
| [2019-07-23 17:33:29] |
We have been thinking about this. We cannot reproduce the issue. Provide the Sierra3.CFG file from your Sierra Chart installation. Attach it here following these instructions: Support Board Posting Information: Attaching a File (Optional) Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2019-07-23 17:33:35
| [2019-07-23 17:52:37] |
File attached
Private File |
| [2019-07-23 18:57:18] |
| John - SC Support - Posts: 48028 |
Your setting for Maximum Volume Bar Width Percentage is 0. Therefore the volume bars will not show. This sets the percentage of the width of the column that is used for the volume bars. You need to set it to something larger than 0 (more than 50 is good, but it is a personal choice). It is found in Global Settings >> Chart DOM Settings. Refer to the documentation for it here: Global Trade Settings Windows: Maximum Volume Bar Width Percentage (Global Settings >> Chart DOM Settings >> Other >> Other Settings) For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
