Date/Time: Fri, 31 Jan 2025 22:55:32 +0000
Evening session developing Hi and Lo overlay
View Count: 866
[2019-06-08 18:06:40] |
User97684 - Posts: 136 |
Hi, Please help: I have 2 RTH charts - 2t renko and 15 mins from 14.30 to 21.15 hrs. Also I have 'evening session' 1 min chart that tracks the Hi and Lo from 21.30 to 14.29.59. I then overlay the evening session Hi and Lo over my RTH charts ( 14.30 to 21.15 ), using the overlay study with exact same settings. During overnight hours, my 2t renko RTH chart is showing Hi Lo as they are develpoing but on my 15 mins chart , these lines only appear after we get into RTH hours. I would like to see the HI and Lo during evening hours, over my RTH chart. Many thanks |
2t_renko_chart_is_showing_developing_evening_session_Hi_Lo.png / V - Attached On 2019-06-08 18:04:12 UTC - Size: 174.8 KB - 285 views 15_mins_chart_not_showing_the_developing_evening_session_Hi_.png / V - Attached On 2019-06-08 18:04:17 UTC - Size: 171.58 KB - 272 views Evening_session_Hi_and_Lo.png / V - Attached On 2019-06-08 18:04:27 UTC - Size: 66.28 KB - 267 views |
[2019-06-09 03:13:57] |
We will only take this as a paid support request. Cost estimate is 15-20.
Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2019-06-09 03:15:18
[2019-06-09 17:46:02] |
Hi , Thank you, I have added 20 USD to my account for this paid request. Pls let me know if that's ok. ----- I am adding 2 more images of identical charts ( duplicates ) that are acting differently with the evening sessions Hi Lo. Thanks, |
ON_Hi_Lo_are_showing_as_developing.png / V - Attached On 2019-06-09 17:44:37 UTC - Size: 126.95 KB - 258 views chart_24_though_is_not_showing_the_developing_On_Hi_Lo.png / V - Attached On 2019-06-09 17:44:42 UTC - Size: 126.51 KB - 291 views |
[2019-06-10 21:53:08] |
Ok we will work on this for you. Sorry about the delay.
[2019-06-10 22:09:20] |
John - SC Support - Posts: 37656 |
Can you please attach a chartbook that has these 3 charts within it. Please follow the instructions here to create a new chartbook and then copy the 3 charts to that chartbook and remove any extraneous studies that are not pertinent to this issue: Support Board Posting Information: Providing Chartbook with Only a Single Chart For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
[2019-06-11 12:27:10] |
Sure, thank you very much, pls see attachd Chartbook # 3 containing 2 charts of each - 2 with developing and 2 with yesterdays ON Hi Lo. Charts are on ES symbol ESM19 Thanks |
Chartbook3.Cht - Attached On 2019-06-11 12:25:19 UTC - Size: 2.5 MB - 355 views |
[2019-06-11 14:57:40] |
For what you are trying to do, you really need to set the Input in the Study/Price Overlay for Match Source Bars to Destination Bars to No. If you do this, you will see the result you are expecting. Really, what you were seeing in the Renko chart was the odd behavior. Since it is not a time-specific chart, the last bar in the Renko was picking up the beginning of that most recent evening session from the Study/Price Overlay. The documentation for Match Source Bars to Destination Bars can be found here: Study/Price Overlay Study: Match Source Bars to Destination Bars We have debited your account for $11.25 for the time to review this. For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
