Date/Time: Sat, 01 Feb 2025 12:41:46 +0000
SCDLLName missing even though it's there
View Count: 1687
[2019-07-19 00:21:22] |
User929084 - Posts: 60 |
Hi. I'm trying to modify a study and it builds no problem but when I try to add it to chart it say that SCDLLName is missing even though it's there on top, under #include "sierrachart.h" . I tried it with SCDLLName and //SCDLLName and it doesn't seem to work.
BidAskDifferenceWithMovingAverage.cpp - Attached On 2019-07-19 00:20:04 UTC - Size: 1.32 KB - 339 views |
[2019-07-19 01:28:59] |
User90125 - Posts: 715 |
Try removing any spaces and make it look something like SCDLLName("BidAskDifferenceWithMovingAverage")
[2019-07-19 01:42:01] |
I tried it and didn't help still have the same issue. Thank you. |
[2019-07-19 02:40:52] |
It works just fine for us using the Analysis >> Build Custom Studies DLL >> Build>> Remote Build. This is the final result on the chart: http://www.sierrachart.com/image.php?Image=1563504002989.png Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2019-07-19 13:01:15] |
For some reason I still get the "Missing SCDLLName..." after study is successfully build. And I get this msg in the log: The custom study "C:\SierraChart\Data\BidAskDifferenceWithMovingAverage_64.dll" is missing the SCDLLName line. Windows error code 127: The specified procedure could not be found. | 2019-07-19 07:41:54.894 * I will try do download current version and see if that helps. But to clarify, how should I include the SCDLLName? 1. //SCDLLName("Name of Study") 2. SCDLLName("Name of Study") Because in the documentation it is #2, but in user contributed studies it is #1. Thank you. |
[2019-07-19 16:44:39] |
Like number 2. Exactly how are you performing a build of that source code file?
[2019-07-19 19:22:14] |
I build it by following step-by-step instructions on your website. But I think I figured out what the problem was. The first time I build it I put //SCDLLName... Then when I build it the second time with SCDLLName... I didn't delete the first study from the /Data folder. Don't know if building second study with the same name will overwrite the first study. So this time around I deleted both .cpp from /ACS_Source and .dll from /Data folders and build it again from scratch and it works. Thank you. |
