Date/Time: Sat, 01 Feb 2025 06:57:16 +0000
hard drive space and sierrachart
View Count: 1669
[2019-06-30 07:38:24] |
qiw4u23oi4u234 - Posts: 34 |
Firs of all, why does sierrachart take so much hard drive space compare to other trading platoforms (eg. TWS)? The 'DATA' folder of my sierrachart is now close to 200gb. There are a lot of chartbooks of instruments that I do not trade anymore. So I went to File>Open Chartbook then deleted all the chartbooks I don't use anymore. However, that did not change anything in terms of hard drive space. Do I have to manually go through all the files in the 'data' folder and delete unecessary files? (I am afraid I might delete something important, or end up changing some settings on my existing charts) Or is there any way to delete all the files associated with a specific chartbook? Also, for example, suppose I already have a chartbook of a daily chart of crude oil with 200 days. Then, if I make a new chartbook and load another daily chart of crude oil (either by duplicating previous chart or by clicking 'find symbbol') does the size of sierrachart increase or remain the same? Thanks! Date Time Of Last Edit: 2019-06-30 07:50:46
[2019-06-30 12:19:50] |
True tick by tick data can take a lot of space and it is stored locally. However, those files are compressed so the actual used size is a lot less. You just need to delete the Intraday data files you no longer need: Chart Data and Chart Data Files: Deleting a Chart Data File Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2019-06-30 12:20:26
