Date/Time: Sat, 01 Feb 2025 02:01:52 +0000
[User Discussion] - Incorrect Study Overlay
View Count: 691
[2019-06-13 02:47:25]
User116783 - Posts: 84
When I attempt to overlay the BitMEX 20 day moving average onto a 4 hour chart, the value of the moving average on the destination chart incorrect.
On both charts under Chart Settings I've set the the Time Zone to New York EST; also under data/trade service settings, I've also set the Time Zone to New York EST.
When I set Time Zones to UTC time however, the value of the 20 SMA is correct overlayed onto the 4 hour chart.
Please fix this problem, this is not due to pilot error.
ZS
[2019-06-13 02:59:19]
Sorry, this post has no merit. There is no possibility of anything being wrong. The result you get is based on the data and the Study/Price Overlay study settings.
And the time zone settings certainly can have an impact on this if you are copying from a Historical Daily chart but that does not mean there is anything wrong.
Date Time Of Last Edit: 2019-06-13 03:01:01
[2019-06-13 03:06:30]
With all due respect, you're wrong.
I have followed the time zone settings to a T.
I still get the same inaccurate overlay when using NY EST.
Try it yourself if you don't believe me.
Put a 20 SMA on a Daily Chart, then try and overlay it onto a 4 hour chart using EST. The value for the 20 SMA on the destination chart will be wrong.
Again, the only way I can get the two to be the same is to use UTC time.
ZS
Date Time Of Last Edit: 2019-06-13 03:08:47
