Date/Time: Sat, 04 May 2024 03:06:49 +0000
Poloniex Data
View Count: 2677
[2019-06-03 00:52:56] |
Neo - Posts: 198 |
I'm having trouble receiving Polonienx data. Data has stopped updating "Socket (2) | Socket gracefully closed by remote side. | 2019-06-03 00:43:39.266 Socket (2) | Closed. | 2019-06-03 00:43:39.266" It's like the whole connection is down- When I try to populate the "get symbols" list nothing with load. " SC DTC Data with Market Depth | Sending symbols for exchange request. Exchange: Poloniex.CryptoCurrencyExchange | 2019-06-03 00:45:09.165 SC DTC Data with Market Depth | Received 0 symbols for symbols exchange (Poloniex.CryptoCurrencyExchange) request. | 2019-06-03 00:45:09.414 " |
[2019-06-03 01:08:14] |
There is a problem with the Poloniex data feed from the source we get it from. This is not within our control. We cannot provide further help with this.
[2019-09-03 20:52:49] |
Queeq - Posts: 42 |
The feed is again down for more than a week. And overall it is quite unreliable: this year it was interrupted several times and the gaps were never filled. Are there any plans to fix this?
[2019-09-04 09:37:01] |
No. The data feed is provided through a third-party. We might as well just remove it. At this point we are delisting Poloniex and also delisting Bitfinex. Consider both of those unsupported and unavailable at this point in time. We will shut it down permanently at the end of the year. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2019-09-04 09:38:30
[2019-09-06 12:21:01] |
User960746 - Posts: 25 |
Will Sierra Chart consider other third-party data provider? The AIcoin https://www.aicoin.net.cn/?lang=en, their data source is really stable and fluent,including all the main trading platfrom. Hope you consider to relist Bitfinex and other platform. Thank you. |
[2019-09-06 12:27:27] |
Please let me know if you consider the third-party data provider AIcoin. They provide real-time and history data of Bitfinex, okex, huobi, binance, and so on. I can do my best for connecting you and AIcoin. Really hope for bring Bitfinex back. |
[2019-09-06 19:00:28] |
Bitfinex is still supported, we just do not list it as supported.
[2019-09-07 00:04:48] |
The data of symbol bchusd and eosusd of bitfinex is missing now, so hope you consider the third-party data source. If I provide the XML data file from the third data provider Aicoin, can you add the data to sierra chart server? Thank you. |
[2019-09-07 03:26:55] |
Support for Bitfinex has stopped. We are not willing to provided any further support for it. We are not going to consider any third-party data sources unless they support the DTC Protocol: https://dtcprotocol.org/ Refer to our post number 27 here: Crypto Currency Development Plans Sierra Chart is not going to be any longer a program which is going to be supporting various different external services other than for those services which support the DTC Protocol in a reliable way. And they do not even have to support historical data over DTC, we will maintain the history for any crypto currency exchange. And that is always how we want to do it. We will always maintain the historical data for the exchanges. We have been steadily working on all of the functionality for a proper high-performance exchange, and that is what we intend to offer as soon as we can. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2019-09-07 03:31:04
[2019-09-07 03:43:31] |
Really appreciate for your help. As you mentioned the DTC Protocol, I found something in the link https://www.sierrachart.com/index.php?page=doc/DataTradingServiceProviderIntegrationWithSierraChart.php. It says, Sierra Chart can also integrate to your Data or Trading service using the following message/communication protocols and data formats: FIX, HTTP, JSON, XML, proprietary or comma delimited data formats. So, without DTC Protocol, will you still support data feed by HTTP? I have contacted the third-party data provider AICOIN, they can do the HTTP way. And I will pay them for the data service. If I pay the data service, will everyone using Sierra Chart can access the data feed from AICOIN? Thank you. |
[2019-09-07 03:46:00] |
By the way, the third-party data source is not cheap, If the third-party AICION support the DTC Protocol, will Sierra Chart consider to pay for thier data feed serivce?
[2019-09-07 03:58:56] |
They really would need to use the DTC protocol. We can also support a websocket connection using DTC JSON messages. Yes and we can pay for it, but we need to discuss terms with them first. Have them initiate communication to us to support _at_ sierrachart.com. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2019-09-07 03:59:30
[2019-09-07 04:34:43] |
We do not know anything about AICOIN (https://www.aicoin.net.cn/). But if they are good programmers, and want to create reliable interfaces which are maintained, between exchanges and the DTC Protocol using whatever supported encoding method they want, then we would be happy to work with them and pay them.
Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2019-09-07 04:37:17
[2019-09-07 06:04:29] |
I contacted AICOIN, they will reach you later. AIcoin is the most popular Crypocurrency Android APP in China, and they also offer web and PC version. AIcoin provides the data feed of the most top Crypotcurrency Exchange, such as Binance, Bitfinex, Bitmex, Bitstamp, Okex, Bithumb, Huobi, Bitflyer, Bittrex, Bybit, Coinbase, Deribit, Kraken, OKCOIN, Poloniex and so on. The full list can be found in the Exchange at the top of the chart, https://www.aicoin.net.cn/chart/okcoinfutures_btcquarter Their team are really responsible and reliable. |
[2019-09-10 03:15:14] |
AIcoin told me they sent the email to you, do you receive the Email?
[2019-09-10 03:19:30] |
Yes we have the email. We will be looking it over and contacting them.
[2019-09-20 04:19:38] |
Hi, AIcoin told me they are looking for your reply, will you consider their data feed?
[2019-09-20 09:06:29] |
We have to get back to you on this. We did ask about pricing and we have to see if we got a response from them on that.
[2019-09-20 13:28:55] |
So far they have not come back to us in regards to pricing.
Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2019-09-20 13:29:03
[2019-09-20 19:57:37] |
Can you tell us what exchanges you want market data from and we can look at just going direct to those exchanges and seeing what we can do to improve integration to the ones we already work with , other than BitMex which is already direct and stable.
[2019-09-22 05:16:48] |
Bitfinex or OKEX: : EOSUSD, BCHUSD
[2019-09-22 06:48:20] |
AIcoin told me they added your Skpye account, you can talk about details by Skype.
[2019-10-12 18:43:48] |
Regarding AIcoin, we did communicate with them some by Skype but when we asked them about pricing they did not answer us. They say they can support any real-time data format we want.
[2020-01-10 12:16:40] |
BeardPower - Posts: 51 |
I was following this thread, and I think we all agree that the exchanges need to settle on the same protocol. @SC: There are other reliable and high-quality providers of aggregated data-feeds and trading integration: https://developers.shrimpy.io/ https://www.coinapi.io/ It would be appreciated if you could reach out to them directly for providing the DTC protocol. Date Time Of Last Edit: 2020-01-10 12:23:08
[2020-01-10 12:45:31] |
Queeq - Posts: 42 |
I agree, aggregated provider would be just amazing.
