Date/Time: Sun, 24 Nov 2024 20:03:04 +0000
help
View Count: 1494
[2013-12-02 15:02:12]
julian pineda - Posts: 60
hi,
my chartbook crash...dont know what happend
http://screencast.com/t/27LrRfhp5
[2013-12-02 15:40:11]
Is it that there are not many bars in the chart? Looks like you have too much fill space. Make sure Chart >> Lock Fill Space is unchecked and then press the END key on the keyboard.
Also refer to help topic 7 here:
hhttp://www.sierrachart.com/index.php?l=doc/helpdetails7.html
[2013-12-02 16:09:39]
i dont have the historical data, this morning everything had gone.... everything is erase
[2013-12-02 18:59:42]
We have looked into this, and apparently the problem is because you are running a significantly older version, there is an issue with the access to historical data. You will need to update by selecting Help >> Download Current Version.
After the update follow the instructions in help topic 7.1 to download the missing data:
