Date/Time: Tue, 04 Nov 2025 14:59:35 +0000
Historical Daily data
View Count: 2708
|   [2013-04-10 16:07:48]     |
| Bruce Heubach - Posts: 16 |
                I'm on a trial of TT data and package#3.  I've selected to use SC historical data in the Historical Data Service Settings under the Data/Trade Service Settings tab.  However, it appears I'm only getting about 6 months of daily bars.  Is there something else I need to select to get years worth of daily bars?  Thanks.
|   [2013-04-10 16:50:59]     |
                Please refer to this page: http://www.sierrachart.com/index.php?l=doc/doc_ContinuousFuturesContractCharts.html Sierra Chart Support - Engineering Level  Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing  |
|   [2013-04-10 19:27:02]     |
                Thanks, gottit.
