Date/Time: Fri, 31 Jan 2025 20:43:18 +0000
cannot connect the futures company in order to use lower CME FEE - Account Support Ticket
View Count: 914
[2019-06-03 07:43:54]
User884604 - Posts: 1
hi , i am the user of sc chart and also open a trading account in infinity future company(TranAct) .
every month , i do the process in the Data trade service setting and connect to the tranAct . then
i change it back to Sc chart All data . after that i can use the lower CME data charge . but this month ,
i do the same process . it said that the user name and password are invalid . BUT its not true .
in fact the user name and the password are correct . now i cannot use the CME data . what should i do ?
(I also check my trading account in infinity future is normal and is nothing worong . )
image222.JPG / V - Attached On 2019-06-03 07:42:06 UTC - Size: 97.18 KB - 265 views
image444.JPG / V - Attached On 2019-06-03 07:42:14 UTC - Size: 113.34 KB - 286 views
[2019-06-03 12:08:23]
You need to contact your broker or Transact support for help with this. This is their website:
https://www.transactfutures.com/
Date Time Of Last Edit: 2019-06-03 12:08:32
