Date/Time: Sat, 01 Feb 2025 09:49:18 +0000
CQG live data is jumping
View Count: 669
[2019-07-09 16:45:42]
User61576 - Posts: 445
i am connected to cqg api data feed and check the screenshot
the historical price is ok (i think) but the live is jumping
pls advice
imageScreenshot_8.png / V - Attached On 2019-07-09 16:44:39 UTC - Size: 204.15 KB - 305 views
[2019-07-09 17:36:41]
We have noticed this with CQG as well. Reconnect to the data feed:
And re-download the affected data:
Data Errors or Spikes in Charts, Flat or Flat Line Graph, Compressed Graph, Errors with Date/Time Values: 2.1.2 Deleting and Re-downloading Data. (Easier and Recommended Method)
We hope users are starting to realize the problems with CQG more and more. A problem like this should never happen and it is not due to any error on our side. We checked now.
Consider using this data feed instead:
Denali Exchange Data Feed
[2019-07-09 18:30:07]
what is the difference between SC df and denali's?
price?
delete and re download worked!
[2019-07-09 19:00:18]
Ok good. We have added logging to isolate the problem and we will ask CQG about it next time we see it.
price?
Yes primarily price difference.
