Date/Time: Fri, 31 Jan 2025 23:00:29 +0000
Managing 2 accounts with different data feeds
View Count: 715
[2019-06-05 04:00:07] |
User716575 - Posts: 24 |
How can I manage a broker account with Cqg data and a One Up Trader account with Rithmic data? First installing the second account information. Second going back and forth from one account to the other. |
[2019-06-05 05:40:06] |
Refer to: Using Multiple Data and Trading Services at the Same Time Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2019-06-05 19:06:20] |
When I run a new instance I can only put in the User name and Password. The service is greyed out. Any ideas what I'm doing wrong?
[2019-06-05 20:53:47] |
It sounds like you started a new Sub-Instance (File >> New Instance), rather than installing a completely separate installation of Sierra Chart. You need to have 2 separate installations of Sierra Chart and then setup each one for the particular service you want to use (one for CQG and the other for Rithmic). The instructions for having the multiple installations is found in the link previously - here it is again: Using Multiple Data and Trading Services at the Same Time Once you have the installations taken care of, refer to the following sections for setup instructions to each of those services: CQG Trading Platform Service: Setup Instructions and Rithmic Trading Platform Service: Setup Instructions Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
